HTTPS/SSL Problem
Begonnen von Tueftler1983, 24 März 2018, 07:38:20
Tueftler1983
hallo mein log wird voll geschrieben mit:
2018.03.24 07:00:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:01:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:01:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:02:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:02:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:03:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:03:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:04:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:04:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:04:48 3: UWZ Unwetter: Run.1043 Done fetching data
2018.03.24 07:05:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:05:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:06:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:06:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:07:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:07:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:08:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:08:32 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:09:02 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:09:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:10:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:10:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:11:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:11:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:12:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:12:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:13:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:13:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:14:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:14:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:14:48 3: UWZ Unwetter: Run.1043 Done fetching data
2018.03.24 07:15:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:15:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:16:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:16:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:17:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:17:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:18:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:18:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:19:03 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:19:33 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:20:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:20:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:21:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:21:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:22:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:22:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:23:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:23:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:24:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:24:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:24:48 3: UWZ Unwetter: Run.1043 Done fetching data
2018.03.24 07:25:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:25:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:26:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:26:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:27:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:27:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:28:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:28:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:29:04 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:29:34 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:30:05 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
2018.03.24 07:30:35 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number (peer: 192.168.2.172)
Wie kann ich dieses Problem Lösen??
CoolTux
#1
Da versucht ein Client eine Verbindung mit einem nicht erlaubten Cipher.
Du wirst sicherlich ein Attribut sslVersion gesetzt haben mit !SSLv3
Oder wenn Du sowas nicht gesetzt hast dann setz es mal bitte, weiß gerade nicht mehr wie genau die Interpretation dafür war.
Das TuxNet Wiki:
https://www.cooltux.net
Tueftler1983
so ist WEB konfiguriert:
attr WEB HTTPS 1
attr WEB csrfToken none
attr WEB defaultRoom all
attr WEB editConfig 1
attr WEB iconPath openautomation:fhemSVG:default
attr WEB longpoll 1
attr WEB sslVersion TLSv12:!SSLv3
attr WEB stylesheetPrefix dark
auch ohne das attr sslVersion habe ich noch die selben meldungen im Log
CoolTux
Die im Log erwähnte IP ist dein ? Mit welchem Client?
Das TuxNet Wiki:
Tueftler1983
gute frage!
das einzige was ich angefangen habe neu einzurichten ist alexa-fhem ist das einzige was ich mir vorstellen kann
Tueftler1983
Ja die IP im log ist die vom Raspberry also von FHEM selbst
CoolTux
Soweit mir bekannt kommuniziert alexa-fhem nicht mit dem Webfrontend. Einzige Kommunikation ist von aussen über Port 3000 zu alexa-fhem.
Du kannst aber den Thread mal ins passende Alexa Forum schieben. Mal schauen was die anderen sagen.
Das TuxNet Wiki:
Tueftler1983
in der Config.json für alexa-fhem steht das
    "alexa": {
        "port": 3000,
        "name": "pi",
        "keyFile": "/opt/fhem/alexa-fhem/key.pem",
        "certFile": "/opt/fhem/alexa-fhem/cert.pem",
        "applicationId": "amzn1.ask.skill.XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX",
        "oauthClientID": "amzn1.application-oa2-client.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
        "permissions": {"<skill-id>": { "client_id": "xyz", "client_secret": "123"}}
    "connections": [
            "name": "FHEM",
            "server": "192.168.2.172",
            "port": "8083",
            "webname": "fhem",
     "auth": {
             "user": "xxxx",
             "pass": "xxxxxx"
            "filter": "room=alexa"
CoolTux
OK scheint also doch eine Verbindung zum FHEMWEB auf zu bauen.
Kannst du unter Connections noch mehr zum Thema HTTPS und SSL einstellen?
Schau mal in der Commandref oder im Wiki.
Und verschiebe das Thema bitte.
Das TuxNet Wiki:
Tueftler1983
ne bis jetzt zumindest nicht mehr gefunden
CoolTux
Nun muss NodeJS installiert werden. Leider ist die Version im Debian Repository deutlich zu alt, daher wird mit den folgenden Befehlen das Node Repository hinzugefügt und NodeJS (in der LTS Version) entsprechend installiert:
Auszug aus dem Wiki. Ich weiß aber nicht wie aktuell das noch ist. Würde aber passen.
Das TuxNet Wiki:
Quicky
Hi All,
i got the same Problem on Ubuntu and try to fix it 3 Days.
My Problem occurs after setting up the certificates and config ssl.
If you sercch for this Problem in Google you find many discussions but no Solutions.
https://www.google.com/search?q=failed+error%3A1408F10B%3ASSL&sourceid=ie8&rls=com.microsoft:de-CH:IE-Address&ie=&oe=&safe=on&gws_rd=ssl
At least i delete complete FHME Installation and install everithing new.
Go back to start ;-(
