TP-Link Power over Ethernet Switch fernsteuern
Begonnen von Uhrheber, 22 September 2016, 19:43:52
fl_Indigo
Wernieman
Zeig mal Dein Script ... ist mir momentan rätselhaft
- Bitte um Input für Output
fl_Indigo
root@fhem:/opt/fhem# sudo su - fhem
fhem@fhem:~$ cd /opt/fhem
fhem@fhem:~$ ./poe.sh
spawn telnet 10.0.0.248
Trying 10.0.0.248...
Connected to 10.0.0.248.
Escape character is '^]'.
***************** User Access Login ********************
User:****
Password:
TL-SG2210P>enable
TL-SG2210P#configure
TL-SG2210P(config)#interface gigabitEthernet 1/0/2
TL-SG2210P(config-if)#power inline supply enable
TL-SG2210P(config-if)#exit
TL-SG2210P(config)##2018-04-18 14:43:32,[User]/3/Login the CLI by root on vty0 (10.0.0.201).
#2018-04-18 14:43:32,[PoE]/3/Power supply status of gigabitEthernet 1/0/2 changes from off to on.
#2018-04-18 14:43:42,[Link]/3/gigabitEthernet 1/0/2 changed state to up.
10.0.0.248
2
enable
das sh script
/usr/bin/expect /opt/fhem/poe_set.exp 10.0.0.248 **** **** 2 enable
das expect script
#!/usr/bin/expect -f
set host [lindex $argv 0]
set user [lindex $argv 1]
set pass [lindex $argv 2]
set port [lindex $argv 3]
set status [lindex $argv 4]
#if { $host == "" || $user == "" || $pass == "" || $port == "" || $status == "" }  {
#  puts "Usage: <host> <user> <password> <switchport> <POE enable/disable>\n"
#  exit 1
spawn telnet $host
expect "User:"
send "$user\r"
expect "Password:"
send "$pass\r"
send "enable\r"
send "configure\r"
send "interface gigabitEthernet 1/0/$port\r"
send "power inline supply $status\r"
# Exit the telnet session, and wait for a special end-of-file character.
send "exit\r"
expect eof
puts "$host"
puts "$user"
puts "$pass"
puts "$port"
puts "$status"
Wernieman
Ich hatte Dir vorgeschlagen, mal das "/usr/bin/expect /opt/fhem/poe_set.exp 10.0.0.248 **** **** 2 enable" in ein eigenes Script zu pachen
ala (nur ein Ungetesteter Schnellschuß)
#!/bin/bash
IP=$1
PORT=$2
WIE=$3
echo "$IP $PORT $WIE"
/usr/bin/expect /opt/fhem/poe_set.exp $IP **** **** $PORT $WIE
Ich habe mit Absicht User/Passwort hier nicht per Parameter übergeben. Sollte doch eigentlich statisch sein?
Und dann in FHEM audrufen mit
"./paf/zum/tollen/scirpt/script.sh 10.0.0.248 2 enable"
Ist zwar dann erstmal ein schritt mehr als vorher, dafür kannst Du besser testen...
fl_Indigo
hat nix geändert:
10.0.0.248 2 enable
User:$$        $        $
Password:
Press any key to continue (Q to quit)
Login invalid.
User:$
Password:
Login invalid.
User:$$        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $        $
Login invalid.
Connection closed by foreign host.
2018.04.19 06:54:32 3: n_PoE_Port_2_on return value: -1
mich würds brennend interessieren wie der threadersteller das damals scheinbar erfolgreich implementiert hat...
Wernieman
Mit was für einem Editor hast Du es bearbeitet??
Da  Script funktioniert aus der Konsole, aber nicht aus FHEM??
fl_Indigo
scripte mit nano erstellt und ausführbar gemacht, laufen unter allen benutzern einwandfrei in der console durch...
Wernieman
Komisch .. kann ich mir nicht erklären ...
Kannst DU mal mit den "Lang" Einstellungen rumspielen?
Bzw. Dir ausgeben?
fl_Indigo
Wernieman
Sorry, dachte Du hast schon in der Richtugn gearbeitet ...
http://linuxwiki.de/locale
also einfach mal reinsetzen:
LC_ALL=de_DE.UTF-8
LANG=de_DE.UTF-8
Bzw vorher einfach mal ausgeben lassen:
echo $LC_ALL
echo $LANG
Dann eventuell mal mit dem Parameter de_DE.UTF-8 spielen...
Edit:
Die auf dem System verfügbaren anzeigen:
locale -a
fl_Indigo
alle möglichen de und en varianten durchprobiert, es verändert sich nix... ich gebs auf...
Wernieman
da ich hier so einen switch nicht habe, kann ich Dir leider nicht weiterhelfen ....
fl_Indigo
danke trotzdem für deine inputs! :thumbsup:
Wernieman
Was mich wundert, das es auf der Konsole geht, aber beim Aufruf durch FHEM nicht.
fl_Indigo
habs jetzt in perl gelöst
folgende routine in die myutils
sub poeswitch {
my ($port, $status) = @_;
use Net::Telnet;
my $remote;
$remote = new Net::Telnet (Timeout => 10,
                     Errmode => 'die');
$remote->open("10.0.0.248");
$remote->waitfor('/User:/');
$remote->print("user") ;
$remote->waitfor('/Password:/');
$remote->print("password") ;
$remote->waitfor('/TL-SG2210P/');
$remote->print("\n");
$remote->print("enable\n");
$remote->print("configure\n");
$remote->print("interface gigabitEthernet 1/0/$port\n");
$remote->print("power inline supply $status\n");
eventuell muss auf dem ausführenden system NET::Telnet via cpan oder libnet-telnet-perl via packagemanager nachinstalliert werden
danach klappt der aufruf von
define n_PoE_Port_2_on notify PoE_Port_2_Switch:on {poeswitch("2","enable")};;
define n_PoE_Port_2_off notify PoE_Port_2_Switch:off {poeswitch("2","disable")};;
und der switch schaltet den angegebenen port
vielleicht hilfts ja nochmal jemandem :)
