PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm
Begonnen von Rampler, 24 Oktober 2018, 09:24:55
Rampler
nach diesem Command:
set FL.EG.anzeige regSet brightness 1
bekomme ich diese Warning:
2018.10.24 09:10:01 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 7892.
2018.10.24 09:10:01 1: stacktrace:
2018.10.24 09:10:01 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7892)
2018.10.24 09:10:01 1:     main::CUL_HM_getRegFromStore        called by ./FHEM/10_CUL_HM.pm (4661)
2018.10.24 09:10:01 1:     main::CUL_HM_Set                    called by fhem.pl (3594)
2018.10.24 09:10:01 1:     main::CallFn                        called by fhem.pl (1809)
2018.10.24 09:10:01 1:     main::DoSet                         called by fhem.pl (1842)
2018.10.24 09:10:01 1:     main::CommandSet                    called by ./FHEM/98_cmdalias.pm (99)
2018.10.24 09:10:01 1:     main::CommandCmdAlias               called by fhem.pl (1216)
2018.10.24 09:10:01 1:     main::AnalyzeCommand                called by fhem.pl (1062)
2018.10.24 09:10:01 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2583)
2018.10.24 09:10:01 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (905)
2018.10.24 09:10:01 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (534)
2018.10.24 09:10:01 1:     main::FW_Read                       called by fhem.pl (3599)
2018.10.24 09:10:01 1:     main::CallFn                        called by fhem.pl (726)
vg
Klaus
PS: Meine 10_CUL_HM.pm hat diesen Stand:
# $Id: 10_CUL_HM.pm 17532 2018-10-14 17:50:45Z martinp876 $
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Bullseye), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
MBHG
Hi, ich habe den gleichen Fehler. Hat sich bei dir was geändert in der Zwischenzeit?
Gruss Marc
https://smarthome.family.blog Debian Linux, NanoCUL 868, Signalduino, 4x HM-SW4, 11x HM Asksin Unisensor, NodeMCU ESP8266, RCS 1000 N Comfort, Magic Home, Rauchmelder PT2262, Babble
Rampler
Gruss Marc
Leider Nein, habe es aber umgangen, indem ich statt "set FL.EG.anzeige regSet brightness 1" jetzt
ein "set FL.EG.anzeige ilum 0 0" absezte.
VG Klaus
