Problem beim Einrichten des ZWave-ME Sticks
Begonnen von mbeckerkassel, 30 Januar 2018, 21:24:49
mbeckerkassel
Ich versuche auf meinem Raspberry pi den ZWave-ME Stick zum laufen zu bekommen. Leider ohne erfolg. Meine beiden CULs funktionieren einwandfrei.
/var/log/messages bringt:
Jan 30 21:12:57 rpi-heizung kernel: [    0.793985] uart-pl011 3f201000.serial: cts_event_workaround enabled
Jan 30 21:12:57 rpi-heizung kernel: [    0.794054] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
lsusb bringt:
Bus 001 Device 008: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
Bus 001 Device 007: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
Bus 001 Device 006: ID 1a40:0201 Terminus Technology Inc. FE 2.1 7-port Hub
Bus 001 Device 005: ID 07ab:fc9f Freecom Technologies
Bus 001 Device 004: ID 1997:2433
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsmod bringt:
Module                  Size  Used by
fuse                   99667  3
rfcomm                 37723  6
cmac                    3239  1
bnep                   12051  2
hci_uart               20020  1
btbcm                   7916  1 hci_uart
bluetooth             365844  29 hci_uart,bnep,btbcm,rfcomm
spidev                  7373  0
sg                     20717  0
evdev                  12423  4
joydev                  9988  0
brcmfmac              292847  0
brcmutil                9863  1 brcmfmac
cfg80211              544609  1 brcmfmac
rfkill                 20851  6 bluetooth,cfg80211
snd_bcm2835            24427  1
snd_pcm                98565  1 snd_bcm2835
snd_timer              23968  1 snd_pcm
snd                    70032  5 snd_timer,snd_bcm2835,snd_pcm
i2c_bcm2835             7167  0
bcm2835_gpiomem         3940  0
spi_bcm2835             7596  0
fixed                   3285  0
w1_gpio                 4818  0
uio_pdrv_genirq         3923  0
uio                    10204  1 uio_pdrv_genirq
cdc_acm                19414  4
ftdi_sio               33027  0
usbserial              29943  1 ftdi_sio
nfsd                  291321  13
w1_therm                6401  0
wire                   32619  2 w1_gpio,w1_therm
cn                      5889  1 wire
i2c_dev                 6913  0
i2c_bcm2708             5994  0
ip_tables              13161  0
x_tables               20578  1 ip_tables
ipv6                  409194  62
usb scan bringt:
### ttyACM0: checking if it is a CUL
ttyACM0 is already used by the fhem device CUL_0
### ttyACM1: checking if it is a CUL
ttyACM1 is already used by the fhem device cul868
### ttyAMA0: checking if it is a CUL
got wrong answer for a CUL
### ttyAMA0: checking if it is a TCM_ESP3
got wrong answer for a TCM_ESP3
### ttyAMA0: checking if it is a ZWDongle
got wrong answer for a ZWDongle
### ttyAMA0: checking if it is a FRM
got wrong answer for a FRM
Wenn ich mit
define ZWDongle_1 ZWDongle /dev/ttyAMA0@115200
den Dongle definieren kommt zwar initialized, aber ich kann keine Geräte hinzufügen:
Hier kommt die Fehlermeldung:
addNode is unsupported by this controller
Bei mir meldet sich das Geraet in lsusb mit
ZitatBus 002 Device 005: ID 0658:0200 Sigma Designs, Inc.
JWRu
Bei mir liefert lsusb das gleiche.
Es gibt einen Eintrag:
/dev/serial/by-id/usb-0658_0200-if00
den ich für das define verwendet habe - hat super geklappt.
ZBox; RasPi 3B; RasPi Zero W; Homematic; Z-Wave; EnOcean, Shelly; DuoFern; Oregon- und Bresser-Sensoren; Steuerung Viessmann-Heizung; ESP32 und ESP8266 über MQTT; Arduino
mbeckerkassel
Ich habe jetzt den Stick auf die neuste Firmwareversion gebracht und bei meinem RaspberryPI das Seriale Terminal auf devama0 deaktiviert. Jetzt läufts. besten Dank
