[erledigt] HM-LC-Dim1TPBU-FM pct warnings
Begonnen von the ratman, 19 Januar 2019, 10:24:03
the ratman
hiho,
schalte ich meine hommatic lämpchen per pct, funzt das zwar, aber es gibt pro schaltvorgang folgende warnings:2019.01.19 10:15:47 1: logfile wurde gelöscht
2019.01.19 10:16:15 1: PERL WARNING: Argument "set_37" isn't numeric in numeric eq (==) at (eval 37363) line 1.
2019.01.19 10:16:15 1: stacktrace:
2019.01.19 10:16:15 1:     main::__ANON__                      called by (eval 37363) (1)
2019.01.19 10:16:15 1:     (eval)                              called by fhem.pl (4556)
2019.01.19 10:16:15 1:     main::evalStateFormat               called by fhem.pl (4657)
2019.01.19 10:16:15 1:     main::readingsEndUpdate             called by fhem.pl (4847)
2019.01.19 10:16:15 1:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (9085)
2019.01.19 10:16:15 1:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (4872)
2019.01.19 10:16:15 1:     main::CUL_HM_Set                    called by fhem.pl (3676)
2019.01.19 10:16:15 1:     main::CallFn                        called by fhem.pl (1878)
2019.01.19 10:16:15 1:     main::DoSet                         called by fhem.pl (1910)
2019.01.19 10:16:15 1:     main::CommandSet                    called by fhem.pl (1228)
2019.01.19 10:16:15 1:     main::AnalyzeCommand                called by fhem.pl (1074)
2019.01.19 10:16:15 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2608)
2019.01.19 10:16:15 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (883)
2019.01.19 10:16:15 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (554)
2019.01.19 10:16:15 1:     main::FW_Read                       called by fhem.pl (3681)
2019.01.19 10:16:15 1:     main::CallFn                        called by fhem.pl (737)
2019.01.19 10:16:15 1: PERL WARNING: Argument "set_37" isn't numeric in numeric eq (==) at (eval 37365) line 1.
2019.01.19 10:16:15 1:     main::__ANON__                      called by (eval 37365) (1)
2019.01.19 10:16:15 1:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (6346)
2019.01.19 10:16:15 1: PERL WARNING: Argument "set_37" isn't numeric in numeric eq (==) at (eval 37368) line 1.
2019.01.19 10:16:15 1:     main::__ANON__                      called by (eval 37368) (1)
2019.01.19 10:16:15 1:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (7146)
2019.01.19 10:16:15 1:     main::CUL_HM_trigLastEvent          called by ./FHEM/10_CUL_HM.pm (7897)
2019.01.19 10:16:15 1:     main::CUL_HM_DumpProtocol           called by ./FHEM/10_CUL_HM.pm (7091)
2019.01.19 10:16:15 1:     main::CUL_HM_SndCmd                 called by ./FHEM/10_CUL_HM.pm (6781)
2019.01.19 10:16:15 1:     main::CUL_HM_ProcessCmdStack        called by ./FHEM/10_CUL_HM.pm (6350)
2019.01.19 10:16:16 1: PERL WARNING: Argument "set_37" isn't numeric in numeric eq (==) at (eval 37371) line 1.
2019.01.19 10:16:16 1: stacktrace:
2019.01.19 10:16:16 1:     main::__ANON__                      called by (eval 37371) (1)
2019.01.19 10:16:16 1:     (eval)                              called by fhem.pl (4556)
2019.01.19 10:16:16 1:     main::evalStateFormat               called by fhem.pl (4657)
2019.01.19 10:16:16 1:     main::readingsEndUpdate             called by ./FHEM/10_CUL_HM.pm (9074)
2019.01.19 10:16:16 1:     main::CUL_HM_UpdtReadBulk           called by ./FHEM/10_CUL_HM.pm (3723)
2019.01.19 10:16:16 1:     main::CUL_HM_pushEvnts              called by ./FHEM/10_CUL_HM.pm (2982)
2019.01.19 10:16:16 1:     main::CUL_HM_Parse                  called by fhem.pl (3877)
2019.01.19 10:16:16 1:     main::Dispatch                      called by ./FHEM/00_HMUARTLGW.pm (1388)
2019.01.19 10:16:16 1:     main::HMUARTLGW_Parse               called by ./FHEM/00_HMUARTLGW.pm (1491)
2019.01.19 10:16:16 1:     main::HMUARTLGW_Read                called by fhem.pl (3681)
2019.01.19 10:16:16 1:     main::CallFn                        called by fhem.pl (737)
wie krieg ich das den weg?
