Nicht identifizierbare Einträge in der LOG Datei
Begonnen von Guest, 08 Juli 2012, 14:46:50
Guest
Seit geraumer Zeit finde ich folgende Einträge in der LOG Datei.
Was hat es damit auf sich? Habe ich etwas verpasst?
Gruß Klaus
FHEM Neustart
2012.07.08 14:28:53 0: Server shutdown
2012.07.08 14:28:55 1: Including /etc/fhem.cfg
2012.07.08 14:28:56 3: WEB: port 8083 opened
2012.07.08 14:28:56 3: WEBS: port 8084 opened
2012.07.08 14:28:56 3: Opening CUL device /dev/ttyACM0
2012.07.08 14:28:56 3: CUL device openedUse of implicit split to @_ is deprecated at /usr/share/fhem/FHEM/95_FLOORPLAN.pm line 410, <$fh> line 76.
2012.07.08 14:28:57 1: OWX: Serial device /dev/ttyUSB0 defined
2012.07.08 14:28:57 1: OWX: 1-Wire bus master DS2480 re-detectedUse of uninitialized value $text in concatenation (.) or string at /usr/bin/fhem.pl line 533, <$fh> line 118.
2012.07.08 14:28:57 3: OWID:   Device OWID defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_Gartenhaus defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_Dach defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_Garage defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_Wasser defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_Zirko defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_F_Heizung_.V defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_F_Heizung_R defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_K_Heizung_.V defined.
2012.07.08 14:28:57 3: OWTHERM: Device 1W.T_K_Heizung_R defined.
2012.07.08 14:28:57 3: OWCOUNT:   Device Zaehler defined.
2012.07.08 14:28:57 3: OWSWITCH:   Device IO defined.
2012.07.08 14:29:00 3: telnetPort: port 7072 opened
2012.07.08 14:29:00 1: Including /var/log/fhem/fhem.saveUse of uninitialized value in concatenation (.) or string at /usr/bin/fhem.pl line 388.
2012.07.08 14:29:00 0: Server started (version , pid 10800)
2012.07.08 14:29:17 1: OWX: Warning, IO is defined with improper family id 1D, correcting to 3A
2012.07.08 14:29:17 1: OWX: 1-Wire devices found (1W.T_F_Heizung_R,1W.T_Zirko,1W.T_Garage,1W.T_Gartenhaus,1W.T_Dach,1W.T_K_Heizung_.V,1W.T_F_Heizung_.V,1W.T_Wasser,1W.T_K_Heizung_R,IO,OWID,Zaehler)
2012.07.08 14:33:14 2: dummy set D_Kaffeemaschine offUse of uninitialized value in numeric ne (!=) at (eval 26) line 1.
Aufruf von Floorplan
Use of uninitialized value $_ in split at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 68.
Use of uninitialized value $cssTitle in substitution (s///) at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 70.
Use of uninitialized value $cssTitle in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
Use of uninitialized value $title in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
Use of uninitialized value $value in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
UliM
generell bei 'uninitialized value': perlbeschwert sich, dass eine verwendete Variable noch nicht befüllt wurde - und macht weiter, als hätte die Variable den Wert 'leer' oder 'null'.
Könnte man im code verbessern, es funktioniert aber auch so.
Also einfach ignorieren - es sei denn, Du stellst einen Verlust an Funktionalität fest, dann als bug melden.
Gruß Uli
UliM
Gruß Uli
