andFHEM and Fritzbox 7390
Begonnen von Guest, 17 Juni 2012, 17:23:03
Guest
Hi
I try to use andFHEM on my smartphone and FHEM on my Fritzbox 7390.
First of all, I can make a telnet connection but have to make telnet in
fhem settings global.  Does this mean everybody knowing my IP address can
start it? The more as it seems I don't have to enter a password.  It seems
I don't have to make telnet available on my Fritzbox for it!?
I was not able to use FHEMWEB on port 8083, 8084 or 8085 for the connection
between  andFHEM and  my Fritzbox. Is this normal or do I something wrong?
Thanks for your work and answers.
{HT}
Guest
Am Sonntag, 17. Juni 2012 17:23:03 UTC+2 schrieb dudler:
> Hi
Fritzbox Telnet is not equal to FHEM's telnet. This port is not yet secured
by a password, Rudi is currently changing this. And yes, the port has to be
global.
> connection between  andFHEM and  my Fritzbox. Is this normal or do I
> something wrong?
This should work without a problem. Usually, use FHEMWEB on port 8083. You
have to give us some more information - there is no way telling you what
you are doing wrong currently.
> {HT}
Matthias
Guest
Thanks for the quick answer.
> > something wrong?
I selected
Datasource:  FHEMWEB
URL: 192.168.178.1:8083/fhem
Username:
Password:
Then I get "Cannot connect to host.¨  when I push refresh. Used from
my laptop that address works without a problem.
I suspect having this connection from my smartphone and my computer at
the same time is not the problem.
This helps?
{HT}
Guest
can you access the URL from your smartphone browser?
Matthias
Am Sonntag, 17. Juni 2012 23:00:52 UTC+2 schrieb dudler:
> > > something wrong?
> You
> I selected
> Datasource:  FHEMWEB
> Username:
> Password:
> This helps?
> {HT}
Guest
Is the notebook connected via WLAN or via LAN Cable?
You have to allow WLAN device to communicate to each other.
CU
Sven
On 18 Jun., 09:12, Matthias wrote:
> Hi,
> Matthias
> > > > something wrong?
> > You
> > I selected
> > Datasource:  FHEMWEB
> > Username:
> > Password:
> > This helps?
> > {HT}
Guest
Yes, that works without a problem.
{HT}
On 18 jun, 09:12, Matthias wrote:
> Hi,
> Matthias
> > > > something wrong?
> > You
> > I selected
> > Datasource:  FHEMWEB
> > Username:
> > Password:
> > This helps?
> > {HT}
Guest
Hi Sven
Via WLAN and I checked, the devices are allowed to communicate with
each other.
Thanx for any hint, but just for my understanding, I have FHEM on my
Fritzbox so I guess it is not necessary to allow devices to
communicate with each other?
{HT}
> CU
> Sven
> > Hi,
> > Matthias
> > > > > something wrong?
> > > You
> > > I selected
> > > Datasource:  FHEMWEB
> > > Username:
> > > Password:
> > > This helps?
> > > {HT}
Guest
But only from the browser not with andFHEM
{HT}
Guest
OK just for the completeness - what is andFHEM actually telling you? Does
it tell 'cannot read xml list' or does it tell 'cannot connect to fhem' ?
What have you entered as connection parameters in andFHEM?
Matthias
Am Dienstag, 19. Juni 2012 12:19:15 UTC+2 schrieb dudler:
> {HT}
Guest
I just updated to 1.6.9
It tells me "Cannot connect to host" NOT fhem.
My parameters are:
Datasource:  FHEMWEB
Username:
Password:
When I select telnet it works.
When I use 192.168.178.1:8083/fhem from the browser on the same
smartphone it also works.
{HT}
Guest
I suppose you are missing an http:// in front of the FHEMWEB URL.
Matthias
Am Mittwoch, 20. Juni 2012 14:01:17 UTC+2 schrieb dudler:
> My parameters are:
> Datasource:  FHEMWEB
> Username:
> Password:
> {HT}
Guest
Hi
:-(  I feel very stupide.  But you are right. To much used to the fact
that you don't have to enter it in a browser.
Thanx
{HT}
On 20 jun, 14:09, Matthias wrote:
> Hi,
> Matthias
> > My parameters are:
> > Datasource:  FHEMWEB
> > Username:
> > Password:
> > {HT}
Guest
Ok great. Some time I thought about automatically adding it. However, this
might become difficult in finding out whether https:// or http:// has to be
prefixed ...
Matthias
Am Mittwoch, 20. Juni 2012 16:48:38 UTC+2 schrieb dudler:
> Hi
> Thanx
> {HT}
> > Hi,
> > Matthias
> > > My parameters are:
> > > Datasource:  FHEMWEB
> > > Username:
> > > Password:
> > > {HT}
Guest
Hi
Maybe a check and a warning if neither  https:// nor http:// is used
is possible. Seems not to difficult and could help people.
{HT}
> prefixed ...
> Matthias
> > Hi
> > Thanx
> > {HT}
> > > Hi,
> > > Matthias
> > > > My parameters are:
> > > > Datasource:  FHEMWEB
> > > > Username:
> > > > Password:
> > > > {HT}
