HM-CC-RT-DN gibt keine Daten trotz pairing. [gelöst]
Begonnen von BenMarloe, 30 Dezember 2016, 13:04:30
BenMarloe
Mein HM-CC-RT-DN ist offensichtlich gepairt:
2016-12-30_10:34:57 DgWzVentil Activity: alive
2016-12-30_10:34:57 DgWzVentil D-firmware: 1.4
2016-12-30_10:34:57 DgWzVentil D-serialNr: NEQ1411641
2016-12-30_10:35:02 DgWzVentil Activity: alive
2016-12-30_10:46:38 DgWzVentil Activity: dead
2016-12-30_12:41:52 DgWzVentil Activity: alive
2016-12-30_12:41:52 DgWzVentil D-firmware: 1.4
2016-12-30_12:41:52 DgWzVentil D-serialNr: NEQ1411641
gibt aber kein bisschen Daten ins log. Woran könnte das liegen?
Hier noch das Listing des devices:
   DEF        50238A
   HMLAN1_MSGCNT 2
   HMLAN1_RAWMSG E50238A,0000,0011AF85,FF,FFCC,01840050238A0000001400954E4551313431313634315900FFFF
   HMLAN1_RSSI -52
   HMLAN1_TIME 2016-12-30 12:42:25
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     2
   NAME       DgWzVentil
   NOTIFYDEV  global
   NR         334
   NTFY_ORDER 50-DgWzVentil
   STATE      T:measured-temp, Td:desired-temp, H:humidity, V:actuator, controlMode
   TYPE       CUL_HM
   channel_01 DgWzVentil_Weather
   channel_02 DgWzVentil_Climate
   channel_03 DgWzVentil_WindowRec
   channel_04 DgWzVentil_Clima
   channel_05 DgWzVentil_ClimaTeam
   channel_06 DgWzVentil_remote
   lastMsg    No:01 - t:00 s:50238A d:000000 1400954E4551313431313634315900FFFF
   protLastRcv 2016-12-30 12:42:25
   rssi_at_HMLAN1 avg:-51.5 min:-52 max:-51 lst:-52 cnt:2
   Readings:
     2016-12-30 13:01:52   Activity        dead
     2016-12-30 12:41:51   D-firmware      1.4
     2016-12-30 12:41:51   D-serialNr      NEQ1411641
   Helper:
     HM_CMDNR   21
     mId        0095
     rxType     140
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +50238A,00,00,00
       nextSend   1483098145.36412
       prefIO
       rxt        0
       vccu
       p:
         50238A
         00
         00
         00
     Mrssi:
       mNo        01
       Io:
         HMLAN1     -50
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf   01,02,03,04,05,06
       qReqStat
     Role:
       dev        1
       prs        1
     Rssi:
       At_hmlan1:
         avg        -51.5
         cnt        2
         lst        -52
         max        -51
         min        -52
     Tmpl:
   IODev      HMLAN1
   actCycle   000:10
   actStatus  dead
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.4
   group      thermostat
   model      HM-CC-RT-DN
   room       CUL_HM,DG
   serialNr   NEQ1411641
   stateFormat T:measured-temp, Td:desired-temp, H:humidity, V:actuator, controlMode
   subType    thermostat
Alles ist kompliziert - bis man es verstanden hat
Fhem auf Raspberry 2 B
EnOcean / Homematic / Eigenbau / ABB 23 / SolarEdge SE10k
BenMarloe
Werks-Reset und erneutes Pairing haben dem abgeholfen. Seltsam..
