[GELÖST] "CUL_0: Unknown code , help me" trotz VCCU
Begonnen von erdo_king, 23 Oktober 2017, 13:19:31
erdo_king
Hallo Zusammen,
ich habe trotz eingerichteter (und funktionierender ;) ) vccu diverse Einträge a la "CUL_0: Unknown code ... help me!" im Log...
Ich bin der Ansicht das die vccu (unter anderem) genau dafür da ist!?
Ich habe alle Updates eingespielt und den kompletten RasPI durchgebootet ... weiterhin hatte ich ein vccu update getestet.
get vccu listDevice
devices using vccu
current IO / preferred
  CUL_0 / --- eg.bad.fenster
  CUL_0 / --- eg.bad.heizung
  CUL_0 / --- eg.ez.heizung.links
  CUL_0 / --- eg.ez.heizung.rechts
  CUL_0 / --- eg.wz.heizung
  CUL_0 / --- eg.wz.thermostat
  CUL_0 / --- og.gz.heizung
  CUL_0 / --- og.sz.heizung
  CUL_0 / --- vccu
  CUL_0 / CUL_0 og.fl.tuer
  CUL_0 / CUL_0 og.pr.heizung
  CUL_0 / CUL_0 og.pr.tuer
list vccu
   CFGFN      ./FHEM/fhem_devices.cfg
   CUL_0_MSGCNT 169
   CUL_0_RAWMSG A0F8586103C3C380000000A88DB0B0040::-103.5:CUL_0
   CUL_0_RSSI -103.5
   CUL_0_TIME 2017-10-23 12:58:05
   DEF        XXXXX
   IODev      CUL_0
   LASTInputDev CUL_0
   MSGCNT     169
   NAME       vccu
   NOTIFYDEV  global
   NR         144
   NTFY_ORDER 50-vccu
   STATE      CUL_0:ok,
   TYPE       CUL_HM
   assignedIOs CUL_0
   channel_01 vccu_Btn1
     2017-10-23 12:06:00   state           CUL_0:ok,
     2017-10-03 19:52:04   unknown_1036F0  received
     2017-10-23 10:15:42   unknown_162E2D  received
     2017-10-22 11:25:52   unknown_1A378F  received
     2017-05-03 07:08:28   unknown_1AECE6  received
     2017-10-23 12:56:36   unknown_244E4B  received
     2017-09-22 07:49:19   unknown_2C28B3  received
     2017-10-12 15:27:32   unknown_2C6208  received
     2016-11-16 23:08:06   unknown_2D9FA6  received
     2017-01-13 16:01:01   unknown_2E24A9  received
     2017-05-06 00:10:32   unknown_2E379B  received
     2017-05-06 00:10:13   unknown_2E48B9  received
     2017-10-12 15:27:27   unknown_2E491A  received
     2017-05-02 09:04:53   unknown_2E4940  received
     2017-04-30 23:14:40   unknown_2FCC6B  received
     2017-10-23 12:04:08   unknown_307FB9  received
     2017-05-06 22:47:41   unknown_308141  received
     2017-06-10 11:48:37   unknown_32BEAB  received
     2017-10-23 12:23:49   unknown_35BFE0  received
     2017-10-23 07:24:31   unknown_35E184  received
     2017-05-06 13:41:44   unknown_35E321  received
     2017-10-23 02:24:38   unknown_35E3F6  received
     2017-10-22 01:55:32   unknown_35E40E  received
     2017-09-14 14:07:45   unknown_3A88D2  received
     2017-02-01 07:30:28   unknown_3ADB10  received
     2017-10-23 12:58:05   unknown_3C3C38  received
     2017-10-19 17:22:04   unknown_3D784B  received
     2017-10-23 12:55:38   unknown_3D7DF6  received
     2017-10-20 08:11:21   unknown_3D8908  received
     2017-10-22 12:16:06   unknown_3DAE11  received
     2017-02-25 18:43:46   unknown_472DB2  received
     2017-05-04 15:44:19   unknown_491E26  received
     2017-05-06 04:24:39   unknown_49265D  received
     2017-10-22 07:19:53   unknown_49B9F3  received
     2017-10-22 04:25:49   unknown_4FE786  received
     2017-02-13 09:11:34   unknown_69A4DF  received
     2016-12-28 08:58:06   unknown_6C4853  received
     2017-05-31 12:33:54   unknown_8E6286  received
     2017-03-27 15:38:05   unknown_8F8B35  received
     2017-10-23 12:57:01   unknown_9F9DEC  received
     2017-04-16 17:54:05   unknown_AC28B3  received
     2017-10-23 12:56:14   unknown_BC469E  received
     2017-07-17 17:02:47   unknown_BCB6F7  received
   helper:
     HM_CMDNR   207
     cfgChkResult No regs found for:-ret--ret-
     mId        FFF0
     rxType     1
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       vccu       vccu
       ioList:
         CUL_0
     mRssi:
       mNo
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       vrt        1
     tmpl:
   nb:
     cnt        1
   IODev      CUL_0
   IOList     CUL_0
   IOgrp      vccu
   expert     3_allReg+raw
   model      CCU-FHEM
   subType    virtual
   webCmd     virtual:update
2017.10.23 12:55:57 3: CUL_0: Unknown code A062A94EF9F9DEC, help me!
