fhem and Freetz on FB7390
Begonnen von Guest, 08 August 2012, 22:58:10
Guest
Hi
I am currently trying things with Freetz. For this I often create a new
image and install this. Now fhem is no longer started at startup of my
fb7390. Is there an easy way to have it started again?
Off course I can save my files, reinstall fhem and copy my saved (with
updates) installation on top of the new installation. But I wonder if there
is an easy way to start it again. Or is there even a script for this?
{HT}
The fhem installscript appends the String /var/InternerSpeicher/startfhem
to the file /var/flash/debug.cfg. I think there is a more elegant way to do
this on the 7390, but I never bothered.
Guest
you can put it in rc.custom
# rc.custom
/var/InternerSpeicher/fhem/startfhem
Am Mittwoch, 8. August 2012 22:58:10 UTC+2 schrieb dudler:
> Hi
> {HT}
Guest
Thanks. Where can I find the file or is it a new one in /etc/init.d ?
Should I change it with nvi ?
{HT}
2012/8/9 fhem-mower
> # rc.custom
>> Hi
>> {HT}
Guest
you can change it directly from freetz
http://fritz.box:81/cgi-bin/file/mod/rc_custom
The file is only executed at startup.
Am Donnerstag, 9. August 2012 20:30:05 UTC+2 schrieb dudler:
> {HT}
> 2012/8/9 fhem-mower
> > # rc.custom
> >> Hi
> there
> >> {HT}
> > fhem-users+...@googlegroups.com
Guest
whow great. Thanx
I just had to change the security level but it is available now.
{HT}
2012/8/9 fhem-mower :
>> {HT}
>> 2012/8/9 fhem-mower
>> > # rc.custom
>> >> Hi
>> >> there
>> >> {HT}
