Revision 20344: mqtt2.template: fixes in shelly-washer example, add OpenMQTTGateway IR ...
Begonnen von System, 11 Oktober 2019, 08:45:19
System
mqtt2.template: fixes in shelly-washer example, add OpenMQTTGateway IR example
Source: Revision 20344: mqtt2.template: fixes in shelly-washer example, add OpenMQTTGateway IR ...
