Warnungen nach Fhem update
Begonnen von Steffen@Home, 16 November 2019, 18:19:47
Steffen@Home
Ich habe hier zwei Meldungen nach meinem FHEM update die ich nicht verstehe... die attribute sehe ich nicht in den Devices.
Jemand eine Ahnung? Danke.
Messages collected while initializing FHEM:
configfile: anyViews: unknown attribute dashboard_activetab. Type 'attr anyViews ?' for a detailed list.
dbLogMaria: unknown attribute shutdownWait. Type 'attr dbLogMaria ?' for a detailed list.
Autosave deactivated
List dbLogMaria
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./maria10.conf
   DEF        ./maria10.conf .*:.*
   FUUID      5dd021af-f33f-e478-edcf-f4b060117ed59ca1
   FVERSION   93_DbLog.pm:v4.8.0-s20445/2019-11-03
   MODE       asynchronous
   MODEL      MYSQL
   NAME       dbLogMaria
   NR         142
   NTFY_ORDER 50-dbLogMaria
   PID        3184
   REGEXP     .*:.*
   STATE      connected
   TYPE       DbLog
   UTF8       1
   dbconn     mysql:database=fhem;host=192.168.1.120;port=3307
   dbuser     fhem
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    4.8.0
     2019-11-16 17:24:08   CacheUsage      0
     2019-11-16 17:24:08   NextSync        2019-11-16 17:24:38 or if CacheUsage 2500 reached
     2019-11-16 17:21:39   background_processing_time 0.5348
     2019-11-16 17:21:39   sql_processing_time 0.5047
     2019-11-16 17:24:08   state           connected
   DbLogSelectionMode Exclude
   DbLogType  Current/History
   alias      DbLog Maria10 NAS
   asyncMode  1
   cacheEvents 2
   cacheLimit 2500
   excludeDevs TYPE=DbLog,global
   group      SystemInfo
   icon       it_remote_folder
   room       zzSystem
   showproctime 1
   verbose    2
List Anyview:
   FUUID      5dd021ac-f33f-e478-4ea8-3f928ab1108d2be4
   FVERSION   95_Dashboard.pm:v3.17.0-s20323/2019-10-06
   NAME       anyViews
   NR         42
   STATE      Initialized
   TYPE       Dashboard
   HELPER:
     FW         WEB,WEBphone,WEBtablet
     PACKAGE    main
     VERSION    3.17.0
     2018-12-28 15:42:02   lockstate       lock
     2019-11-16 17:19:56   state           Initialized
   alias      Dashboard
   dashboard_tab1groups Diagramme
   dashboard_tab1name Diagramme
   dashboard_tab1sorting t0c0,Diagramme,true,820,0,0,0:
   dashboard_tab2groups Dash_temp, Heizung Info, Dash_Wochenplan
   dashboard_tab2name Temperaturen
   dashboard_tab2sorting t1c0,Dash_temp,true,384,0,0,0:t1c0,Heizung Info,true,826,0,0,329:t1c0,Dash_Wochenplan,true,826,0,0,576:
   dashboard_tab3groups Dash_Main, Heizung Steuerung, Medien, Aussen, Garage Ost, Garage West, Haus
   dashboard_tab3name Funktionen
   dashboard_tab3sorting t2c0,Dash_Main,true,177,0,1,1:t2c0,Heizung Steuerung,true,269,0,178,1:t2c0,Medien,true,854,0,1,172:t2c0,Garage Ost,true,438,0,1,451:t2c0,Garage West,true,417,196,439,451:t2c0,Aussen,true,439,0,1,647:t2c0,Haus,true,417,0,440,647:
   dashboard_tab4groups SystemInfo, Geräte Zustand
   dashboard_tab4name System
   dashboard_tab4sorting t3c0,SystemInfo,true,0,0:t3c0,BattStatus,true,0,0:t3c0,Geräte Zustand,true,0,0:
   dashboard_tab5devices LiveCam1,LiveCam2,IPCam3
   dashboard_tab5name Kameras
   dashboard_tab5sorting t4c0,LiveCam1,true,816,0,0,0:t4c0,LiveCam2,true,815,0,0,629:t4c0,IPCam3,true,0,0:
   dashboard_tab6groups Fritzbox
   dashboard_tab6name FritzBox
   dashboard_width 80%
   icon       shutter_halfopen
   userattr   dashboard_homeTab:1,2,3,4,5,6 dashboard_tab2backgroundimage dashboard_tab2colcount dashboard_tab2devices dashboard_tab2groups dashboard_tab2icon dashboard_tab2name dashboard_tab2rowcentercolwidth dashboard_tab2sorting dashboard_tab3backgroundimage dashboard_tab3colcount dashboard_tab3devices dashboard_tab3groups dashboard_tab3icon dashboard_tab3name dashboard_tab3rowcentercolwidth dashboard_tab3sorting dashboard_tab4backgroundimage dashboard_tab4colcount dashboard_tab4devices dashboard_tab4groups dashboard_tab4icon dashboard_tab4name dashboard_tab4rowcentercolwidth dashboard_tab4sorting dashboard_tab5backgroundimage dashboard_tab5colcount dashboard_tab5devices dashboard_tab5groups dashboard_tab5icon dashboard_tab5name dashboard_tab5rowcentercolwidth dashboard_tab5sorting dashboard_tab6backgroundimage dashboard_tab6colcount dashboard_tab6devices dashboard_tab6groups dashboard_tab6icon dashboard_tab6name dashboard_tab6rowcentercolwidth dashboard_tab6sorting dashboard_tab7backgroundimage dashboard_tab7colcount dashboard_tab7devices dashboard_tab7groups dashboard_tab7icon dashboard_tab7name dashboard_tab7rowcentercolwidth dashboard_tab7sorting dashboard_webRefresh:multiple-strict,WEB,WEBphone,WEBtablet
Pi 1 - FHEM, HM-MOD-RPI-PCB, HM-RT-CC-DN, HM-WDS10-TH-O, HM-Sec-SCo, HM-LC-Sw1PBU-FM, Relais Platine für ext. Ansteuerung, LD382 Wifi LED Controller, DHT
Pi 2 - Kamera, DHT
Pi 3 - FHEM2, Grafana, DHT, Magnet-Sensoren, Relais-Platine
CoolTux
Einfach save drücken und gut ist. Sollte es noch mal kommen steht es sicherlich in der message to day. Dann im Device global schauen.
Das TuxNet Wiki:
https://www.cooltux.net
Steffen@Home
Pi 2 - Kamera, DHT
