[gelöst] HM-LC-Sw1PBU-FM MISSING ACK nach neuem anlernen
Begonnen von moontear, 24 Januar 2017, 21:27:20
moontear
Neuer Schalter HM-LC-Sw1PBU-FM.
Anlernen funktioniert super (neue Schalter, unbenutzt), hier list HM_50BEE3
   CFGFN
   CUL_0_MSGCNT 3
   CUL_0_RAWMSG A1A01840050BEE30000002800694E45513136343638343110010100::-59:CUL_0
   CUL_0_RSSI -59
   CUL_0_TIME 2017-01-24 21:18:08
   DEF        50BEE3
   IODev      CUL_0
   LASTInputDev CUL_0
   MSGCNT     3
   NAME       HM_50BEE3
   NOTIFYDEV  global
   NR         434
   STATE      RESPONSE TIMEOUT:RegisterRead
   TYPE       CUL_HM
   lastMsg    No:01 - t:00 s:50BEE3 d:000000 2800694E45513136343638343110010100
   protCmdDel 4
   protLastRcv 2017-01-24 21:18:08
   protResnd  6 last_at:2017-01-24 21:22:47
   protResndFail 2 last_at:2017-01-24 21:22:53
   protSnd    2 last_at:2017-01-24 21:22:35
   protState  CMDs_done_Errors:1
   rssi_at_CUL_0 lst:-59 min:-63.5 cnt:3 max:-59 avg:-61.83
   Readings:
     2017-01-24 21:18:08   D-firmware      2.8
     2017-01-24 21:18:08   D-serialNr      NEQ1646841
     2017-01-24 21:17:15   deviceMsg       off (to broadcast)
     2017-01-24 21:17:15   level           0
     2017-01-24 21:17:15   pct             0
     2017-01-24 21:17:15   powerOn         2017-01-24 21:17:15
     2017-01-24 21:17:15   recentStateType info
     2017-01-24 21:22:53   state           RESPONSE TIMEOUT:RegisterRead
     2017-01-24 21:17:15   timedOn         off
     Regl_00.:
       VAL
   Helper:
     HM_CMDNR   42
     PONtest    0
     cSnd       11CA5A0050BEE30201C80000,01CA5A0050BEE300040000000000
     dlvl       C8
     dlvlCmd    ++A011CA5A0050BEE30201C80000
     getCfgList all
     getCfgListNo ,3
     mId        0069
     rxType     1
     supp_Pair_Rep 1
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +50BEE3,00,00,00
       nextSend   1485289088.23151
       prefIO
       rxt        0
       vccu
       p:
         50BEE3
         00
         00
         00
     Mrssi:
       mNo        01
       Io:
         CUL_0      -57
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rssi:
       At_cul_0:
         avg        -61.8333333333333
         cnt        3
         lst        -59
         max        -59
         min        -63.5
     Tmpl:
   IODev      CUL_0
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.8
   model      HM-LC-Sw1PBU-FM
   room       CUL_HM
   serialNr   NEQ1646841
   subType    switch
   webCmd     statusRequest:toggle:on:off
Leider funktioniert kein schalten/getConfig. Da bekomme ich MISSING ACK oder bei getConfig RESPONSE TIMEOUT:RegisterRead. Ich habe jetzt schon 3x probiert den Schalter aus fhem zu löschen und auf den Werkszustand zu setzen. Anlernen funktioniert jedes mal immer prächtig, aber alles danach nicht.
Was kann ich noch probieren?
piet_pit
wahrscheinlich nicht gepairt, was steht bei "R-pairCentral"?
VG
Pit
FHEM Latest Revision: 29615
Raspberry Pi 3, Rasbian-Stretch
FRITZ!Box 7690
HM-Mod-RPI-PCB, JeeLink
CUNO 1.47
moontear
komplettes list ist oben R-pairCentral sehe ich gar nicht.
Ich habe den Schalter manuell angeschaltet und irgendwann kam die Message auch an:
2017-01-24_21:29:20 HM_50BEE3 deviceMsg: on (to broadcast)
2017-01-24_21:29:20 HM_50BEE3 level: 100
2017-01-24_21:29:20 HM_50BEE3 pct: 100
Trotzdem funktioniert senden nicht... Sehr komisch. Der Schalter ist direkt neben einem HOmematic Thermostaten. Problem?
piet_pit
hier ein Auszug aus dem Wik, Anlernen von HM-Komponenten.
Pairing verifizieren
Nur weil ein Gerät angelegt wurde, heißt das nicht, dass es auch gepaired ist. In den Readings eines Devices muss stehen (list <name> oder im Webinterface):
R_pairCentral  0xABCDEF
ABCDEF steht dabei für die HMID des IO-Device (zB CUL). Wurde für das IO-Device kein attribute mit einer individuellen HMID gesetzt, sollte hier die Standard-ID F11034 stehen. Die führende 0x steht für den Hinweis auf eine HEX-Adresse.
Ist das Pairing noch nicht abgeschlossen, kann man nach kurzer Pause den Befehl:
set <HM-Gerät> getConfig
VG
Pit
FRITZ!Box 7690
CUNO 1.47
moontear
Piet perfekter Hinweis. https://wiki.fhem.de/wiki/HomeMatic_Devices_pairen
Zitatnoch einmal probieren, ein getConfig auszulösen - vielleicht hat das Lesen nicht funktioniert
    noch einmal pairen - das schadet nichts
    die Anlerntaste / Configtaste / irgendeine Taste am Gerät (hängt vom konkreten Device ab) wiederholt drücken um die Datenübertragung anzustoßen.
Ich habe jetzt einfach 5 mal hintereinander die Config Taste gedrückt. Siehe da pairCentral ist gesetzt und das Device funktioniert.
