Wie peere ich HM-LC-Sw1-DR und HM-LC-SW1-FM?
Begonnen von Olli_aus_LuBu, 03 November 2017, 10:06:44
Olli_aus_LuBu
ich habe einen Stromstoßschalter HM-LC-Sw1-DR an dem drei Tastereingänge angeschlossen sind
   CUL0_868_MSGCNT 127
   CUL0_868_RAWMSG A0DECA4104822B4F1103406010000::-68.5:CUL0_868
   CUL0_868_RSSI -68.5
   CUL0_868_TIME 2017-11-03 09:50:12
   DEF        4822B4
   IODev      CUL0_868
   LASTInputDev CUL0_868
   MSGCNT     127
   NAME       HM_4822B4
   NOTIFYDEV  global
   NR         803
   NTFY_ORDER 50-HM_4822B4
   STATE      off
   TYPE       CUL_HM
   lastMsg    No:EC - t:10 s:4822B4 d:F11034 06010000
   peerList   self01,
   protLastRcv 2017-11-03 09:50:12
   protResnd  2 last_at:2017-11-03 09:31:01
   protSnd    168 last_at:2017-11-03 09:50:12
   protState  CMDs_done
   rssi_at_CUL0_868 cnt:127 avg:-68.5 lst:-68.5 max:-67.5 min:-69.5
     2017-11-03 09:32:39   CommandAccepted yes
     2017-10-29 18:52:44   D-firmware      2.8
     2017-10-29 18:52:44   D-serialNr      NEQ0384184
     2017-11-03 09:32:42   PairedTo        0xF11034
     2017-11-01 16:51:02   R-confBtnTime   permanent
     2017-11-03 09:18:18   R-intKeyVisib   visib
     2017-11-01 16:51:02   R-localResDis   off
     2017-11-01 16:51:02   R-pairCentral   0xF11034
     2017-11-01 16:51:03   R-powerUpAction off
     2017-11-03 09:18:20   R-self01-lgActionType jmpToTarget
     2017-11-03 09:18:20   R-self01-lgCtDlyOff geLo
     2017-11-03 09:18:20   R-self01-lgCtDlyOn geLo
     2017-11-03 09:18:20   R-self01-lgCtOff geLo
     2017-11-03 09:18:20   R-self01-lgCtOn geLo
     2017-11-03 09:18:20   R-self01-lgCtValHi 100
     2017-11-03 09:18:20   R-self01-lgCtValLo 50
     2017-11-03 09:18:20   R-self01-lgMultiExec on
     2017-11-03 09:18:20   R-self01-lgOffDly 0 s
     2017-11-03 09:18:20   R-self01-lgOffTime unused
     2017-11-03 09:18:20   R-self01-lgOffTimeMode absolut
     2017-11-03 09:18:20   R-self01-lgOnDly 0 s
     2017-11-03 09:18:20   R-self01-lgOnTime unused
     2017-11-03 09:18:20   R-self01-lgOnTimeMode absolut
     2017-11-03 09:18:20   R-self01-lgSwJtDlyOff off
     2017-11-03 09:18:20   R-self01-lgSwJtDlyOn on
     2017-11-03 09:18:20   R-self01-lgSwJtOff dlyOn
     2017-11-03 09:18:20   R-self01-lgSwJtOn dlyOff
     2017-11-03 09:18:20   R-self01-shActionType jmpToTarget
     2017-11-03 09:18:20   R-self01-shCtDlyOff geLo
     2017-11-03 09:18:20   R-self01-shCtDlyOn geLo
     2017-11-03 09:18:20   R-self01-shCtOff geLo
     2017-11-03 09:18:20   R-self01-shCtOn geLo
     2017-11-03 09:18:20   R-self01-shCtValHi 100
     2017-11-03 09:18:20   R-self01-shCtValLo 50
     2017-11-03 09:18:20   R-self01-shMultiExec off
     2017-11-03 09:18:20   R-self01-shOffDly 0 s
     2017-11-03 09:18:20   R-self01-shOffTime unused
     2017-11-03 09:18:20   R-self01-shOffTimeMode absolut
     2017-11-03 09:18:20   R-self01-shOnDly 0 s
     2017-11-03 09:18:20   R-self01-shOnTime unused
     2017-11-03 09:18:20   R-self01-shOnTimeMode absolut
     2017-11-03 09:18:20   R-self01-shSwJtDlyOff off
     2017-11-03 09:18:20   R-self01-shSwJtDlyOn on
     2017-11-03 09:18:20   R-self01-shSwJtOff dlyOn
     2017-11-03 09:18:20   R-self01-shSwJtOn dlyOff
     2017-11-01 16:51:03   R-sign          off
     2017-11-03 09:32:43   R-statusInfoMinDly 1 s
     2017-11-03 09:32:43   R-statusInfoRandom 0 s
     2017-11-01 16:51:03   R-transmitTryMax 6
     2017-11-03 09:50:12   deviceMsg       off (to CUL0_868)
     2017-11-03 09:50:12   level           0
     2017-11-03 09:50:12   pct             0
     2017-11-03 09:32:43   peerList        self01,
     2017-10-29 18:52:31   powerOn         2017-10-29 18:52:31
     2017-11-03 09:50:12   recentStateType info
     2017-11-03 09:50:12   state           off
     2017-11-03 09:50:12   timedOn         off
   helper:
     HM_CMDNR   236
     cSnd       01F110344822B40103,01F110344822B401044822B40103
     mId        00F0
     peerIDsRaw ,4822B401,00000000
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        1
