[GELÖST] PERL WARNING: Argument "off" isn't numeric in sprintf at
Begonnen von Burny4600, 04 Juli 2019, 20:25:33
Burny4600
Wie bekomme ich den Fehler heraus wie diese ständigen Fehlermeldungen produziert werden?
2019.07.05 07:27:17.021 1 : PERL WARNING: Argument "off" isn't numeric in sprintf at (eval 205057) line 1.
2019.07.05 07:27:17.021 1 : stacktrace:
2019.07.05 07:27:17.021 1 : main::__ANON__ called by (eval 205057) (1)
2019.07.05 07:27:17.022 1 : (eval) called by fhem.pl (4626)
2019.07.05 07:27:17.022 1 : main::evalStateFormat called by fhem.pl (4727)
2019.07.05 07:27:17.022 1 : main::readingsEndUpdate called by ./FHEM/10_CUL_HM.pm (9448)
2019.07.05 07:27:17.022 1 : main::CUL_HM_UpdtReadBulk called by ./FHEM/10_CUL_HM.pm (3794)
2019.07.05 07:27:17.022 1 : main::CUL_HM_pushEvnts called by ./FHEM/10_CUL_HM.pm (3042)
2019.07.05 07:27:17.022 1 : main::CUL_HM_Parse called by fhem.pl (3950)
2019.07.05 07:27:17.022 1 : main::Dispatch called by ./FHEM/00_HMUARTLGW.pm (1463)
2019.07.05 07:27:17.023 1 : main::HMUARTLGW_Parse called by ./FHEM/00_HMUARTLGW.pm (1566)
2019.07.05 07:27:17.023 1 : main::HMUARTLGW_Read called by fhem.pl (3754)
2019.07.05 07:27:17.023 1 : main::CallFn called by fhem.pl (748)
2019.07.05 07:27:17.026 4 : CUL_HM OG1_SL_HZG_TC dupe: dont process
2019.07.05 07:27:17.028 5 : Starting notify loop for OG1_SL_HZG_TC, 1 event(s), first is rssi_at_HmUART_OG1: -68
2019.07.05 07:27:17.044 5 : Heizung: not on any display, ignoring notify
2019.07.05 07:27:17.055 5 : SabStatus: not on any display, ignoring notify
2019.07.05 07:27:17.056 5 : SenRSSI: not on any display, ignoring notify
2019.07.05 07:27:17.057 5 : battStatus: not on any display, ignoring notify
2019-07-05 07:27:17.058 CUL_HM OG1_SL_HZG_TC rssi_at_HmUART_OG1: -68
2019.07.05 07:27:17.058 5 : End notify loop for OG1_SL_HZG_TC
   CFGFN      /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
   DEF        634116
   FUUID      5c45b04e-f33f-f4d2-590d-a99320a19c6ef89b
   HmUART_AB_GTO_MSGCNT 170
   HmUART_AB_GTO_RAWMSG 050000554F84106341160000000B24F33340
   HmUART_AB_GTO_RSSI -85
   HmUART_AB_GTO_TIME 2019-07-05 06:48:22
   HmUART_EG_MSGCNT 440
   HmUART_EG_RAWMSG 0500005B68847063411600000000F02D
   HmUART_EG_RSSI -91
   HmUART_EG_TIME 2019-07-05 06:58:51
   HmUART_OG1_MSGCNT 578
   HmUART_OG1_RAWMSG 0500004474847063411600000000EE2E
   HmUART_OG1_RSSI -68
   HmUART_OG1_TIME 2019-07-05 07:30:08
   HmUART_OG2_MSGCNT 578
   HmUART_OG2_RAWMSG 0500004A74847063411600000000EE2E
   HmUART_OG2_RSSI -74
   HmUART_OG2_TIME 2019-07-05 07:30:08
   IODev      HmUART_OG1
   LASTInputDev HmUART_OG1
   MSGCNT     1766
   NAME       OG1_SL_HZG_TC
   NOTIFYDEV  global
   NR         3432
   NTFY_ORDER 50-OG1_SL_HZG_TC
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 OG1_SL_HZG_TC_Weather
   channel_02 OG1_SL_HZG_TC_Climate
   channel_03 OG1_SL_HZG_TC_WindowRec
   channel_06 OG1_SL_HZG_TC_remote
   channel_07 OG1_SL_HZG_TC_SwitchTr
   lastMsg    No:74 - t:70 s:634116 d:000000 00EE2E
   protCondBurst unknown
   protLastRcv 2019-07-05 07:30:08
   protRcv    581 last_at:2019-07-05 07:30:08
   rssi_at_HmUART_AB_GTO cnt:170 min:-86 max:-80 avg:-83.15 lst:-85
   rssi_at_HmUART_EG cnt:440 min:-93 max:-82 avg:-85.12 lst:-91
   rssi_at_HmUART_OG1 cnt:578 min:-72 max:-66 avg:-69.03 lst:-68
   rssi_at_HmUART_OG2 cnt:578 min:-78 max:-74 avg:-75.7 lst:-74
     2019-07-04 19:54:11   Activity        alive
     2019-07-04 22:34:02   CommandAccepted yes
     2019-01-21 12:43:31   D-firmware      1.3
     2019-01-21 12:43:31   D-serialNr      OEQ1675526
