CUL_RFR issues
Begonnen von Guest, 01 März 2011, 21:22:18
Guest
I bought a second cul als v3.2 to expand the range. I hope this also
work with sending fs20 commands?
I installed and configured it, but I'm not sure it works ok.
I have this but no State?
fhem> l MyRFR
   DEF        02 01
   ID         02
   IODev      CUL
   MyRFR_MSGCNT 11982
   MyRFR_TIME 2011-03-01 21:17:18
   NAME       MyRFR
   NR         3
   NR_EMSG    90
   NR_FMSG    5
   NR_KMSG    780
   NR_RMSG    1
   NR_TMSG    9821
   RAWMSG     T130300B6420D
   ROUTERID   01
   RSSI       -67.5
   STATE      ???
   TYPE       CUL_RFR
Also  sinds I plugged it in, my FHZ lost control of the primair CUL??
 CUL
   CUL_MSGCNT 26092
   CUL_TIME   2011-03-01 21:18:25
   DEF        /dev/cul868 4631
   DeviceName /dev/cul868
   FD         4
   FHTID      4631
   NAME       CUL
   NR         2
   PARTIAL
   RAWMSG     K172020070021F8E2
   RSSI       -89
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.40 CUL868
Any ideas?
Regards Richard
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Zrrronggg!
> I hope this also
Yes, but you need to define the IOdevice, f.e.
attr fht_room1 IODev MyRFR
SENDING can only be done by one CUL and you have to define per
attribute which one you want so use for every FHT an FS20 device.
Thats normal. RFRs do not deliver a state.
But you get a RSSI value and a RAWMSG etc. that means that the RFR is
doing at least something.
>  CUL
> Internals:
>    CUL_MSGCNT 26092
>    FD         4
>    FHTID      4631
>    NAME       CUL
>    NR         2
>    PARTIAL
>    RSSI       -89
>    STATE      Initialized
>    TYPE       CUL
What do you mean by "lost control"?
Everything looks quite normal to me.
FHEM auf RPi3B+, CUL 868 SlowRF, 2xCUL 868 RFR, 2x CUL 433 für IT, 2xHMLAN Configurator  + USB_HmUART mit VCCU, ITV-100 Repeater, Sender, Sensoren und Aktoren von FS20, S300, HM, IT, RSL, Blink
Guest
Ok,
Setting the OIDev was solving the issues tnhx
On Mar 2, 3:05 am, "Zrrronggg!" wrote:
> > I hope this also
> >  CUL
> > Internals:
> >    CUL_MSGCNT 26092
> >    FD         4
> >    FHTID      4631
> >    NAME       CUL
> >    NR         2
> >    PARTIAL
> >    RSSI       -89
> >    STATE      Initialized
> >    TYPE       CUL
