HM-MOD-EM-8 liefert seit kurzem komische Werte ala "Short 1_181 (to broadcast)"
Begonnen von chunter1, 30 Januar 2020, 08:58:00
chunter1
Seit kurzem liefert mein HM-MOD-EM-8 komische Werte wie z.B. "Short 1_181 (to broadcast)"
In den Readings steht eine Kilometer lange Liste von Einträgen siehe unten:
Auf dem Eingang hängt ein Optokoppler der die 230V vom Ölbrenner überwacht.
Hat wer eine Idee woher plötzlich diese Einträge kommen?
Long_1_0_(to_broadcast): 00:00:25 Long_1_0_(to_broadcast)_Count: 9 Long_1_100_(to_broadcast): 00:00:32 Long_1_100_(to_broadcast)_Count: 11 Long_1_101_(to_broadcast): 00:00:26 Long_1_101_(to_broadcast)_Count: 13 Long_1_102_(to_broadcast): 00:00:08 Long_1_102_(to_broadcast)_Count: 10 Long_1_103_(to_broadcast): 00:00:32 Long_1_103_(to_broadcast)_Count: 12 Long_1_104_(to_broadcast): 00:00:28 Long_1_104_(to_broadcast)_Count: 9 Long_1_105_(to_broadcast): 00:00:25 Long_1_105_(to_broadcast)_Count: 9 Long_1_106_(to_broadcast): 00:00:12 Long_1_106_(to_broadcast)_Count: 11 Long_1_107_(to_broadcast): 00:08:29 Long_1_107_(to_broadcast)_Count: 12 Long_1_108_(to_broadcast): 00:00:18 Long_1_108_(to_broadcast)_Count: 10 Long_1_109_(to_broadcast): 00:00:23 Long_1_109_(to_broadcast)_Count: 13 Long_1_10_(to_broadcast): 00:00:14 Long_1_10_(to_broadcast)_Count: 11 Long_1_110_(to_broadcast): 00:00:18 Long_1_110_(to_broadcast)_Count: 14 Long_1_111_(to_broadcast): 00:00:11 Long_1_111_(to_broadcast)_Count: 12 Long_1_112_(to_broadcast): 00:00:13 Long_1_112_(to_broadcast)_Count: 11 Long_1_113_(to_broadcast): 00:00:13 Long_1_113_(to_broadcast)_Count: 10 Long_1_114_(to_broadcast): 00:00:25 Long_1_114_(to_broadcast)_Count: 13 Long_1_115_(to_broadcast): 00:00:34 Long_1_115_(to_broadcast)_Count: 11 Long_1_116_(to_broadcast): 00:00:13 Long_1_116_(to_broadcast)_Count: 13 Long_1_117_(to_broadcast): 00:00:16 Long_1_117_(to_broadcast)_Count: 13 Long_1_118_(to_broadcast): 00:00:30 Long_1_118_(to_broadcast)_Count: 14 Long_1_119_(to_broadcast): 00:00:15 Long_1_119_(to_broadcast)_Count: 12 Long_1_11_(to_broadcast): 00:00:20 Long_1_11_(to_broadcast)_Count: 10 Long_1_120_(to_broadcast): 00:00:31 Long_1_120_(to_broadcast)_Count: 12 Long_1_121_(to_broadcast): 00:00:18 Long_1_121_(to_broadcast)_Count: 13 Long_1_122_(to_broadcast): 00:00:16 Long_1_122_(to_broadcast)_Count: 10 Long_1_123_(to_broadcast): 00:00:10 Long_1_123_(to_broadcast)_Count: 10 Long_1_124_(to_broadcast): 00:00:15 Long_1_124_(to_broadcast)_Count: 12 Long_1_125_(to_broadcast): 00:00:09 Long_1_125_(to_broadcast)_Count: 9 Long_1_126_(to_broadcast): 00:00:15 Long_1_126_(to_broadcast)_Count: 12 Long_1_127_(to_broadcast): 00:00:26 Long_1_127_(to_broadcast)_Count: 8 Long_1_128_(to_broadcast): 00:00:09 Long_1_128_(to_broadcast)_Count: 12 Long_1_129_(to_broadcast): 00:00:08 Long_1_129_(to_broadcast)_Count: 12 Long_1_12_(to_broadcast): 00:00:43 Long_1_12_(to_broadcast)_Count: 10 Long_1_130_(to_broadcast): 00:00:13 Long_1_130_(to_broadcast)_Count: 14 Long_1_131_(to_broadcast): 00:00:19 Long_1_131_(to_broadcast)_Count: 10 Long_1_132_(to_broadcast): 00:00:31 Long_1_132_(to_broadcast)_Count: 9 Long_1_133_(to_broadcast): 00:00:29 Long_1_133_(to_broadcast)_Count: 12 Long_1_134_(to_broadcast): 00:00:12 Long_1_134_(to_broadcast)_Count: 13 Long_1_135_(to_broadcast): 00:01:02 Long_1_135_(to_broadcast)_Count: 13 Long_1_136_(to_broadcast): 00:19:57 Long_1_136_(to_broadcast)_Count: 12 Long_1_137_(to_broadcast): 00:00:21 Long_1_137_(to_broadcast)_Count: 14 Long_1_138_(to_broadcast): 00:00:18 Long_1_138_(to_broadcast)_Count: 11 Long_1_139_(to_broadcast): 00:00:38 Long_1_139_(to_broadcast)_Count: 11 Long_1_13_(to_broadcast): 00:00:11 Long_1_13_(to_broadcast)_Count: 9 Long_1_140_(to_broadcast): 00:04:04 Long_1_140_(to_broadcast)_Count: 11 Long_1_141_(to_broadcast): 00:00:19 Long_1_141_(to_broadcast)_Count: 11 Long_1_142_(to_broadcast): 00:00:19 Long_1_142_(to_broadcast)_Count: 9 Long_1_143_(to_broadcast): 00:00:21 Long_1_143_(to_broadcast)_Count: 11 Long_1_144_(to_broadcast): 00:00:11 Long_1_144_(to_broadcast)_Count: 13 Long_1_145_(to_broadcast): 00:00:28 Long_1_145_(to_broadcast)_Count: 13 Long_1_146_(to_broadcast): 00:00:19 Long_1_146_(to_broadcast)_Count: 7 Long_1_147_(to_broadcast): 00:00:37 Long_1_147_(to_broadcast)_Count: 10 Long_1_148_(to_broadcast): 00:00:09
in den Readings? hast Du mal ein list anstatt nur ein Fragment?