list zum device:Internals:
   DEF        1A962201
   FUUID      5c42da43-f33f-0f9e-5417-864f9fd31337ce4c
   NAME       wohnzimmer_buero_licht_Dim
   NOTIFYDEV  global
   NR         81
   NTFY_ORDER 50-wohnzimmer_buero_licht_Dim
   STATE      off
   TYPE       CUL_HM
   chanNo     01
   device     wohnzimmer_buero_licht
     2019-01-19 10:16:35   CommandAccepted yes
     2018-10-13 11:34:31   RegL_01.        00:00
     2019-01-19 10:16:41   deviceMsg       off (to vccu)
     2019-01-19 10:16:41   dim             stop:off
     2019-01-19 10:16:41   level           0
     2018-10-19 22:59:43   levelMissed     desired:0
     2019-01-19 10:16:41   overheat        off
     2019-01-19 10:16:41   overload        off
     2019-01-19 10:16:41   pct             0
     2019-01-19 10:16:41   phyLevel        0
     2019-01-19 10:16:41   recentStateType info
     2019-01-19 10:16:41   reduced         off
     2019-01-19 10:16:41   state           off
     2019-01-19 10:16:41   timedOn         off
     2019-01-19 10:16:34   trigLast        fhem:02
   helper:
     dlvlCmd    ++A0113224331A96220201000000
     regLst     ,1,3p
     dir:
       cur        stop
       rct        up
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     tmpl:
     vDim:
       idPhy      1A962201
       idV2       1A962202
       idV3       1A962203
   alias      wohnzimmer büro dim
   devStateIcon off:off on:light_light_dim_100 up:light_light_dim_10 down:light_light_dim_100 9\d.*:light_light_dim_90 8\d.*:light_light_dim_80 7\d.*:light_light_dim_70 6\d.*:light_light_dim_60 5\d.*:light_light_dim_50 4\d.*:light_light_dim_40 3\d.*:light_light_dim_30 2\d.*:light_light_dim_20 1\d.*:light_light_dim_10 0\d.*:light_light_dim_100 .*:edit_settings@orange
   fp_fp_start 475,15,2,büro deckenlicht
   fp_fp_tab_start 115,340,2,büro deckenlicht,
   group      licht
   icon       light_light
   model      HM-LC-Dim1TPBU-FM
   peerIDs    00000000,
   room       homematic
   stateFormat {if(ReadingsVal($name,"level",0)==0) {"off"} elsif (ReadingsVal($name,"level",0)==100) {"on"} else {ReadingsVal($name,"level",0)}}
   webCmd     pct
list zur "hardware":Internals:
   DEF        1A9622
   FUUID      5c42da43-f33f-0f9e-4f8b-e0dbea3b51d5103f
   IODev      hmLan2
   LASTInputDev hmLan2
   MSGCNT     8
   NOTIFYDEV  global
   NR         79
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 wohnzimmer_buero_licht_Dim
   channel_02 wohnzimmer_buero_licht_Dim_V_01
   channel_03 wohnzimmer_buero_licht_Dim_V_02
   hmLan2_MSGCNT 8
   hmLan2_RAWMSG 050100349CA4101A9622322433060100002F00
   hmLan2_RSSI -52
   hmLan2_TIME 2019-01-19 10:16:41
   lastMsg    No:9C - t:10 s:1A9622 d:322433 060100002F00
   protLastRcv 2019-01-19 10:16:41
   protRcv    8 last_at:2019-01-19 10:16:41
   protSnd    12 last_at:2019-01-19 10:16:41
   protState  CMDs_done
   rssi_at_hmLan2 cnt:8 min:-53 max:-48 avg:-51.37 lst:-52
   rssi_hmLan2 cnt:7 min:-54 max:-45 avg:-50 lst:-47
     2018-10-13 11:33:18   D-firmware      2.9
     2018-10-13 11:33:18   D-serialNr      JEQ0204016
     2018-10-13 11:34:30   PairedTo        0x322433
     2018-10-13 11:34:30   R-pairCentral   0x322433
     2018-10-13 11:34:30   RegL_00.        02:01 0A:32 0B:24 0C:33 15:FF 18:00 00:00
     2019-01-05 23:56:09   phyLevel        0