       raw        0
       tpl        0
     io:
       newChn     +4822B4,00,00,00
       nextSend   1509699012.19809
       prefIO
       rxt        0
       vccu
       p:
         4822B4
         00
         00
         00
     mRssi:
       mNo        EC
       io:
         CUL0_868   -66.5
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         CUL0_868
       flg        A
       ts         1509699012.10266
       ack:
         HASH(0x27a9b80)
         EC8002F110344822B400
     rssi:
       at_CUL0_868:
         avg        -68.507874015748
         cnt        127
         lst        -68.5
         max        -67.5
         min        -69.5
     shadowReg:
     tmpl:
   IODev      CUL0_868
   alias      swLichtSchlafzimmer
   autoReadReg 3_onChange
   expert     1_allReg
   firmware   2.8
   model      HM-LC-Sw1-DR
   peerIDs    00000000,4822B401,
   room       CUL_HM,Homekit,Schlafzimmer
   serialNr   NEQ0384184
   subType    switch
   webCmd     statusRequest:toggle:on:off
und einen Unterputz-Schaltaktuator HM-LC-SW1-FM  an dem eine Lampe hängt
   CUL0_868_MSGCNT 62
   CUL0_868_RAWMSG A0C36A010579246F11034030000::-75.5:CUL0_868
   CUL0_868_RSSI -75.5
   CUL0_868_TIME 2017-11-03 10:00:46
   DEF        579246
   IODev      CUL0_868
   MSGCNT     62
   NAME       soSchlafzimmer
   NOTIFYDEV  global
   NR         809
   NTFY_ORDER 50-soSchlafzimmer
   STATE      off
   TYPE       CUL_HM
   lastMsg    No:36 - t:10 s:579246 d:F11034 030000
   peerList   self01,
   protLastRcv 2017-11-03 10:00:45
   protResnd  1 last_at:2017-11-03 09:32:01
   protSnd    81 last_at:2017-11-03 10:00:46
   protState  CMDs_done
   rssi_CUL0_868 cnt:17 avg:-81.7 lst:-81 max:-79 min:-84
   rssi_at_CUL0_868 lst:-75.5 max:-75 min:-86 avg:-78.22 cnt:62
     2017-11-03 10:00:04   CommandAccepted yes
     2017-10-30 15:58:20   D-firmware      2.8
     2017-10-30 15:58:20   D-serialNr      OEQ0378998
     2017-11-03 10:00:44   PairedTo        0xF11034
     2017-11-03 09:08:19   R-pairCentral   0xF11034
     2017-11-03 09:08:20   R-powerUpAction off
     2017-11-03 10:00:12   R-self01-lgActionType jmpToTarget
     2017-11-03 10:00:12   R-self01-shActionType jmpToTarget
     2017-11-03 09:08:20   R-sign          off
     2017-11-03 10:00:44   RegL_00.          02:81 0A:F1 0B:10 0C:34 15:FF 18:00 00:00
     2017-11-03 10:00:44   RegL_01.         08:00  30:06 57:24 56:00 00:00
     2017-11-03 10:00:45   RegL_03.self01   02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:63 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2017-11-03 10:00:45   peerList        self01,
     2017-10-30 16:09:06   powerOn         2017-10-30 16:09:06
     2017-11-03 09:50:12   recentStateType ack
   helper:
     HM_CMDNR   54
     cSnd       01F110345792460103,01F1103457924601045792460103
     dlvlCmd    ++A011F110345792460201000000
     mId        0004
     peerIDsRaw ,57924601,00000000
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +579246,00,00,00
       nextSend   1509699646.04861
       prefIO
       rxt        0
       vccu
       p:
         579246
         00
         00
         00
     mRssi:
       mNo        36
       io:
         CUL0_868   -73.5
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         CUL0_868
       flg        A
       ts         1509699645.96661
       ack:
         HASH(0x27aada0)
         368002F1103457924600
     rssi:
       CUL0_868:
         avg        -81.7058823529412
         cnt        17
         lst        -81
         max        -79
         min        -84
       at_CUL0_868:
         avg        -78.2258064516129
         cnt        62
         lst        -75.5
         max        -75
         min        -86
     shadowReg:
     tmpl:
   IODev      CUL0_868
   alias      soSchlafzimmer
   expert     2_raw
   firmware   2.8
   model      HM-LC-SW1-FM
   peerIDs    00000000,57924601,
   room       CUL_HM,Schlafzimmer
   serialNr   OEQ0378998
   subType    switch
in FHEM eingebunden.
