[SOLVED] MQTT and MQTT2_DEVICE
Begonnen von bmentink, 02 September 2019, 02:01:58
Great to hear, things now work to your satisfaction :) .
I'd recommend to have two additional things to be changed, but if it's really the "final working version" in your eyes, I'm fine with that also ;) . Imo, the final thing should look nice in FHEMWEB, have three grafical elements to control it (also with grafical representation of the mode and pump status...) and having some additional text about solar and moisture data ::) .
Feel free to ask in case you need additional info about that (remember: this thread might serve as a showcase for others desiring docu in English language...)
Wrt to FTUI, as already mentionned, FUIP may help to get quick start.
Enjoy :) .
bmentink
And many thanks for helping me ... much appreciated  8)
You're welcome!
Would you mind marking this thread as [solved]? (Just edit the first post and change the title there).