     2019-01-19 10:16:41   state           CMDs_done
   helper:
     HM_CMDNR   156
     cSnd       113224331A96220201000000,013224331A9622010E
     mId        0068
     regLst     ,0
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +1A9622,00,00,00
       nextSend   1547889401.56673
       rxt        0
       vccu       vccu
       p:
         1A9622
         00
         00
         00
       prefIO:
         hmLan2
     mRssi:
       mNo        9C
       io:
         hmLan:
         hmLan2:
           -46
           -46
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rpt:
       IO         hmLan2
       flg        A
       ts         1547889401.27307
       ack:
         HASH(0x555f8bf0d6e0)
         9C80023224331A962200
     rssi:
       at_hmLan2:
         avg        -51.375
         cnt        8
         lst        -52
         max        -48
         min        -53
       hmLan2:
         avg        -50
         cnt        7
         lst        -47
         max        -45
         min        -54
     tmpl:
   IODev      hmLan2
   IOgrp      vccu:hmLan2
   alias      wohnzimmer büro licht
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.9
   group      aktoren
   icon       light_light
   room       homematic
   serialNr   JEQ0204016
   subType    dimmer
   webCmd     getConfig:clear msgEvents
→do↑p!dnʇs↓shit←
frank
#1
du musst anscheinend die "set_XX" infos in deinem attr stateFormat "abfangen", so dass sie nicht mit "==" verarbeitet werden.
edit: oder mit "eq" vergleichen, anstatt mit "==".
eigentlich dachte ich, dass die "set_XX" infos nur im state reading auftauchen. muss ich mal selber testen.
FHEM: 6.0(SVN) => Pi3(buster)
the ratman
#2
wie soll ich die abfangen?
die set_xx warnings kommen auch, wenn ich ganz stink normal "set wohnzimmer_buero_licht_Dim pct 50" sag. da rennt also von haus aus schon was falsch würd ich sagen.
nachtrag:
habs nur spaßeshalber mal mit meinen rollos der marke HM-LC-Bl1PBU-FM probiert
das kommt kein solches warning.
nur, falls dies hilft
→do↑p!dnʇs↓shit←
frank
#3
wenn ich meinen eventmonitor anschaue, wäre es am besten, du nutzt das reading "pct" für dein stateformat.
edit: der test war aber gerade beim Dim1T-FM.
ich schau gleich noch beim Dim1TPBU-FM.
edit2: beim PBU sollte es auch über das reading pct funktionieren.
the ratman
#4
ha
so einfach kanns gehen - danke für den hinweis ... funzt!
das "level" hab ich aber irgendwo abgeschrieben - muß also irgendwo als tipp stehen.
habts ihr da irgendwann mal was umgestellt? weil den stateformat hatte ich schon drinnen, seit ich hm verwend. wobei ich zugeben muß - pct verwend ich bei homematic extremst selten bei den lichtern, kann ich also durchaus übersehen haben.
→do↑p!dnʇs↓shit←
martinp876
Du kannst aber auch auf eq"0" anstelle von ==0 abfragen. Hängt davon ab wie du mit den transienten umgehen willst. Ein numerischer Vergleich ist nicht erforderlich.
Du solltest überlegen die Funktion reasingsval nur einmal aufzurufen mich stören solche low Performance Implementierungen
the ratman
jo - wie gsagt - das war entweder hier im forum oder sonst wo als "tipp" für hm-devices. quasi also noch aus zeiten, als ich noch weniger ahnung als jetzt gehabt hab *g*. und dann einfach verdrängt/vergessen/[bitte ausrede hier einfügen].
→do↑p!dnʇs↓shit←