     2019-05-23 12:50:51   PairedTo        0xF12347
     2019-01-21 13:29:57   R-btnLock       on
     2019-01-21 13:29:57   R-burstRx       on
     2019-01-21 13:29:57   R-cyclicInfoMsg on
     2019-01-21 13:29:57   R-cyclicInfoMsgDis 0
     2019-01-21 13:29:57   R-globalBtnLock off
     2019-01-21 13:29:57   R-localResDis   off
     2019-01-21 13:29:57   R-lowBatLimitRT 2.2 V
     2019-01-21 13:29:57   R-modusBtnLock  off
     2019-01-21 13:29:57   R-pairCentral   0xF12347
     2019-05-23 12:50:51   RegL_00.        00:00 01:01 02:01 09:01 0A:F1 0B:23 0C:47 0F:01 11:00 12:16 16:01 18:00 19:00 1A:00
     2019-05-23 13:05:34   RegL_07.
     2019-07-05 07:07:05   battery         ok
     2019-07-05 07:07:05   batteryLevel    3.4
     2019-07-05 07:07:05   desired-temp    off
     2019-07-05 07:07:05   measured-temp   23.8
     2019-06-04 21:41:38   rssi_HmUART_AB_GTO -68
     2019-06-05 10:28:51   rssi_HmUART_OG1 -65
     2019-05-29 21:41:58   rssi_HmUART_OG2 -68
     2019-07-05 06:48:22   rssi_at_HmUART_AB_GTO -85
     2019-07-05 06:58:51   rssi_at_HmUART_EG -91
     2019-07-05 07:30:08   rssi_at_HmUART_OG1 -68
     2019-07-05 07:30:08   rssi_at_HmUART_OG2 -74
     2019-05-22 19:21:02   sabotageAttack_ErrIoAttack cnt 1
     2019-06-30 03:30:02   state           CMDs_done
     2019-02-23 12:51:49   time-request    -
   helper:
     HM_CMDNR   116
     mId        00AD
     peerFriend
     peerOpt    -:thermostat
     regLst     0
     rxType     6
     supp_Pair_Rep 0
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       newChn     +634116,00,03,00
       nextSend   1562304608.90135
       prefIO
       rxt        0
       vccu       VCCU
       p:
         634116
         00
         03
         00
     mRssi:
       mNo        74
       io:
         HmUART_AB_GTO:
         HmUART_EG:
         HmUART_OG1:
           -64
           -64
         HmUART_OG2:
           -74
           -74
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rssi:
       at_HmUART_AB_GTO:
         avg        -83.1588235294118
         cnt        170
         lst        -85
         max        -80
         min        -86
       at_HmUART_EG:
         avg        -85.1295454545455
         cnt        440
         lst        -91
         max        -82
         min        -93
       at_HmUART_OG1:
         avg        -69.0328719723183
         cnt        578
         lst        -68
         max        -66
         min        -72
       at_HmUART_OG2:
         avg        -75.7006920415224
         cnt        578
         lst        -74
         max        -74
         min        -78
     shRegW:
       07         02
     shadowReg:
     tmpl:
   IODev      HmUART_OG1
   IOgrp      VCCU
   actCycle   000:10
   actStatus  alive
   alias      OG1 Schlafzimmer - Heizung - Temperaturcontroller
   autoReadReg 4_reqStatus
   burstAccess 1_auto
   devStateStyle style="text-align:left;;font-weight:bold;;"
   event-on-change-reading .*
   expert     251_anything
   firmware   1.3
   group      OG1 Schlafzimmer - Heizung
   icon       hm-tc-it-wm-w-eu
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   room       Heizung,OG1-Schlafzimmer,_HM
   rssiLog    1
   serialNr   OEQ1675526
   sortby     02.01
   subType    thermostat
   userReadings rssi_dB:CUL_Master_RSSI.* {(ReadingsVal("$name","CUL_Master_RSSI",0))}
   webCmd     getConfig:clear msgEvents
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
amenomade
Dein Device hat kein Reading CUL_Master_RSSI. Wie soll das funktionieren?
