Viele Log Einträge mit 1-wire-zu-WLAN-Bridge
Begonnen von Marlen, 28 August 2017, 07:41:52
Marlen
ich habe die 1-wire-zu-WLAN-Bridge vom Hexenmeister.
Die Bridge hab ich mit dem ESPEasy-FHEM-Modul eingebunden.
Jetzt hab ich aber jede Menge Fehler im Log:
2017.08.28 07:38:42 5: ESPEasy Fuehler_Ez: Received: 1_Wire_Bridge_Wohnzimmer_2::192.168.178.52::1::1::1::i||unit||0||0|||i||sleep||0||0|||i||build||20000||0|||i||build_git||||0|||i||build_notes|| - Mega||0|||i||version||2||0|||i||node_type_id||17||0|||r||Temperature||20.5||1
2017.08.28 07:38:42 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220.
2017.08.28 07:38:42 1: stacktrace:
2017.08.28 07:38:42 1:     main::__ANON__                      called by ./FHEM/34_ESPEasy.pm (1220)
2017.08.28 07:38:42 1:     main::ESPEasy_dispatchParse         called by fhem.pl (3629)
2017.08.28 07:38:42 1:     main::Dispatch                      called by ./FHEM/34_ESPEasy.pm (1159)
2017.08.28 07:38:42 1:     main::ESPEasy_dispatch              called by ./FHEM/34_ESPEasy.pm (794)
2017.08.28 07:38:42 1:     main::ESPEasy_Read                  called by fhem.pl (3433)
2017.08.28 07:38:42 1:     main::CallFn                        called by fhem.pl (689)
2017.08.28 07:38:42 2: ESPEasy Fuehler_Ez: Unknown command received via dispatch
2017.08.28 07:38:42 4: ESPEasy Fuehler_Ez: Temperature: 20.5
2017.08.28 07:38:42 5: ESPEasy Fuehler_Ez: Internals: unit:0 sleep:0 build:20000 build_git:not defined build_notes: - Mega version:2 node_type_id:17: ESP Easy Mega
Mein Device ist so definiert:
   CFGFN
   DEF        192.168.178.52 80 espBridge 1_Wire_Bridge_Wohnzimmer_2
   ESP_BUILD  20000
   ESP_BUILD_GIT not defined
   ESP_BUILD_NOTES  - Mega
   ESP_NODE_TYPE_ID 17: ESP Easy Mega
   ESP_SLEEP  0
   ESP_UNIT   0
   ESP_VERSION 2
   HOST       192.168.178.52
   IDENT      1_Wire_Bridge_Wohnzimmer_2
   INTERVAL   300
   IODev      espBridge
   LASTInputDev espBridge
   MSGCNT     5128
   NAME       Fuehler_Ez
   NOTIFYDEV  global
   NR         63210
   NTFY_ORDER 50-ESPEasy_1_Wire_Bridge_Wohnzimmer_2
   PORT       80
   STATE      20.5
   SUBTYPE    device
   TYPE       ESPEasy
   VERSION    1.32
   espBridge_MSGCNT 5128
   espBridge_TIME 2017-08-28 07:40:42
     2017-08-28 07:40:42   Temperature     20.5
     2017-08-28 07:40:37   presence        present
     2017-08-28 07:40:42   state           Tem: 20.5
   helper:
     fpc        1503601619
     pm:
       Encode     1
       JSON       1
     received:
       Temperature 1503898842
   IODev      espBridge
   Interval   300
   group      Wohnzimmer
   presenceCheck 1
   readingSwitchText 1
   room       Heizung
   setState   3
   stateFormat Temperature
   verbose    5
Kann mir hier jemand helfen?
  Marlen
Bartimaus
wie hast Du den Fühler im Modul eingebunden ?
B.
FHEM@AMD-Ryzen7-5825U@Debian-LXC (ProxmoxHOST), CUL1101,FS20,IT,DS18B20,DS2413(Heizungslogger),DS2423(Stromlogger)Homematic,HM-LAN,ZWave,MiniCULs,Shelly
Bartimaus
Soweit ok.
Ich meine es gibt hier zu dem Interface einen Thread, wo andere auch das Problem mit den Logs hatten.
Ich habe es so "gelöst", das ich Verbose auf 1 gesetzt habe.....   ::) 8)
B.
Marlen
Hmmm ja.....wenn es nicht anders geht.
Allerdings hab ich dann immernoch diese Einträge:
2017.08.28 20:29:44 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7732866.
2017.08.28 20:31:44 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7733758.
2017.08.28 20:32:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7734300.
2017.08.28 20:33:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7734794.
2017.08.28 20:35:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7735604.
2017.08.28 20:36:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7736111.
2017.08.28 20:37:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7736639.
2017.08.28 20:39:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7737405.
2017.08.28 20:40:45 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN27> line 1088625.
2017.08.28 20:42:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7738875.
2017.08.28 20:43:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7739198.
2017.08.28 20:44:46 1: PERL WARNING: Use of uninitialized value $reading in substitution (s///) at ./FHEM/34_ESPEasy.pm line 1220, <GEN46> line 7739713.
  Marlen
DerBodo
Bartimaus
B.
Frank_Huber
Oder verbose 0
Gesendet von meinem S3_32 mit Tapatalk
Marlen
