Problem mit 1-Wire an DS9097U09# nach shutdown restart
Begonnen von Guest, 24 August 2012, 19:15:59
Guest
heir einfach das Log
2012.08.15 21:06:42 1: OWX: Serial device /dev/ttyUSB0 defined
2012.08.15 21:06:42 1: OWX: Trying again to detect an interface,
answer was
2012.08.15 21:06:43 1: OWX: Trying again to detect an interface,
answer was 0x90
answer was 0x90
2012.08.15 21:06:44 1: OWX: Trying again to detect an interface,
answer was 0x90
2012.08.15 21:06:44 1: OWX: No 1-Wire bus interface detected, answer
was 0x90
2012.08.15 21:06:44 3: OWTHERM: Device OWX_22_69A31A000000 defined.
2012.08.15 21:06:44 3: OWID:   Device OWX_09_5B6D03050000 defined.
2012.08.15 21:06:45 3: OWTHERM: Device OWX_10_67814C010800 defined.
2012.08.15 21:06:45 1: Including ./log/fhem.save
2012.08.15 21:06:45 3: Opening CUL device /dev/ttyACM0
2012.08.15 21:06:45 3: Setting CUL baudrate to 9600
2012.08.15 21:06:45 3: CUL device opened
2012.08.15 21:06:46 1: define CUL_0 CUL /dev/ttyACM0@9600 1034
2012.08.15 21:06:46 3: Opening TCM310 device /dev/ttyUSB0
2012.08.15 21:06:46 3: Setting TCM310 baudrate to 57600
2012.08.15 21:06:46 3: TCM310 device opened
2012.08.15 21:06:46 3: Opening TCM120 device /dev/ttyUSB0
2012.08.15 21:06:46 3: Setting TCM120 baudrate to 9600
2012.08.15 21:06:46 3: TCM120 device opened
2012.08.15 21:06:46 3: Opening FHZ device /dev/ttyUSB0
2012.08.15 21:06:46 3: Setting FHZ baudrate to 9600
2012.08.15 21:06:46 3: FHZ device opened
2012.08.15 21:06:46 3: Opening TRX device /dev/ttyUSB0
2012.08.15 21:06:46 3: Setting TRX baudrate to 38400
2012.08.15 21:06:46 3: TRX device opened
2012.08.15 21:06:47 2: SecurityCheck:  WEB,WEBphone has no basicAuth
attribute. telnetPort has no password/globalpassword attribute.
Running with root privileges. Restart fhem for a new check if the
problem is fixed, or set the global attribute motd to none to supress
this message.
2012.08.15 21:06:47 0: Server started (version Fhem 5.2 (DEVELOPMENT),
$Id: fhem.pl 1757 2012-07-23 13:16:02Z rudolfkoenig $, pid 6763)
2012.08.15 21:06:52 3: Setting CUL_0 baudrate to 9600
2012.08.15 21:06:52 1: /dev/ttyACM0 reappeared (CUL_0)
2012.08.15 21:06:54 1: OWX: Reset called with unknown interface
2012.08.15 21:06:54 1: OWX: Complex called with unknown interface
Das hängt an einer FB7390.
Hat das was  mit dem USB scan bzw create zu tun?
Bernhard
Guest
Nein.
Es gibt noch irgendwelche Aktivitäten auf dem 1-Wire Bus, der Busmaster
wird nicht richtig zurückgesetzt. Hängt mit der parasitären Stromversorgung
des Busmaster zusammen. Abhilfe: Nochmal shutdown von FHEM.
pah