Burny4600
Das stimmt. Das war ein Copy Fehler.
Dennoch habe ich immer noch diesen Fehler mit
Antw:PERL WARNING: Argument "off" isn't numeric in sprintf at
den ich nicht feststellen kann woher er kommt.
2019.07.06 21:16:16.933 1 : PERL WARNING: Argument "off" isn't numeric in sprintf at (eval 23312) line 1.
2019.07.06 21:16:16.934 1 : stacktrace:
2019.07.06 21:16:16.935 1 : main::__ANON__ called by (eval 23312) (1)
2019.07.06 21:16:16.936 1 : (eval) called by fhem.pl (4626)
2019.07.06 21:16:16.936 1 : main::evalStateFormat called by fhem.pl (4727)
2019.07.06 21:16:16.937 1 : main::readingsEndUpdate called by ./FHEM/10_CUL_HM.pm (9448)
2019.07.06 21:16:16.937 1 : main::CUL_HM_UpdtReadBulk called by ./FHEM/10_CUL_HM.pm (3787)
2019.07.06 21:16:16.938 1 : main::CUL_HM_pushEvnts called by ./FHEM/10_CUL_HM.pm (3042)
2019.07.06 21:16:16.939 1 : main::CUL_HM_Parse called by fhem.pl (3950)
2019.07.06 21:16:16.940 1 : main::Dispatch called by ./FHEM/00_HMUARTLGW.pm (1463)
2019.07.06 21:16:16.941 1 : main::HMUARTLGW_Parse called by ./FHEM/00_HMUARTLGW.pm (1566)
2019.07.06 21:16:16.942 1 : main::HMUARTLGW_Read called by fhem.pl (3754)
2019.07.06 21:16:16.942 1 : main::CallFn called by fhem.pl (748)
LG Chris
amenomade
Burny4600
list stateFormat=.*{.* habe ich gemacht.
AB_MB_PS
AB_P_ST_DT09T04D
AB_WST_ReMDayD
AB_WST_ReMDayZD
APCUSVL
APCUSVL_bc
APCUSVL_bcl
APCUSVL_bcw
APCUSVL_br
APCUSVL_brl
APCUSVL_bt
APCUSVL_iv
APCUSVL_rbr
APCUSVL_rp
APCUSVL_rul
APCUSVL_udsh
APCUSVL_udst
APCUSVL_ul
DL2_CS10
DL2_T01
DL2_T02
DL2_T03
DL2_T04
DL2_T05
DL2_T06
DL2_T07
DL2_T08
DL2_T09
DL2_T10
DL2_T11
DL2_T12
DL2_WMZ1RT
DL2_WMZ1VT
DL2_WMZ2RT
DL2_WMZ2VT
EG_BA_HZG_RT_Clima
EG_BA_HZG_RT_Weather
EG_BA_HZG_TC_Climate
EG_BA_HZG_TC_Weather
EG_KU_HZG_RT_Clima
EG_KU_HZG_RT_Weather
EG_KU_HZG_TC_Climate
EG_KU_HZG_TC_Weather
EG_SL_HZG_RT_Clima
EG_SL_HZG_RT_Weather
EG_SL_HZG_TC_Climate
EG_SL_HZG_TC_Weather
EG_STH_HZG_RT_Clima
EG_STH_HZG_RT_Weather
EG_WC_HZG_RT_Clima
EG_WC_HZG_RT_Weather
EG_WI_HZG_RT_Clima
EG_WI_HZG_RT_Weather
EG_WZ_HZG_RT_Clima
EG_WZ_HZG_RT_Weather
EG_WZ_HZG_TC_Climate
EG_WZ_HZG_TC_Weather
EV_SDM630M
EnergieAB
EnergieEG
EnergieGas
EnergieOG1
EnergieOG2
HZG_EKF_STR
KAL_WEEK
KG_WE_WV
LUX_SRD
NG_SDM630M
OG1_KI_HZG_RT_Clima
OG1_KI_HZG_RT_Weather
OG1_KI_HZG_TC_Climate
OG1_KI_HZG_TC_Weather
OG1_KU_HZG_RT_Clima
OG1_KU_HZG_RT_Weather
OG1_KU_HZG_TC_Climate
OG1_KU_HZG_TC_Weather
OG1_SL_HZG_RT_Clima
OG1_SL_HZG_RT_Weather
OG1_STH_HZG_RT_Clima
OG1_STH_HZG_RT_Weather
OG1_STH_HZG_TC_Weather_vT_S
OG1_WC_HZG_RT_Clima
OG1_WC_HZG_RT_Weather
OG1_WC_HZG_TC_Weather_vT_S
OG1_WZ_HZG_RT_Clima
OG1_WZ_HZG_RT_Weather
OG1_WZ_HZG_TC_Climate
OG1_WZ_HZG_TC_Weather
OG2_BU1_HZG_RT_Clima
OG2_BU1_HZG_RT_Weather
OG2_BU1_HZG_TC_Climate
OG2_BU1_HZG_TC_Weather
OG2_BU2_HZG_RT1_Clima
OG2_BU2_HZG_RT1_Weather
