SIP hat (vermutlich) Fhem-Neustart verursacht
Begonnen von Gisbert, 19 Dezember 2023, 13:51:09
Gisbert
Hallo Wzut und plin,
ich hatte folgenden Eintrag in einem SIP-Device, 1 Sekunde danach hat Fhem sich selbst neu gestartet.
2023.12.19 12:49:00.800 1:  blockCallcenter[835], can´t find my parent 625 in process list !
Died at .//FHEM/96_SIP.pm line 387.
Mein Device:
define blockCallcenter SIP
attr blockCallcenter history_file ./log/blockCallcenter.sip
attr blockCallcenter history_size 0
attr blockCallcenter sip_dtmf_loop once
attr blockCallcenter sip_dtmf_send audio
attr blockCallcenter sip_dtmf_size 2
attr blockCallcenter sip_elbc yes
attr blockCallcenter sip_filter <gelöscht/privat>
attr blockCallcenter sip_from sip:blockCallcenter@fritz.box
attr blockCallcenter sip_ip 192.168.xx.yyy
attr blockCallcenter sip_listen echo
attr blockCallcenter sip_port 5070
attr blockCallcenter sip_registrar 192.168.xx.yyy
attr blockCallcenter sip_ringtime 0.5
attr blockCallcenter sip_user blockCallcenter
#   CFGFN      ./FHEM/FritzboxUniFiAnwesenheit.cfg
#   FUUID      62d57d73-f33f-e986-8d1c-679f355437a1cd19
#   LPID       163084
#   NAME       blockCallcenter
#   NOTIFYDEV  global
#   NR         137
#   NTFY_ORDER 50-blockCallcenter
#   STATE      listen_echo
#   TYPE       SIP
#   VERSION    V1.92 / 21.03.2020
#   eventCount 22
#   READINGS:
#     2022-11-23 10:38:50   call            done
#     2022-11-23 10:38:50   call_attempt    0
#     2022-11-23 10:38:50   call_state      no answer
#     2022-11-23 10:38:50   call_success    0
#     2022-11-23 10:38:50   call_time       0
#     2023-09-21 09:08:48   caller          Gisbert sip:017644437623@fritz.box
#     2023-09-21 09:08:48   caller_name     Gisbert
#     2023-09-21 09:08:48   caller_nr       017644437623
#     2023-09-21 09:08:48   caller_state    ignoring
#     2023-09-21 09:08:48   caller_time     0
#     2023-12-19 13:41:53   expire          300
#     2023-09-11 13:26:55   last_error      ListenRegister: Failed with error Network is unreachable
#     2023-12-19 13:41:53   listen_alive    163084
#     2023-12-19 13:41:53   state           listen_echo
#   helper:
#     LISTEN_PID:
#       abortArg
#       abortFn
#       arg        blockCallcenter
#       bc_pid     3
#       finishFn   SIP_ListenDone
#       fn         SIP_ListenStart
#       pid        163084
#       timeout
#     bm:
#       SIP_Set:
#         cnt        10
#         dmx        -1000
#         dtot       0
#         dtotcnt    0
#         mTS        19.12. 13:41:53
#         max        0.00032806396484375
#         tot        0.00124526023864746
#         mAr:
#           HASH(0x559a88e09f88)
#           blockCallcenter
setstate blockCallcenter listen_echo
setstate blockCallcenter 2022-11-23 10:38:50 call done
setstate blockCallcenter 2022-11-23 10:38:50 call_attempt 0
setstate blockCallcenter 2022-11-23 10:38:50 call_state no answer
setstate blockCallcenter 2022-11-23 10:38:50 call_success 0
setstate blockCallcenter 2022-11-23 10:38:50 call_time 0
setstate blockCallcenter 2023-09-21 09:08:48 caller Gisbert sip:017644437623@fritz.box
setstate blockCallcenter 2023-09-21 09:08:48 caller_name Gisbert
setstate blockCallcenter 2023-09-21 09:08:48 caller_nr 017644437623
setstate blockCallcenter 2023-09-21 09:08:48 caller_state ignoring
setstate blockCallcenter 2023-09-21 09:08:48 caller_time 0
setstate blockCallcenter 2023-12-19 13:41:53 expire 300
setstate blockCallcenter 2023-09-11 13:26:55 last_error ListenRegister: Failed with error Network is unreachable
setstate blockCallcenter 2023-12-19 13:41:53 listen_alive 163084
setstate blockCallcenter 2023-12-19 13:41:53 state listen_echo
Viele Grüße Gisbert
Proxmox | UniFiRHASSPY | DEYE | JK-BMS | ESPHome | Panasonic Heishamon | Homematic, VCCU, HMUART | ESP8266 | ATtiny85 | Wasser-, Stromzähler | tuya local | Wlan-Kamera | SIGNALduino, Rauchmelder FA21/22RF
