peerlist "aufräumen"
Begonnen von stgeran, 06 September 2017, 19:35:39
stgeran
list Vent_Bad_Sw_01
   DEF        32754101
   NAME       Vent_Bad_Sw_01
   NOTIFYDEV  global
   NR         107
   NTFY_ORDER 50-Vent_Bad_Sw_01
   STATE      off
   TYPE       CUL_HM
   chanNo     01
   device     Vent_Bad
   peerList   2620E903,HM_Wand_SwitchTr,HM_Wand_chn-08,
     2017-09-06 17:32:18   CommandAccepted yes
     2017-09-06 18:53:10   R-2620E903-lgActionType jmpToTarget
     2017-09-06 18:53:10   R-2620E903-shActionType jmpToTarget
     2017-09-06 18:53:11   R-HM_Wand_SwitchTr-lgActionType jmpToTarget
     2017-09-06 18:53:11   R-HM_Wand_SwitchTr-shActionType jmpToTarget
     2017-09-06 18:53:12   R-HM_Wand_chn-08-lgActionType jmpToTarget
     2017-09-06 18:53:12   R-HM_Wand_chn-08-shActionType jmpToTarget
     2017-09-06 18:53:08   R-sign          off
     2017-09-06 19:25:43   RegL_01.         08:00 00:00
     2017-09-06 19:25:44   RegL_03.2620E903  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2017-09-06 19:25:45   RegL_03.HM_Wand_SwitchTr  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2017-09-06 19:25:46   RegL_03.HM_Wand_chn-08  02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:13 0C:33 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:13 8C:33 00:00
     2017-09-06 19:25:49   deviceMsg       off (to VCCU)
     2017-09-06 19:25:49   level           0
     2017-09-06 19:25:49   pct             0
     2017-09-06 19:25:43   peerList        2620E903,HM_Wand_SwitchTr,HM_Wand_chn-08,
     2017-09-06 19:25:49   recentStateType info
     2017-09-06 19:25:49   state           off
     2017-09-06 19:25:49   timedOn         off
     2017-09-06 19:30:40   trigLast        HM_Wand_SwitchTr:0
     2017-09-06 19:30:40   trig_HM_Wand_SwitchTr 0_254
   helper:
     peerIDsRaw ,2620E903,514F9608,514F9607,00000000
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     shadowReg:
     tmpl:
   model      HM-LC-SW2-FM
   peerIDs    00000000,2620E903,514F9607,514F9608,
   room       Bad
   webCmd     statusRequest:toggle:on:off
Die beiden bekomme ich nicht weg 2620E903,HM_Wand_chn-08,
Der erste war mal ein Handsender, den ich gelöscht habe, der Wandthermostat hat nur 7 Kanäle.
Es macht mich madig
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
Der erste geht mit peerBulk der zweite auch mit peerChan.
