Anlernen von Funkkomponenten schlägt fehl
Begonnen von wendeling, 23 November 2017, 13:41:10
wendeling
ich bin fast am Verzweifeln. Aktuell benutze ich HM-Wired , Funk Bewegungsmelder und Funk Temperaturmesser.
Alles läuft prima.
Folgende Sender sind installiert:
CUL_0
defmod CUL_0 CUL /dev/ttyACM0@38400 1234
attr CUL_0 alias CUL_868
attr CUL_0 group CUL
attr CUL_0 hmProtocolEvents 1_dump
attr CUL_0 model CUL
attr CUL_0 rfmode HomeMatic
attr CUL_0 room Z_CUL
setstate CUL_0 2017-11-23 09:47:07 cmds  B b C F i A Z N k G M K U Y R T V W X e f m L l t u x
setstate CUL_0 2017-11-23 13:33:27 state Initialized
HMWLAN1
defmod HMLAN1 HMLAN 192.168.113.9:1000
attr HMLAN1 group CUL
attr HMLAN1 hmId 200DB8
attr HMLAN1 hmLanQlen 1_min
attr HMLAN1 loadLevel 0:low,40:batchLevel,90:high,99:suspended
attr HMLAN1 room Z_CUL
attr HMLAN1 verbose 5
setstate HMLAN1 opened
setstate HMLAN1 2017-11-14 21:52:12 D-HMIdAssigned 200DB8
setstate HMLAN1 2017-11-14 21:52:12 D-HMIdOriginal 272D21
setstate HMLAN1 2017-11-14 21:52:12 D-firmware 0.964
setstate HMLAN1 2017-11-14 21:52:12 D-serialNr LEQ0049740
setstate HMLAN1 2017-11-23 04:01:38 Xmit-Events init:58 disconnected:69 ok:58
setstate HMLAN1 2017-11-23 04:01:38 cond ok
setstate HMLAN1 2017-11-23 13:33:53 loadLvl low
setstate HMLAN1 2017-11-23 03:59:28 prot_disconnected last
setstate HMLAN1 2017-11-23 04:01:38 prot_init last
setstate HMLAN1 2017-11-23 03:42:08 prot_keepAlive last
setstate HMLAN1 2017-11-23 04:01:38 prot_ok last
setstate HMLAN1 2017-11-23 04:01:38 state opened
jetzt möchte ich einen  HM-MOD-Em-8
defmod HM_4E46B7 CUL_HM 4E46B7
attr HM_4E46B7 IODev CUL_0
attr HM_4E46B7 autoReadReg 4_reqStatus
attr HM_4E46B7 expert 2_raw
attr HM_4E46B7 firmware 1.2
attr HM_4E46B7 model HM-MOD-Re-8
attr HM_4E46B7 msgRepeat 1
attr HM_4E46B7 room CUL_HM
attr HM_4E46B7 serialNr NEQ0958915
attr HM_4E46B7 subType switch
attr HM_4E46B7 webCmd getConfig:clear msgEvents
setstate HM_4E46B7 RESPONSE TIMEOUT:RegisterRead
setstate HM_4E46B7 2017-11-23 09:48:31 .D-devInfo 480200
setstate HM_4E46B7 2017-11-23 09:48:31 .D-stc 10
setstate HM_4E46B7 2017-11-23 09:45:29 .R-intKeyVisib invisib
setstate HM_4E46B7 2017-11-23 09:45:29 .R-ledMode off
setstate HM_4E46B7 2017-11-23 09:48:42 .protLastRcv 2017-11-23 09:48:42
setstate HM_4E46B7 2017-11-23 09:48:31 D-firmware 1.2
setstate HM_4E46B7 2017-11-23 09:48:31 D-serialNr NEQ0958915
setstate HM_4E46B7 2017-11-23 09:45:29 PairedTo 0x000000
setstate HM_4E46B7 2017-11-23 09:45:29 R-pairCentral 0x000000
setstate HM_4E46B7 2017-11-23 10:41:22 RegL_00.