2017.10.23 12:55:58 3: CUL_0: Unknown code A06BC469E9F9DEC, help me!
2017.10.23 12:57:02 3: CUL_0: Unknown code A06BC469E9F9DEC, help me!
list CUL_0
   CMDS       BbCFiAZEGMKUYRTVWXefmltux
   CUL_0_MSGCNT 714
   CUL_0_TIME 2017-10-23 13:01:20
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        /dev/serial/by-id/usb-busware.de_CUL868-if00@9600 1034
   DeviceName /dev/serial/by-id/usb-busware.de_CUL868-if00@9600
   FD         12
   FHTID      1034
   NAME       CUL_0
   NR         49
   NR_CMD_LAST_H 4
   PARTIAL
   RAWMSG     A0F8D86103CD9500000000A809F0A0A402E
   RSSI       -51
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.61 CUL868
   initString X21
Ar
   owner_CCU  vccu
   MatchList:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2017-10-23 10:53:40   cmds             B b C F i A Z E G M K U Y R T V W X e f m l t u x
     2017-10-23 13:01:20   state           Initialized
   XMIT_TIME:
     1508752641.58827
     1508754594.3326
     1508755148.49258
     1508755983.88125
   helper:
     444AE0:
       QUEUE:
     444B92:
       QUEUE:
     444E09:
       QUEUE:
   hmId       XXXXX
   rfmode     HomeMatic
martinp876
Die msg ist zu kurz. Wahrscheinlich verstümmelt.
Das wird der Grund sein
LuckyDay
das bekommst du aktuell nur weg mit verbose 2 Attribut an deinem CUL_0, also nicht global setzen
erdo_king
Wenn ich nur so einen Support von meinen kommerziellen Anbietern bekommen würde   ;)
Mit "verbose 2" sind die Fehlermeldungen Geschichte - und ich weiß nun (vermutlich) wo sie herkamen...
DANKE!
KNUT345
Sorry, wenn ich mich hier nochmal einklinke.
Habe im Prinzip das gleiche Problem.
vccu definiert und dennoch
2017.12.27 21:48:10 3: CUL1: Unknown code A06BF0FF0608C25, help me!
2017.12.27 21:51:28 3: CUL1: Unknown code A06BF0FF05D39F8, help me!
2017.12.27 21:53:26 3: CUL1: Unknown code A06BF0FF0608C25, help me!
Habe jetzt auch mit verbose 2 die Meldung weg bekommen.
Aber was ist/war das Problem?
Wenn ich das richtig verstehe, dann wird mit verbose 2 doch die Meldung nur nicht mehr geloggt, oder?
Sir Volvic
Ich habe seit 02.02. auch LogEinträge dieser Art.
Sie zu unterdrücken funktioniert zwar, aber habe ich eine Chance herauszufinden was sie verursacht?
2018.02.03 04:00:10 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:03:08 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:05:51 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:08:19 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:10:32 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:13:37 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:16:27 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:19:01 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:21:20 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:24:32 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:27:28 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:30:09 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:32:35 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:34:46 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:37:49 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:40:36 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:43:09 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:45:27 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:48:36 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:51:30 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:54:10 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:56:34 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 04:58:43 3: CUL1: Unknown code A0654BC248BC809, help me!
2018.02.03 05:01:44 3: CUL1: Unknown code A0654BC248BC809, help me!
Es tritt schon recht häufig auf - wie man sieht.