OG2_BU2_HZG_RT2_Clima
OG2_BU2_HZG_RT2_Weather
OG2_BU2_HZG_TC_Climate
OG2_BU2_HZG_TC_Weather
OG2_EDV_R_EDVVT
OG2_EDV_R_RT
OG2_HZR_ST_DT07T08D
OG2_HZR_ST_DT12T08D
OG2_WC_HZG_RT_Clima
OG2_WC_HZG_RT_Weather
PCR800
PV_Anlage_1
PV_Anlage_1_PAC
RGB_AB_FR_Dim
RGB_OG1_WZ_Dim
SUSV
THGR810_1
THGR810_2
THGR810_2D
THGR810_6
THGR810_7
THWR800_3
UVN800
WGR800
ab_d_sstg
ab_fr_rt
ab_sa_rt
bmp180
eq3
myAstro
myTwilight
og1_ba_rt
sds011
tek603
tsl2561
veml6070
Nur wie mir das bei dieser Perl Warning weiterhelfen kann habe ich noch nicht verstanden.
Zudem sind hier auch nicht HM Geräte vorhanden.
Ich denke ich habe den Fehler gefunden.
list EG_BA_HZG_TC_Climate
   DEF        633B6D02
   FUUID      5c45b04d-f33f-f4d2-63c7-2ba0f6b5682afe03
   NAME       EG_BA_HZG_TC_Climate
   NOTIFYDEV  global
   NR         3201
   NTFY_ORDER 50-EG_BA_HZG_TC_Climate
   STATE      Raumtemperatur: 24.0 °C <br>Luftfeuchte: 63.0 % <br>Sollwert: 0.0 °C
   TYPE       CUL_HM
   chanNo     02
   device     EG_BA_HZG_TC
   peerList   EG_BA_HZG_RT_Climate,
     2019-07-07 13:47:38   CommandAccepted yes
     2019-01-25 22:23:16   R-boostPeriod   5 min
     2019-01-25 22:23:16   R-dayTemp       21 C
     2019-01-25 22:23:16   R-daylightSaveTime on
     2019-01-25 22:23:16   R-heatCool      heating
     2019-01-25 22:23:16   R-modePrioManu  all
     2019-01-25 22:23:16   R-modePrioParty all
     2019-01-25 22:23:16   R-nightTemp     17 C
     2019-01-25 22:23:16   R-noMinMax4Manu off
     2019-01-25 22:23:16   R-sendWeatherData on
     2019-01-25 22:23:16   R-showHumidity  temp
     2019-01-25 22:23:16   R-showInfo      time
     2019-01-25 22:23:16   R-showSetTemp   actTemp
     2019-01-25 22:23:16   R-showWeekday   off
     2019-01-21 13:28:35   R-sign          off
     2019-05-22 18:22:40   R-tempMax       30.5 C
     2019-05-22 18:22:40   R-tempMin       4.5 C
     2019-01-25 22:23:16   R-tempOffset    0.0K
     2019-01-25 22:23:16   R-weekPrgSel    prog1
     2019-01-25 22:23:16   R-winOpnBoost   off
     2019-05-23 07:16:47   R_P1_0_tempListSat 06:00 18.0 10:00 21.0 18:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_1_tempListSun 06:00 18.0 10:00 21.0 18:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_2_tempListMon 06:00 18.0 10:00 21.0 18:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_3_tempListTue 06:00 18.0 10:00 21.0 18:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_4_tempListWed 06:00 18.0 10:00 21.0 17:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_5_tempListThu 06:00 18.0 10:00 21.0 18:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_6_tempListFri 06:00 18.0 10:00 21.0 17:00 19.0 20:00 21.0 24:00 18.0
     2019-05-23 07:16:47   R_P1_tempList_State verified
     2019-05-23 07:16:51   R_P2_0_tempListSat 24:00 17.0
