Nach fhem-update alle RT Devices gelöscht
Begonnen von Lars_, 08 Januar 2019, 00:26:47
Lars_
Nach einem fhem update sind heute alle RT's aus der Config verschwunden :-\
(de
2019.01.07 23:33:19.759 3: Device db_RT added to ActionDetector with 000:10 time
2019.01.07 23:33:19.781 3: Device ez_RT added to ActionDetector with 000:10 time
2019.01.07 23:33:19.804 3: Device kz_RT added to ActionDetector with 000:10 time
2019.01.07 23:33:19.826 3: Device kz_og_RHS_Gaupe added to ActionDetector with 028:00 time
2019.01.07 23:33:19.848 3: Device kz_og_RHS_Strasse added to ActionDetector with 028:00 time
2019.01.07 23:33:19.869 3: Device sz1_dg_RT added to ActionDetector with 000:10 time
2019.01.07 23:33:19.892 3: Device sz2_dg_RT added to ActionDetector with 000:10 time
2019.01.07 23:33:19.916 3: Device sz_dg_RHS added to ActionDetector with 028:00 time
2019.01.07 23:33:19.968 3: Device wez_TC added to ActionDetector with 000:10 time
2019.01.07 23:33:19.993 3: Device wz_RT added to ActionDetector with 000:10 time
2019.01.07 23:34:13.333 3: telnetForBlockingFn_1546900453: port 37143 opened
2019.01.07 23:34:21.889 1: PERL WARNING: Argument "1.34 0.00 0.13 98.31 0.05 0.00 0.17" isn't numeric in sprintf at ./FHEM/98_SVG.pm line 2198.
2019.01.07 23:35:44.248 3: CUL_HM set kz_RT getConfig
2019.01.07 23:36:52.753 1: PERL WARNING: Argument "0.35 0.00 0.17 98.36 1.07 0.00 0.04" isn't numeric in sprintf at ./FHEM/98_SVG.pm line 2198.
2019.01.07 23:41:36.688 1: PERL WARNING: Argument "0.10 0.00 0.06 99.73 0.00 0.00 0.10" isn't numeric in sprintf at ./FHEM/98_SVG.pm line 2198.
2019.01.07 23:48:40.613 0: Server shutdown
2019.01.07 23:48:53.202 1: Including fhem.cfg
2019.01.07 23:48:53.288 3: telnetPort: port 7072 opened
2019.01.07 23:48:54.534 3: WEB: port 58083 opened
2019.01.07 23:48:54.540 3: WEBphone: port 8084 opened
2019.01.07 23:48:54.543 3: WEBtablet: port 8085 opened
2019.01.07 23:48:54.699 2: eventTypes: loaded 1131 events from /opt/fhem/log/eventTypes.txt
2019.01.07 23:48:55.568 3: Opening CUL0 device /dev/ttyACM0
2019.01.07 23:48:55.639 3: Setting CUL0 serial parameters to 9600,8,N,1
2019.01.07 23:48:55.747 3: CUL0: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2019.01.07 23:48:55.752 3: CUL0 device opened
2019.01.07 23:48:55.756 2: Switched CUL0 rfmode to HomeMatic
2019.01.07 23:48:56.282 1: Including /opt/fhem/FHEM/foreign_devices.cfg
2019.01.07 23:48:56.369 3: Opening myJeeLink device /dev/ttyUSB0
2019.01.07 23:48:56.372 3: Setting myJeeLink serial parameters to 57600,8,N,1
2019.01.07 23:48:57.388 3: myJeeLink device opened
2019.01.07 23:48:57.458 3: LaCrosse_Sensor_AZ_aussen: I/O device is myJeeLink
2019.01.07 23:48:58.055 1: define S_WEZ.Heizung structure rtwez: wrong syntax: define <name> structure <struct-type> [device ...]
2019.01.07 23:48:58.498 3: [HC_BadDG_aw_arriving] device <bad_dg_RT_Clima> in fhem not defined, but accepted
2019.01.07 23:48:58.516 3: [HC_BadDG_aw] device <bad_dg_RT_Clima> in fhem not defined, but accepted
2019.01.07 23:48:58.532 3: [HC_BadDG_au] device <bad_dg_RT_Clima> in fhem not defined, but accepted
2019.01.07 23:48:58.555 3: [HC_BadDG_hwla] device <bad_dg_RT_Clima> in fhem not defined, but accepted
2019.01.07 23:48:58.581 3: [HC_BadDG_hwl] device <bad_dg_RT_Clima> in fhem not defined, but accepted
Über restore aus dem /update konnte ich wieder alles herstellen, aber da klemmt es irgendwo gewaltig :-(
Wäre prima, wenn da mal jemand der Wissenden danach schauen könnte.
Fhem auf rpi 3   fhem auf rpi b+
1 x CULHM/jeelink v3c   1 x CULHM
7 x HM-CC-RT-DN   3 x HM-CC-RT-DN
5 x HM-Sec-RHS
Paul
Cubietruck, HM-USB, CUL, FS20, FHT, HUE, Keymatic
