[patch] fhem.pl - minor changes
Begonnen von betateilchen, 31 Dezember 2018, 19:47:02
Index: fhem.pl
--- fhem.pl     (Revision 18105)
+++ fhem.pl     (Arbeitskopie)
@@ -4,7 +4,7 @@
#  Copyright notice
-#  (c) 2005-2018
+#  (c) 2005-2019
#  Copyright: Rudolf Koenig (r dot koenig at koeniglich dot de)
#  All rights reserved
@@ -2643,7 +2643,7 @@
   my ($type, $me, $name, $val) = @_;
   if($type eq "del") {
-    my %noDel = ( modpath=>1, verbose=>1, logfile=>1 );
+    my %noDel = ( modpath=>1, verbose=>1, logfile=>1, configfile=>1 );
     return "The global attribute $name cannot be deleted" if($noDel{$name});
     $featurelevel = 5.9 if($name eq "featurelevel");
     $haveInet6    = 0   if($name eq "useInet6"); # IPv6