     2019-05-23 07:16:51   R_P2_1_tempListSun 24:00 17.0
     2019-05-23 07:16:51   R_P2_2_tempListMon 24:00 17.0
     2019-05-23 07:16:51   R_P2_3_tempListTue 24:00 17.0
     2019-05-23 07:16:51   R_P2_4_tempListWed 24:00 17.0
     2019-05-23 07:16:51   R_P2_5_tempListThu 24:00 17.0
     2019-05-23 07:16:51   R_P2_6_tempListFri 24:00 17.0
     2019-05-23 07:16:51   R_P2_tempList_State verified
     2019-05-23 07:16:55   R_P3_0_tempListSat 24:00 17.0
     2019-05-23 07:16:55   R_P3_1_tempListSun 24:00 17.0
     2019-05-23 07:16:55   R_P3_2_tempListMon 24:00 17.0
     2019-05-23 07:16:55   R_P3_3_tempListTue 24:00 17.0
     2019-05-23 07:16:55   R_P3_4_tempListWed 24:00 17.0
     2019-05-23 07:16:55   R_P3_5_tempListThu 24:00 17.0
     2019-05-23 07:16:55   R_P3_6_tempListFri 24:00 17.0
     2019-05-23 07:16:55   R_P3_tempList_State verified
     2019-05-23 07:16:42   RegL_01.        00:00 08:00
     2019-05-23 07:16:47   RegL_07.        00:00 01:2A 02:22 03:09 04:3D 05:00 06:00 07:00 08:00 09:87 0A:30 0B:00 0C:00 0D:00 0E:01 0F:04 10:00 11:00 12:09 13:00 14:48 15:48 16:54 17:78 18:4C 19:D8 1A:54 1B:F0 1C:49 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:48 2F:48 30:54 31:78 32:4C 33:D8 34:54 35:F0 36:49 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:48 49:48 4A:54 4B:78 4C:4C 4D:D8 4E:54 4F:F0 50:49 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:48 63:48 64:54 65:78 66:4C 67:D8 68:54 69:F0 6A:49 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:48 7D:48 7E:54 7F:78 80:4C 81:CC 82:54 83:F0 84:49 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:48 97:48 98:54 99:78 9A:4C 9B:D8 9C:54 9D:F0 9E:49 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:48 B1:48 B2:54 B3:78 B4:4C B5:CC B6:54 B7:F0 B8:49 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2019-05-23 07:16:51   RegL_08.        00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2019-05-23 07:16:55   RegL_09.        00:00 01:00 02:00 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:00 0D:00 0E:00 0F:00 10:00 11:00 12:00 13:00 14:45 15:20 16:45 17:20 18:45 19:20 1A:45 1B:20 1C:45 1D:20 1E:45 1F:20 20:45 21:20 22:45 23:20 24:45 25:20 26:45 27:20 28:45 29:20 2A:45 2B:20 2C:45 2D:20 2E:45 2F:20 30:45 31:20 32:45 33:20 34:45 35:20 36:45 37:20 38:45 39:20 3A:45 3B:20 3C:45 3D:20 3E:45 3F:20 40:45 41:20 42:45 43:20 44:45 45:20 46:45 47:20 48:45 49:20 4A:45 4B:20 4C:45 4D:20 4E:45 4F:20 50:45 51:20 52:45 53:20 54:45 55:20 56:45 57:20 58:45 59:20 5A:45 5B:20 5C:45 5D:20 5E:45 5F:20 60:45 61:20 62:45 63:20 64:45 65:20 66:45 67:20 68:45 69:20 6A:45 6B:20 6C:45 6D:20 6E:45 6F:20 70:45 71:20 72:45 73:20 74:45 75:20 76:45 77:20 78:45 79:20 7A:45 7B:20 7C:45 7D:20 7E:45 7F:20 80:45 81:20 82:45 83:20 84:45 85:20 86:45 87:20 88:45 89:20 8A:45 8B:20 8C:45 8D:20 8E:45 8F:20 90:45 91:20 92:45 93:20 94:45 95:20 96:45 97:20 98:45 99:20 9A:45 9B:20 9C:45 9D:20 9E:45 9F:20 A0:45 A1:20 A2:45 A3:20 A4:45 A5:20 A6:45 A7:20 A8:45 A9:20 AA:45 AB:20 AC:45 AD:20 AE:45 AF:20 B0:45 B1:20 B2:45 B3:20 B4:45 B5:20 B6:45 B7:20 B8:45 B9:20 BA:45 BB:20 BC:45 BD:20 BE:45 BF:20 C0:45 C1:20 C2:45 C3:20 C4:45 C5:20 C6:45 C7:20 C8:45 C9:20 CA:00 CB:00 CC:00 CD:00 CE:00 CF:00