Über das folgende notify habe ich die beiden verbunden:
   DEF        HM_4822B4:(on|off) set soSchlafzimmer $EVENT
   NAME       ntfySchlafzimmerlicht
   NR         808
   NTFY_ORDER 50-ntfySchlafzimmerlicht
   REGEXP     HM_4822B4:(on|off)
   STATE      2017-11-03 09:50:12
   TYPE       notify
Das funktioniert auch soweit nur leider mit einer Verzögerung von etwa einer Sekunde.
Mit statusInfoMinDly habe ich auch schon experimentiert, doch wenn ich es auf 0 (unused) setze habe ich keine Reaktion mehr auf einen Tastendruck.
Ich denke ich muss diese beiden Devices jetzt peeren, aber auf diesem Gebiet bin ich ziemlich neu. Ich habe mir die Anleitung die auf dem Wiki und um Forum vorliegen mehrfach durchgelesen, werde aber trotzdem nicht schlau draus.
Kann mir hier jemand helfen wie ich diese beiden Devices peere damit sie direkt miteinander kommunizieren und ich somit kein Delay mehr zwischen Tastenbetätigung am Stromstoßschalter und Lampenreaktion am Unterputschalter erhalte?
Vielen Dank!
Oliver
CoolTux
#1
set HM_4822B4 peerChan 0 soSchlafzimmer dual set
Bilde mir ein das es so passen sollte
Das TuxNet Wiki:
https://www.cooltux.net
Pfriemler
#2
Nein. Man kann nicht zwei Aktoren peeren.
Der -DR hat zwar quasi eine (oder beliebig viele parallele) Taste, deren Betätigung wird aber nach außen nicht sichtbar per Funk. Nur eine Reaktion auf den geänderten Schaltzustand ist möglich, wie bereits geschehen.
Die Denksekunde wäre nur mit zusätzlicher Hardware zu eliminieren.
rabehd
Sehe ich auch so.
Du müsstest Deine 3 Taster (parallel ?)  durch z.B. HM-PB-2-WM55-2 ersetzen.
Dann kannst Du die HM-PB-2-WM55-2 mit den beiden Aktoren peeren.
Ich hoffe mal der  HM-LC-Sw1-DR kann gepeert werden.
Pfriemler
Logisch kann der gepeert werden. Wäre sonst reichlich nutzlos als Standalone-Aktor mit Statusfunk  ;D
Ich hätte eigentlich eher an einen Schaltdosenkeks PB4, zur Not auch SCI-3, gedacht. Hängt dann von den Leitungslängen ab. Umbau auf Stromlos erforderlich. Aber die Bedienhaptik und -optik bliebe.
Verflucht sei der Tag, an dem man bei eq3 entschied, den Aktoren lokale bedienbare Tasten beizugeben, deren Betätigung nicht per Funk gemeldet wird. Tausende User wären glücklicher. Aber die Knete (in Form zusätzlich verkaufter Hardware) is eben wichtiger...
rabehd
@Pfriemler
ZitatIch hoffe mal der  HM-LC-Sw1-DR kann gepeert werden.
Ich habe es zwar vermutet, aber für den Fall das eq3 da wieder einen Sonderfall hat...
Nicht das jemand sich Hardware kauft ohne vorher mal die Dokumentation gelesen zu haben und ich bin dann schuld.
papa
Naja ... so langsam können wir da was gegen machen. Zumindest wenn die Hardware halbwegs passt.
Pfriemler
Ich querlese die Entwicklung schon länger mit wachsender Hochachtung - auch wenn die bestehenden Probleme das Stadium noch (!) aufzeigen. Dabei wäre es ein leichtes gewesen, das vom Design ab Werk vorzusehen. Wohl auch aus dem Grund gibt es bisher immer noch kein 4-/4-Kanalmodul als HM-MOD-ER-8 - vier Sensoren, vier Aktoren. Könnte man sogar als 8/8 bauen. Das wäre der Knaller.
Gemischte Geräte gibt es ja durchaus: Der Regensensor sendet Daten als Sensor und besitzt einen separat schaltbaren Aktorkanal für die Heizung.
Olli_aus_LuBu
danke an alle für die schnellen Antworten!!!
Dann werde ich es wohl oder übel so belassen. Aber die Schalter tauschen oder alles auf stromlos umbauen möchte ich nicht.
Oliver
