[HM-LC-Sw1-DR] level C8 instead of 00
Begonnen von betateilchen, 28 März 2017, 17:31:26
Hallo Martin,
wie interpretiere ich diese Meldung im Logfile?
2017.03.28 17:25:18 3: CUL_HM fl_Lichtaktor repeat, level C8 instead of 00
Der Aktor ist ein HM-LC-Sw1-DR und ansonsten korrekt eingerichtet.
   CFGFN
   DEF        40DE0D
   IODev      hmuart
   LASTInputDev hmuart
   MSGCNT     9
   NAME       fl_Lichtaktor
   NOTIFYDEV  global
   NR         102
   NTFY_ORDER 50-fl_Lichtaktor
   STATE      off
   TYPE       CUL_HM
   hmuart_MSGCNT 9
   hmuart_RAWMSG 0403005418800240DE0D34C3680101000057
   hmuart_RSSI -84
   hmuart_TIME 2017-03-28 17:25:20
   lastMsg    No:18 - t:02 s:40DE0D d:34C368 0101000057
   protLastRcv 2017-03-28 17:25:20
   protSnd    9 last_at:2017-03-28 17:25:19
   protState  CMDs_done
   rssi_at_hmuart cnt:9 lst:-84 min:-84 avg:-81.66 max:-79
   rssi_hmuart avg:-84.44 min:-87 lst:-87 cnt:9 max:-81
   Helper:
     Dblog:
       Devicemsg:
         Fhemdblog:
           TIME       1490714720.05292
           VALUE      off (to hmvccu)
       Level:
         Fhemdblog:
           VALUE      0
       Levelmissed:
         Fhemdblog:
           TIME       1490714718.17128
           VALUE      desired:0
       Pct:
         Fhemdblog:
           VALUE      0
       State:
         Fhemdblog:
           VALUE      off
       Timedon:
         Fhemdblog:
           VALUE      off
   Readings:
     2017-03-28 17:25:20   CommandAccepted yes
     2017-02-19 19:58:13   D-firmware      2.8
     2017-02-19 19:58:13   D-serialNr      MEQ1563378
     2017-03-21 11:43:51   PairedTo        0x34C368
     2017-02-19 19:58:17   R-pairCentral   0x34C368
     2017-02-19 19:58:18   R-powerUpAction off
     2017-02-19 19:58:18   R-sign          off
     2017-03-21 11:43:51   RegL_00.        02:01 0A:34 0B:C3 0C:68 15:FF 18:00 00:00
     2017-03-21 11:43:52   RegL_01.        08:00  30:06 57:24 56:00 93:11 94:3A 00:00
     2017-03-28 17:25:20   deviceMsg       off (to hmvccu)
     2017-03-28 17:25:20   level           0
     2017-03-28 17:25:18   levelMissed     desired:0
     2017-03-28 17:25:20   pct             0
     2017-03-27 23:16:25   powerOn         2017-03-27 23:16:25
     2017-03-28 17:25:20   recentStateType ack
     2017-03-28 17:25:20   state           off
     2017-03-28 17:25:20   timedOn         off
   Helper:
     HM_CMDNR   24
     cSnd       1134C36840DE0D0201000000,1134C36840DE0D0201000000
     mId        00F0
     rxType     1
     supp_Pair_Rep 0
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +40DE0D,00,00,00
       nextSend   1490714720.13209
       rxt        0
       vccu       hmvccu
       p:
         40DE0D
         00
         00
         00
       prefIO:
         hmuart
     Mrssi:
       mNo        18
       Io:
         hmuart     -82
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rssi:
       At_hmuart:
         avg        -81.6666666666667
         cnt        9
         lst        -84
         max        -79
         min        -84
       Hmuart:
         avg        -84.4444444444444
         cnt        9
         lst        -87
         max        -81
         min        -87
     Shadowreg:
     Tmpl:
   IODev      hmuart
   IOgrp      hmvccu:hmuart
   autoReadReg 0_off
   expert     2_raw
   firmware   2.8
   model      HM-LC-Sw1-DR
   peerIDs    00000000,
   room       18 Flur
   serialNr   MEQ1563378
   subType    switch
   webCmd     statusRequest:toggle:on:off
justcallmeal
...eine Antwort hierzu würde mich auch interessieren.
Ich erhalte seit Kurzem diese Meldung bei einem HM-MOD-Re-8
VG,
al
HM-Sen-DB-PCB, HM-Sec-SCo, HM-MOD-Re-8, HM-SEC-SC-2, HM-Sen-MDIR-O, HM-LC-Sw1PBU-FM, HM-LC-RGBW-WM, HM-ES-PMSw1-SM, HM-LC-Sw1-DR, div. Shellies u.v.m.
Sedikit
Dimmer reagieren unter Umständen sensibel auf die Unterschreitung der Mindestlast. Habt ihr LED daran angeschlossen?
Umgangen werden kann dies durch entsprechendes Setzen eines Registers. Dazu mal in die Commandref schauen.
VG
   Sedikit
Gesendet von iPad mit Tapatalk
Pfriemler
#3
Beide Aktoren sind Schalter, keine Dimmer.
Level C8 entspricht 200 und ist das Gegenstück zu 0. FHEM übersetzt das intern auf 100 (= on) und off.
Irgendwie wird ein unerwarteter Schaltzustand zurückgemeldet.
In betateilchens Auszug fällt auf, dass laut einem mit "levelMissed" bezeichneten Internal wohl der Aktor zurückmelden _sollte_, dass er einen Ausschaltbefehl bekommen hat (was man in FHEM sonst mit "set_off" im Status zu sehen bekommt. Anscheinend quittert der Aktor auch was, aber das zurückkommende entspricht nicht den Erwartungen. Nichtsdestotrotz folgt 2s später eine Vollzugsmeldung mit korrektem Wert.
Im Auszug liegen die rssi zudem bedenklich niedrig. Denkbar, dass es hier Verfälschungen und Ausfälle durch zu niedrigen Funkpegel gibt. Wäre aber außergewöhnlich aus meiner bescheidenen Kenntnis.
Nun wäre interessant wie das beim Re-8 aussieht
Gesendet von meinem SM-G900FD mit Tapatalk
martinp876
auch hier sind die logs interessant.
Wenn ein Kommando kommt einen Level zu setzen (schalter haben bei eq3  die gleichen Level wie dimmer, aber nur 2 Stufen: 0 und 100%)prüft FHEM ob dieser in der Antwort auch erreicht ist. Ist das nicht der Fall kommt diese Meldung: Gewünschter Zustand entspricht nicht dem gemeldeten.
Da einige Devices "zicken" (eQ3 hat einige Varianten in der FW-Verarbeitung) kann ich mir schon vorstellen, dass die Überwachung getunt werden könnte. Dazu braucht es logs.