     2019-07-07 14:40:09   boostTime       -
     2019-07-07 14:40:09   commReporting   off
     2019-07-07 14:40:09   controlMode     manual
     2019-07-07 14:55:15   desired-temp    off
     2019-07-07 14:55:15   humidity        63
     2019-07-07 14:55:15   measured-temp   24.0
     2019-07-06 20:35:17   peerList        EG_BA_HZG_RT_Climate,
     2019-07-07 13:47:38   recentStateType ack
     2019-07-07 14:55:15   state           T: 24.0 desired: off
     2019-07-06 20:34:26   tempTmplSet     EgBad
     2019-07-07 13:47:38   trigLast        fhem:81
     2019-07-07 14:40:09   winOpenReporting on
   helper:
     peerFriend peerRtTc
     peerOpt    p:thermostat
     regLst     1,7,8,9
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     role:
       chn        1
     shRegR:
       07         00
     shadowReg:
     tmpl:
   alias      EG Bad - Heizung - Temperaturcontroller Climate
   group      EG Bad - Heizung
   peerIDs    00000000,5FA4CA02,
   room       EG-Bad,Heizung,_HM
   sortby     04.02
   stateFormat {sprintf(
"Raumtemperatur: %.1f °C <br>Luftfeuchte: %.1f %% <br>Sollwert: %.1f °C",
ReadingsVal("$name","measured-temp",0),
ReadingsVal("$name","humidity",0),
ReadingsVal("$name","desired-temp",0))}
   tempListTmpl EgBad
Bei dem HM TC Geräten wird beim Ausschalten der Heizung set EG_BA_HZG_TC_Climate controlManu off ausgeführt.
Dadurch wird desired-temp mit off definiert.
Nachdem die desired-temp aber bei anderen Programmschritten weiter verwendet wird kommt unweigerlich zur Meldung Argument "off" isn't numeric.
Da muss ich mir noch etwas einfallen lassen.
LG Chris
amenomade
Zitatlist stateFormat=.*{.*
Das war dafür gedacht, die Devices zu finden, die ein stateFormat auf Perl haben, da die Fehlermeldung darauf deutet. Ich weiss nicht, warum es bei dir so viele Ergebnisse bringt. Bei mir hat es funktioniert.
Genau sowas habe ich gesucht.
Du könntest ReadingsVal durch ReadingsNum ersetzen. Damit solltest Du nur numerische Werte kriegen (und vermutlich 0 bei off)
Ansonsten mach nur eine String Konkatenierung.
attr <Device> stateFormat Raumtemperatur: measured-temp °C<br>Luftfeuchte: humidity %<br>Sollwert: desired-temp
oder auf Perl:
stateFormat { "Raumtemperatur: ".ReadingsVal("$name","measured-temp",0)." Luftfeuchte: ".ReadingsVal...}
Burny4600
Alles klar.
Danke für die Tipps.
Das werde ich in den nächsten Tagen gleich einmal abändern.
LG Chris
