[Gelöst]HM-LC-Dim1TPBU-FM; state: chn:on phys:0
Begonnen von Gueco315, 13 Januar 2018, 10:45:22
Gueco315
der List sieht wie folgt aus:
[/Internals:
   CUL_1_MSGCNT 50
   CUL_1_RAWMSG A0F57800218A909FF23450101C8004F00::-78.5:CUL_1
   CUL_1_RSSI -78.5
   CUL_1_TIME 2018-01-13 10:20:59
   DEF        18A909
   IODev      CUL_1
   LASTInputDev CUL_1
   MSGCNT     50
   NAME       wz_erker
   NOTIFYDEV  global
   NR         2096
   NTFY_ORDER 50-wz_erker
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 wz_erkerlampe
   channel_02 wz_erker_Dim_V_01
   channel_03 wz_erker_Dim_V_02
   lastMsg    No:57 - t:02 s:18A909 d:FF2345 0101C8004F00
   protLastRcv 2018-01-13 10:20:59
   protResnd  5 last_at:2018-01-13 10:19:10
   protSnd    57 last_at:2018-01-13 10:20:59
   protState  CMDs_done
   rssi_CUL_1 min:-98 lst:-79 cnt:15 max:-75 avg:-87.13
   rssi_at_CUL_1 cnt:50 min:-100 lst:-78.5 avg:-82.76 max:-72.5
     2018-01-11 16:41:44   CommandAccepted yes
     2018-01-11 16:50:10   D-firmware      2.9
     2018-01-11 16:50:10   D-serialNr      IEQ0544868
     2018-01-13 10:12:12   PairedTo        0xFF2345
     2018-01-11 16:42:28   R-pairCentral   0xFF2345
     2018-01-13 10:12:12   RegL_00.          02:01 0A:FF 0B:23 0C:45 15:FF 18:00 00:00
     2018-01-11 16:44:46   deviceMsg       off (to VCCU)
     2018-01-11 16:44:46   dim             stop:off
     2018-01-11 16:44:46   level           0
     2018-01-11 16:44:46   overheat        off
     2018-01-11 16:44:46   overload        off
     2018-01-11 16:44:46   pct             0
     2018-01-11 16:45:52   phyLevel        0
     2018-01-13 09:43:29   powerOn         2018-01-13 09:43:29
     2018-01-11 16:44:46   recentStateType info
     2018-01-11 16:44:46   reduced         off
     2018-01-13 10:20:59   state           CMDs_done
     2018-01-11 16:44:46   timedOn         off
   helper:
     HM_CMDNR   87
     PONtest    0
     cSnd       11FF234518A9090201000000,11FF234518A9090201C80000
     mId        0068
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +18A909,00,00,00
       nextSend   1515835259.49931
       prefIO
       rxt        0
       vccu
       p:
         18A909
         00
         00
         00
     mRssi:
       mNo        57
       io:
         CUL_1      -76.5
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat   01
     role:
       dev        1
       prs        1
     rssi:
       CUL_1:
         avg        -87.1333333333333
         cnt        15
         lst        -79
         max        -75
         min        -98
       at_CUL_1:
         avg        -82.76
         cnt        50
         lst        -78.5
         max        -72.5
         min        -100
     shadowReg:
     tmpl:
   IODev      CUL_1
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.9
   model      HM-LC-Dim1TPBU-FM
   room       CUL_HM
   serialNr   IEQ0544868
   subType    dimmer
   webCmd     getConfig:clear msgEvents
code]
Über den 1. Kanal
[code]
schalte ich, was auch funktioniert. Nur bleibt der State bei chn:on phys:0
Hätte hier ein on erwartet, bei off ist alles okay.
Wie bekomme ich das auf on und off reduziert?
Gruß Günter
Fhem 6.0, JeeLink, CUL 868 auf Raspi 4, Buster, IT-1500, 4x SB_Player, Squeezebox auf Raspi 4, 3x Fritzbox,  WIFI Light, EGPM2LAN, ENIGMA, Sec-SCO,CC-RT-DN,TC-IT-WM-W-EU,SEN-Wa-Od,ES-PMSw1-PW,HM-SE, Sonoff, Shelly,SMA
Hallo Günter,
das ist normalerweise ein Übergangszustand. Das hier ist nicht so toll -> protResnd  5 last_at:2018-01-13 10:19:10
Du hast einen CUL als IO?
Ich vermute es gehen Nachrichten verloren, der CUL arbeitet nicht exklusiv für Homematic, es liegt an der Firmware des CUL was auch immer.
Also nur als Forschungsansatz.
Gueco315
Hallo Otto,
ich habe eine CUL-Stick im Einsatz ..
