HOW-TO: CUL, Netgear ReadyNAS and CUL
Begonnen von Guest, 21 März 2011, 23:48:22
Guest
How to install FHEM 5.0 on a Netgear ReadyNAS Duo
Document created and compiled by A. Thobaben referencing various other
sources.
This "How-To" is provided "as it is" - read through it, understand it
and use it at your OWN RISK.
The Author is not responsible of the loss of time, date and nerves.
Considering donation to the red cross to help japan and step away from
nuklear power generation - consider alternatives.
1) Update to the latestet Firmware (4.1.7)
2) Get SSH access:
   A. Download the EnableRootSSH extension. I've used the following
link:
   http://www.readynas.com/download/addons/4.00/EnableRootSSH_1.0.bin
   B. Go in the ReadyNAS FrontView with your browser and go to System -
> Update -> Local Update
   C. Upload the EnableRootSSH binary file. The ReadyNAS verifies that
content and if it is correct it displays a description of the addon.
3) Get the so called development enviroment up and running
   Follow the instructions under: http://www.readynas.com/?p=145
   Create the missing system link between the gcc binary and cc
otherwise the make command with the GPL Sources will fail. Use the
following command:
      cd /usr/bin
      ln -sn cc gcc
4) Create a folder "GPL" under /c/ and download the GPL Sources
(~480MB)using the following commands:
   cd /c
   mkdir GPL
   cd GPL
   wget http://www.readynas.com/download/GPL/RNR4_RND4_RND2_4.1.7_WW_src.zip
   >> Hint: check the following URL for your NAS: http://www.readynas.com/?page_id=2324
   unzip RNR4_RND4_RND2_4.1.7_WW_src.zip
5) Setup the configuration for padre. Therefore "cd" to the linux
kernel directory
   cd /c/GPL/linux-2.6.17.14/
   and run
       cp arch/padre/defconfig .config
6) There is a hardcoded cross-compile setup in the kernel build, which
needs to be fixed. Edit arch/padre/Makefile, and replace the line that
starts with "CROSS_COMPILE" with one like this
    CROSS_COMPILE ?=
7) Install the APT-Addon - follow the instructions under:
http://www.readynas.com/?p=4216
8) Install libncurses5-dev using the following command:
   apt-get install libncurses5-dev
9) Configure the compilation of the missing USB Modules using the
following command:
   make menuconfig
   >> Hint: make menuconfig take quite a while on the little box. In
the end it gives you the installation screen to configure the kernel
modules.
   With this tool you can end up easily in reinstalling everthing form
defaults. I did this myself... .
   You have to configure the modem usb drivers (we are looking for the
cdc_acm module).
   USE AT YOUR OWN RISK! <<
   compile the modules:
   make modules
   >> Hint: Takes time as well... <<
   and install the compiled modules using:
   make modules_install
10) Reinstall Perl, it's tools and libraries
   apt-get --reinstall install perl perl-base perl-modules perl-doc
11) update CPAN
   apt-get install cpan
   >> Hint: Endless session with a couple of questions in between. You
will sit longtime in fornt of the terminal but needed....  <<
12) install Device::Serial in a version greater than 1.x
   cpan install Device::SerialPort
13) Install the screen tool
   apt-get install screen
14) Install FHEM 5.0 from sources or from .deb file
15) Configure FHEM with you setting and devices (here my sample)
      # pgm2 / autocreate configfile. Take a look at the other
examples for more.
      attr global logfile /var/log/fhem/fhem-%Y-%m.log
      attr global modpath /usr/share/fhem                     # where
our FHEM directory is
      attr global port 7072                           # our TCP/IP port
(localhost only)
      attr global statefile /var/log/fhem/fhem.save         # where to
save the state of the devices
      attr global verbose 3                           # "normal" verbosity
(min 1, max 5)
      define CUL CUL /dev/ttyACM0 1234
      #define FHEM FHEM /dev/USB0
      define WEBS FHEMWEB 8084 global
      attr WEBS smallscreen
      # Fake logfile, to access the global log
      define Logfile FileLog /var/log/fhem/fhem-%Y-%m.log fakelog
      define Arbeitszimmer FS20 1234 10
      define Kinderzimmer FS20 1234 20
      define Mobil_Lampe FS20 1234 30
      # Comment out for initial testing....
      # define autocreate autocreate
      # attr autocreate autosave
      # attr autocreate device_room %TYPE
      # attr autocreate filelog /var/log/fhem/%NAME-%Y.log
      # attr autocreate weblink
      # attr autocreate weblink_room Plots
16) Flash CUL with the latest firmware (culfw 1.40) if needed
17) Reboot the whole thing
18) Load the module by running:
   insmod cdc_acm.ko
19) Attach the CUL to the USB Slot (I used the front one)and check the
syslog:
   tail --lines=100 /var/log/syslog
    You should see something like this:
    Mar 21 21:10:44 Talacker-NAS kernel: usb 3-1: new full speed USB
device using uhci_hcd and address 6
    Mar 21 21:10:44 Talacker-NAS kernel: usb 3-1: configuration #1
chosen from 1 choice
    Mar 21 21:10:44 Talacker-NAS kernel: cdc_acm 3-1:1.0: ttyACM0: USB
ACM device
    Mar 21 21:10:54 Talacker-NAS usb.agent: ... no modules for USB
product 3eb/204b/0
    Only the "no modules message" looks scary.
20) Check with the following:
       lsusb
    Gives you:
    Bus 003 Device 006: ID 03eb:204b Atmel Corp.     <<< This is your
CUL...
    Bus 003 Device 001: ID 0000:0000
    Bus 002 Device 001: ID 0000:0000
    Bus 001 Device 001: ID 0000:0000
21) test the usb device with
   screen /dev/ttyACM0
   press "V" (Shift-V) and you should see the Version String of the CUL
Firmware
   unplug the CUL for some seconed to kill screen...
22) start FHEM
   perl /usr/bin/fhem.pl /etc/fhem.cfg
23) Check fhem.log by using:
   tail -lines=100 /var/log/fhem/YOURFHEM.LOG
    You should not see any warning and the device must be read.
   Might looks like this:
   2011.03.21 23:35:14 3: CUL opening CUL device /dev/ttyACM0
   2011.03.21 23:35:14 3: CUL device opened
   2011.03.21 23:35:15 2: FHEMWEB port 8083 opened
   2011.03.21 23:35:15 2: FHEMWEB port 8084 opened
   2011.03.21 23:35:15 0: Server started (version 5.0 from 2010-08-15
($Id: fhem.pl,v 1.110 2010-08-14 10:35:12 rudolfkoenig Exp $), pid
12398)
   2011.03.21 23:35:46 2: FS20 set Arbeitszimmer on
   2011.03.21 23:35:56 2: FS20 set Arbeitszimmer off
24) Startup your webbrowser and navigate to the NAS URL
   http://your-ReadyNAS:8083/fhem
    You should see the settings under "unsorted" and you can switch on
the lights...
    Works fine :-)
Regards,
Axel Thobaben
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