setstate HM_4E46B7 2017-11-23 09:47:49 level 0
setstate HM_4E46B7 2017-11-23 09:47:49 pct 0
setstate HM_4E46B7 2017-11-23 09:47:49 powerOn 2017-11-23 09:47:49
setstate HM_4E46B7 2017-11-23 09:47:49 recentStateType info
setstate HM_4E46B7 2017-11-23 09:48:14 sabotageAttackId_ErrIoId_F10000  cnt:9
setstate HM_4E46B7 2017-11-23 09:48:05 state RESPONSE TIMEOUT:RegisterRead
setstate HM_4E46B7 2017-11-23 09:47:49 timedOn off
oder auch HM-LC-SW4-DR
defmod HM_545D4B CUL_HM 545D4B
attr HM_545D4B IODev CUL_0
attr HM_545D4B autoReadReg 4_reqStatus
attr HM_545D4B expert 2_raw
attr HM_545D4B firmware 2.8
attr HM_545D4B model HM-LC-SW4-DR
attr HM_545D4B room CUL_HM
attr HM_545D4B serialNr OEQ0090099
attr HM_545D4B subType switch
attr HM_545D4B webCmd getConfig:clear msgEvents
setstate HM_545D4B RESPONSE TIMEOUT:RegisterRead
setstate HM_545D4B 2017-11-23 13:36:21 .D-devInfo 040100
setstate HM_545D4B 2017-11-23 13:36:21 .D-stc 10
setstate HM_545D4B 2017-11-23 13:36:20 .protLastRcv 2017-11-23 13:36:20
setstate HM_545D4B 2017-11-23 13:36:21 D-firmware 2.8
setstate HM_545D4B 2017-11-23 13:36:21 D-serialNr OEQ0090099
setstate HM_545D4B 2017-11-23 13:38:49 RegL_00.
setstate HM_545D4B 2017-11-23 13:38:37 state RESPONSE TIMEOUT:RegisterRead
ich bekomme jedoch zu beiden Geräten keine richtige Verbindung!
Wer kann mir hier helfen ?
Auch ja habe auch noch einen  HM-MOD-Sm-8 der auch ohne Probleme läuft
Hallo wendeling,
da du zwei HM-IO's (oder mehr, da ist von einem maxcube die Rede?!?) nutzen willst, stellt sich mir die Frage, warum du keine VCCU einrichtest (siehe Wiki zu VCCU).
Das solltest Du zuerst machen, wobei du dafür ohne weiteres eine der beiden HmIDs weiter nutzen kannst (würde die vom HMLAN1 nehmen bzw. die, mit der bereits Devices gepairt sind, ansonsten bitte erst die mit einer anderen HmID erst wieder entpairen, damit das hinterher einheitlich geht). Dann die IOGrp der bereits gepairten Devices darauf anpassen.
Dann sollten weitere Devices ohne weiteres mit der VCCU zu pairen sein, es sei denn, AES wäre erforderlich (erfordert für CUL&Co ein perl-Modul).
Und warum der CUL_0 nicht gleich ein rename auf CUL_868 bekommt, verstehe ich btw. auch nicht so richtig...
Gruß, Beta-User
wendeling
Das mit dem maxcube war nur ein Versuch !
der ist nicht aktiv. Habe ich jetzt auf CUL_0 geändert . Läuft auch
Bitte unterlasse solche "Verbesserungen" in vorherigen Posts, bei denen hinterher niemand mehr nachvollziehen kann, worauf sich die späteren Beiträge beziehen >:( .
Ansonsten hoffe, ich, du liest erst mal fleisig zu VCCU?!?
Mit welcher HmID ist denn der HM-MOD-Sm-8 gepaired?
Und welche Devices genau betrifft "Läuft auch"? (neben dem HM-MOD-Sm-8 auch der HM-MOD-Em-8, der urspünlich den maxcube als IO hatte?)