Gruß Günter
#3
Du kannst Dir das im Eventmonitor gut anschauen, so ist bei mir eine komplette Folge für an. Wie man sieht ist der finale Status etwas verzögert. Der geht bei Dir eventuell verloren,
nehme ich an.2018-01-13 11:43:51 CUL_HM LichtWzR CMDs_pending
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw level: set_60
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw set_60
2018-01-13 11:43:51 CUL_HM LichtWzR CMDs_done
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw deviceMsg: 0.5 (to VCCU)
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw dim: up:0.5
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw level: 0.5
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw overheat: off
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw overload: off
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw pct: 0.5
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw reduced: off
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw chn:0.5 phys:0
2018-01-13 11:43:51 CUL_HM LichtWzR_Sw timedOn: off
2018-01-13 11:43:56 CUL_HM LichtWzR CMDs_done
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw deviceMsg: on (to VCCU)
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw dim: stop:on
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw level: on
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw overheat: off
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw overload: off
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw pct: on
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw phyLevel: on
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw reduced: off
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw on
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw timedOn: off
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw1_V_01 phyLevel: 60
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw1_V_01 chn:off  phys:60
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw1_V_02 phyLevel: 60
2018-01-13 11:43:56 CUL_HM LichtWzR_Sw1_V_02 chn:off  phys:60
Gueco315
Guter Hinweis!
2018-01-13 12:49:39 CUL_HM wz_erker CMDs_pending
2018-01-13 12:49:39 CUL_HM wz_erkerlampe set_on
2018-01-13 12:49:39 CUL_HM wz_erker CMDs_done
2018-01-13 12:49:39 CUL_HM wz_erkerlampe chn:on phys:30
Scheinbar ist da beim Aktor-Pairing was nicht rund gelaufen .....
Hier mal das List:
   CUL_1_MSGCNT 17
   CUL_1_RAWMSG A0FD5800218A909FF23450101C8004800::-72.5:CUL_1
   CUL_1_RSSI -72.5
   CUL_1_TIME 2018-01-13 12:49:39
   DEF        18A909
   IODev      CUL_1
   LASTInputDev CUL_1
   MSGCNT     17
   NAME       wz_erker
   NOTIFYDEV  global
   NR         2096
   STATE      CMDs_done
   TYPE       CUL_HM
   lastMsg    No:D5 - t:02 s:18A909 d:FF2345 0101C8004800
   protLastRcv 2018-01-13 12:49:39
   protResnd  1 last_at:2018-01-13 11:33:20
   protSnd    17 last_at:2018-01-13 12:49:39
   protState  CMDs_done
   rssi_CUL_1 avg:-74.46 max:-72 min:-79 cnt:15 lst:-72
   rssi_at_CUL_1 min:-77.5 avg:-74.99 max:-71.5 cnt:17 lst:-72.5
     2018-01-13 11:19:52   PairedTo        0xFF2345
     2018-01-13 11:19:51   RegL_00.        02:01 0A:FF 0B:23 0C:45 15:FF 18:00 A6:A6 00:00
     2018-01-13 11:30:32   phyLevel        30
     2018-01-13 12:49:39   state           CMDs_done
   helper:
     HM_CMDNR   213
     mId        0068
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       nextSend   1515844179.69434
       prefIO
       rxt        0
       vccu
       p:
         18A909
         00
         00
         00
     mRssi:
       mNo        D5
       io:
         CUL_1      -70.5
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat   01
     role:
       dev        1
       prs        1
     rssi:
       CUL_1:
         avg        -74.4666666666667
         cnt        15
         lst        -72
         max        -72
         min        -79
       at_CUL_1:
         avg        -75
         cnt        17
         lst        -72.5
         max        -71.5
         min        -77.5
     tmpl:
     vDim:
       idPhy      18A90901
   IODev      CUL_1
   expert     2_raw
   firmware   2.9
   room       CUL_HM
   serialNr   IEQ0544868
   subType    dimmer
#5
Nein das Pairing war vorhin schon ok
Aber die Kommunikation läuft irgendwie schlecht protResnd  1 last_at:2018-01-13 11:33:20
Was ist, wenn Du einen Statusrequest extra absetzt?
Es wird wohl am CUL liegen ... Hat der die TS Firmware? Sieh auch hier -> https://wiki.fhem.de/wiki/HomeMatic#FHEM_als_Zentrale
Gueco315
Hallo Otto,
ja das habe ich jetzt auch festgestellt, mit einem statusRequest ist alles fein!
Gruß Günter
Gueco315
Otto, wie komme ich an die TS-FW und dann wie installiert?
Dem Link in meinem Link bist Du nicht gefolgt?
isy
#9
Das mit dem STATE ist bei mir auch so.
Mit HM-MOD-RPI-PCB
Liegt also nicht unbedingt am CUL.
Bestätige das Verhalten mit dem statusRequest.
Kam drauf, da ich zum Ein- und Ausschalten einen Dash Button verwende. Der geht nur ein mal, weil der Status nicht voll auf off geht, erst nach dem statusRequest eben.
Gruß Helmut
Ein Weg wird erst zu einem Weg, wenn man ihn geht
Gueco315
danke euch für die Unterstützung. Ja das mit dem State ist ein Einzelfall und tritt exakt nur bei diesem Dimmer auf.
Habe es jetzt so gelöste, dass ich per Notify nach 2 Sekunden eine statusRequest auslöse, dann ist der state auch wieder fein.
Gruß Günter
