main::AttrVal called by ./FHEM/10_CUL_HM.pm (7285)
Begonnen von Rampler, 14 April 2017, 08:27:18
Rampler
ich glaube diese Meldung:
PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4036.
kommt von 10_CUL_HM.pm ...
Stacktrace gibt das hier bei Aufruf von "get hm configcheck aus" ...
2017.04.14 08:12:55 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4036.
2017.04.14 08:12:55 1: stacktrace:
2017.04.14 08:12:55 1:     main::__ANON__                      called by fhem.pl (4036)
2017.04.14 08:12:55 1:     main::AttrVal                       called by ./FHEM/10_CUL_HM.pm (7285)
2017.04.14 08:12:55 1:     main::CUL_HM_getMId                 called by ./FHEM/10_CUL_HM.pm (7304)
2017.04.14 08:12:55 1:     main::CUL_HM_getRxType              called by ./FHEM/98_HMinfo.pm (621)
2017.04.14 08:12:55 1:     main::HMinfo_burstCheck             called by ./FHEM/98_HMinfo.pm (2101)
2017.04.14 08:12:55 1:     main::HMinfo_configCheck            called by FHEM/Blocking.pm (153)
2017.04.14 08:12:55 1:     main::BlockingStart                 called by FHEM/Blocking.pm (78)
2017.04.14 08:12:55 1:     main::BlockingCall                  called by ./FHEM/98_HMinfo.pm (1327)
2017.04.14 08:12:55 1:     main::HMinfo_GetFn                  called by ./FHEM/98_HMinfo.pm (1634)
2017.04.14 08:12:55 1:     main::HMinfo_SetFn                  called by fhem.pl (3374)
2017.04.14 08:12:55 1:     main::CallFn                        called by fhem.pl (1718)
2017.04.14 08:12:55 1:     main::DoSet                         called by fhem.pl (1750)
2017.04.14 08:12:55 1:     main::CommandSet                    called by ./FHEM/98_cmdalias.pm (98)
2017.04.14 08:12:55 1:     main::CommandCmdAlias               called by fhem.pl (1149)
2017.04.14 08:12:55 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2440)
2017.04.14 08:12:55 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (850)
2017.04.14 08:12:55 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (539)
2017.04.14 08:12:55 1:     main::FW_Read                       called by fhem.pl (3379)
2017.04.14 08:12:55 1:     main::CallFn                        called by fhem.pl (685)
EDIT:
In der Zeile 7285 wird AttrVal mit einem nicht definierten Wert als Geraetename aufgerufen.
   Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
martinp876
Werde ich mir nächste Woche ansehen. Habe aktuell keinen Zugriff.
Rampler
Bump, sonst rutscht es immer weiter zurück ..
martinp876
Rampler
