30_HUEBridge.pm - deCONZ Bridge Modus
Begonnen von P.A.Trick, 29 Oktober 2019, 05:52:59
P.A.Trick
Hallo Andre,
ich benutze seit kurzem einen ConBeeII Stick und die Phoscon App als Bridge.
Was mir aufgefallen ist:
Wenn ich ein nach neuen Devices suche bekomme ich folgende Log Meldungen:
2019.10.29 05:49:45.615 1:     main::CallFn                        called by fhem.pl (754)
2019.10.29 05:49:45.615 1:     main::FW_Read                       called by fhem.pl (3754)
2019.10.29 05:49:45.614 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (582)
2019.10.29 05:49:45.614 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (956)
2019.10.29 05:49:45.613 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2685)
2019.10.29 05:49:45.613 1:     main::CommandCmdAlias               called by fhem.pl (1242)
2019.10.29 05:49:45.612 1:     main::CommandSet                    called by ./FHEM/98_cmdalias.pm (99)
2019.10.29 05:49:45.612 1:     main::DoSet                         called by fhem.pl (1928)
2019.10.29 05:49:45.611 1:     main::CallFn                        called by fhem.pl (1895)
2019.10.29 05:49:45.611 1:     main::HUEBridge_Set                 called by fhem.pl (3749)
2019.10.29 05:49:45.610 1:     main::HUEBridge_Call                called by ./FHEM/30_HUEBridge.pm (581)
2019.10.29 05:49:45.609 1:     main::HUEBridge_HTTP_Call2          called by ./FHEM/30_HUEBridge.pm (1554)
2019.10.29 05:49:45.609 1:     main::HUEBridge_ProcessResponse     called by ./FHEM/30_HUEBridge.pm (1680)
2019.10.29 05:49:45.609 1:     main::__ANON__                      called by ./FHEM/30_HUEBridge.pm (1465)
2019.10.29 05:49:45.608 1: stacktrace:
2019.10.29 05:49:45.607 1: PERL WARNING: Use of uninitialized value $l[3] in string eq at ./FHEM/30_HUEBridge.pm line 1465.
2019.10.29 05:49:45.606 1:     main::CallFn                        called by fhem.pl (754)
2019.10.29 05:49:45.606 1:     main::FW_Read                       called by fhem.pl (3754)
2019.10.29 05:49:45.605 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (582)
2019.10.29 05:49:45.604 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (956)
2019.10.29 05:49:45.603 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2685)
2019.10.29 05:49:45.603 1:     main::CommandCmdAlias               called by fhem.pl (1242)
2019.10.29 05:49:45.602 1:     main::CommandSet                    called by ./FHEM/98_cmdalias.pm (99)
2019.10.29 05:49:45.601 1:     main::DoSet                         called by fhem.pl (1928)
2019.10.29 05:49:45.600 1:     main::CallFn                        called by fhem.pl (1895)
2019.10.29 05:49:45.599 1:     main::HUEBridge_Set                 called by fhem.pl (3749)
2019.10.29 05:49:45.598 1:     main::HUEBridge_Call                called by ./FHEM/30_HUEBridge.pm (581)
2019.10.29 05:49:45.598 1:     main::HUEBridge_HTTP_Call2          called by ./FHEM/30_HUEBridge.pm (1554)
2019.10.29 05:49:45.597 1:     main::HUEBridge_ProcessResponse     called by ./FHEM/30_HUEBridge.pm (1680)
2019.10.29 05:49:45.596 1:     main::__ANON__                      called by ./FHEM/30_HUEBridge.pm (1465)
2019.10.29 05:49:45.596 1: stacktrace:
2019.10.29 05:49:45.595 1: PERL WARNING: Use of uninitialized value $l[3] in string eq at ./FHEM/30_HUEBridge.pm line 1465.
Weiterhin tauchen im Log folgende Meldungen auf:
2019.10.29 05:48:54.005 3: deCONZ: websocket: Switching Protocols ok
2019.10.29 05:48:53.966 4: deCONZ: message for unknown sensor received: deCONZ-S4
2019.10.29 05:48:53.966 4: deCONZ: message for unknown sensor received: deCONZ-S7
2019.10.29 05:48:53.966 4: deCONZ: message for unknown sensor received: deCONZ-S9
2019.10.29 05:48:53.965 4: deCONZ: message for unknown sensor received: deCONZ-S3
2019.10.29 05:48:53.965 4: deCONZ: message for unknown sensor received: deCONZ-S6
2019.10.29 05:48:53.964 4: deCONZ: message for unknown sensor received: deCONZ-S1
2019.10.29 05:48:53.964 4: deCONZ: message for unknown sensor received: deCONZ-S8
2019.10.29 05:48:53.963 4: deCONZ: message for unknown sensor received: deCONZ-S5
Version:
30_HUEBridge.pm 19854 2019-07-19 13:04:29Z justme1968
Aufgefallen ist mir noch, dass Sensoren scheinbar keinen Status senden z.b. der Tradfri Motion Sensor.
Any idea?
FHEM + Homeassistant - meine HW -> https://www.trinityonline.de/hardware/
P.A.Trick
Ich Depp - man muss sie manuell einrichten:
define <Name> HUEDevice sensor <ID>
Argghhhhh