Ich habe kein Sensor/Aktor in Betrieb genommen. Eine vccu lief bisher ohne Probleme.
Kann sein da hat ein Nachbar Homematic IP in Betrieb genommen oder was anderes. Das ist kein Classic Homematic Funktelegramm, das ist was anderes. Ich glaube dagegen gibt es kein Kraut, außer verbose 2.
dantist
Ist das Einrichten einer vCCU empfehlenswert/wichtig, oder kann ich die Log-Einträge von unbekannten Geräten einfach ignorieren?
Pfriemler
Das Kapern alter Threads ohne ausreichenden Themenbezug ist in jedem Fall nicht richtig ...  ;D
1000 User, 2 Meinungen. Ich denke die meisten halten die vCCU zu Recht für unverzichtbar, selbst mit nur einem Funkinterface. Dabei gibt es so viele Gründe dafür, mindestens zwei davon zu betreiben...
Logeinträge unbekannter Geräte kann man in der Regel gefahrlos ignorieren, sie müllen halt nur das Log zu, und das ist zumindest unschön, wenn man was anderes sucht.
Wenn ich den Thread aber richtig verstanden habe, ist die Frage "vCCU oder nicht" für echte "Unknown codes" ohnehin irrelevant. Fremde, aber anlegbare Geräte (etwa vom Nachbarn) setzt man hinterher auf "ignore" und dann behelligen sie einen nie wieder.
Toro
Hallo Zusammen,
ich habe auch das Problem - da es aber extrem viele Einträge sind und meine Nachbarn eher nicht so technikbegeistert wirken, hat es mich schon gewundert, wo die alle herkommen.
Meiner Recherche nach sind es LTE Geräte im 800 Mhz Band, Dieses "strahlt" auch ins 868Mhz Band.
Hier wird das Problem beschrieben https://www.tu-chemnitz.de/etit/sse/szee/rsrc/StoertLTE800.pdf. Das ist nur eine von vielen Quellen zu dem Thema.
Ich habe hier im Forum gesucht, aber diesen Zusammenhang nicht finden können - gab es dazu bereits mal einen Eintrag?
Muss mich jetzt auch mal mit den Möglichkeiten der Unterdrückung beschäftigen - irgendwie blöd ist, das sich scheinbar (das untersuche ich grad) kein Eintrag wiederholt. Aber
bestimmte Teil der "unknown codes" sind immer gleich - siehe Bsp. (86105A)
VG Toro
2019.01.17 09:38:44 3: HMLANGW: Unknown code A0F4C86105A90370000000A50830C0000::-91:HMLANGW, help me!
2019.01.17 09:39:19 3: HMLANGW: Unknown code A0F1086105A94850000000AA0E30C0000::-83:HMLANGW, help me!
2019.01.17 09:39:44 3: HMLANGW: Unknown code A0F4586105A94860000000A60A60C0000::-88:HMLANGW, help me!
2019.01.17 09:40:46 3: HMLANGW: Unknown code A0F4D86105A90370000000A50830C0000::-88:HMLANGW, help me!
LuckyDay
Zitat von: Toro am 18 Januar 2019, 21:44:49
Hallo Zusammen,
VG Toro
Das sind lauter Statusmeldungen von Homematic, nix LTE
richte eine vccu ein--> dann sind die Meldungen im Log weg!
Toro
VCCU ist eingerichtet und mit verbose sind die Meldungen auch weg - aber woher kommen am Tag 100 neue HM Geräte? Interessant ist auch, dass in dem Moment, wo ein Bus am Haus vorbeifährt auf einen Schlag 10 neue Geräte erkannt werden. Alles nur Zufall - um mich herum stehen 4 Einfamilienhäuser, die Hälfte der Bewohner hat kein Smartphone ;-) ?
frank
deine meldungen müssen auch bei verbose=3 (default) weg sein, ansonnsten funktioniert deine vccu nicht. zumindestens die messages, die du bisher gepostet hast. da war kein voodoo dabei.
wieso hundert geräte? wieso smartphone?
FHEM: 6.0(SVN) => Pi3(buster)
Toro
Woran erkennt man denn, dass es Homematic Geräte sind? Ich habe mir mal mein Logfile angeschaut und die Zahlen sind erstaunlich  - am 1.1. (Silvesternacht) hatte ich die ersten 100 dieser Einträge zwischen 0:00 und 1:10 Uhr - über den ganzen Tag waren über 2200!!