Short 1_181 (to broadcast) ist ein völlig normaler Eintrag wenn Du ihn als Taster programmiert hast. Kurzer Tastendruck, kein Peer (deswegen broadcast)
chunter1
Hier das list eines Einganges (nutze wie man sieht das statistics modul).
Die Zeilen der Readings sind ewiglang darum hab ich sie ab "..." gekürzt.
   DEF        XXXXXXXX
   FUUID      XXXXXXXX-XXXX-XXX....
   NAME       K_K_HEI_8IN_Eingangsmodul_Btn_01
   NOTIFYDEV  global
   NR         99
   NTFY_ORDER 50-K_K_HEI_8IN_Eingangsmodul_Btn_01
   STATE      Short 1_201 (to broadcast)
   TYPE       CUL_HM
   chanNo     01
   device     K_K_HEI_8IN_Eingangsmodul
     2020-01-30 12:51:59   statStateDay    Long_1_0_(to_broadcast): 00:00:28 Long_1_0_(to_broadcast)_Count: ...
     2020-01-29 23:59:55   statStateDayLast Long_1_0_(to_broadcast): 00:00:01 Long_1_0_(to_broadcast)_Count: ...
     2020-01-29 23:59:55   statStateDayclosed 00:00:00
     2020-01-29 23:59:55   statStateDayclosedLast 12:02:45
     2020-01-29 23:59:55   statStateDayclosed_Count 0
     2020-01-29 23:59:55   statStateDayclosed_CountLast 92
     2020-01-30 12:51:59   statStateHour   Long_1_100_(to_broadcast): 00:00:01 Long_1_100_(to_broadcast)_Count: ...
     2020-01-30 11:59:55   statStateHourLast Long_1_100_(to_broadcast): 00:00:00 Long_1_100_(to_broadcast)_Count: ...
     2020-01-30 12:51:59   statStateMonth  Long_1_0_(to_broadcast): 00:00:29 Long_1_0_(to_broadcast)_Count: ...
     2020-01-30 12:51:59   statStateYear   Long_1_0_(to_broadcast): 00:00:34 Long_1_0_(to_broadcast)_Count: ...
     2020-01-30 12:51:59   state           Short 1_201 (to broadcast)
     2020-01-30 12:51:59   trigger         Short_201
     2020-01-30 12:51:59   trigger_cnt     201
   helper:
     BNO        201
     BNOCNT     1
     _98_statistics myStatDevice
     getCfgList all
     getCfgListNo ,4
     peerFriend peerAct,peerVirt
     peerOpt    4:remote
     regLst     1,4p
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     tmpl:
   model      HM-MOD-EM-8
   peerIDs    00000000,
peterk_de
Du musst das Teil irgendwie umgestellt haben - was du willst, ist dass als Schließkontakt agiert (meldet nur open/closed), es hat sich bei dir aber irgendwie in den Taster-Modus versetzt (Kontakt geschlossen --> Dauerfeuer an Nachrichten mit Longpress...)
Du musst es also wieder in den anderen Modus bringen:
set EM-8-channel regSet triggerMode sensor
siehe auch https://wiki.fhem.de/wiki/HM-MOD-EM-8_8-Kanal-Sendemodul
FHEM auf Ubuntu-VM / 2xNUC Proxmox Cluster
UI: HomeKit, TabletUI, Grafana
IOdevs: 2xHueBridge, RaspiMatic-CCU, CUL868, 2xHarmonyHub, 6xRaspi-Roomnode mit CO2, VOC und lepresenced
Devices: 107xHomematic(IP), 96xPhilips Hue, 17xTECHEM, 12xBTLE, 8xSONOS, 2xHomeConnect, 1xShelly 3em, 1xNanoleaf ...
chunter1
Danke, das ist ein wertvoller Tip!
Allerdings ignoriert er jeglichen Versuch einen Kanal wieder in den sensor-mode zu setzen.
Hab schon in Kombination mit einem power-cycle und Reset versucht... hilft alles nix :(
Die Frage ist nach wie vor... wieso hat er den mode umgestellt und wie komm ich wieder zurück in den mode?...
Folgender Befehl schaltet alle Kanäle in den "sensor" Modus. RC81 ist mein Devicename!!!
set RC81_.* regSet triggerMode sensor
Reset und Power Cycle ist "Quark"
peterk_de
Klingt für mich danach, dass er entweder durch irgendwas in den Factory-Modus zurückgesetzt wurde. Im Auslieferungszustand ist er nämlich in eben diesem Taster-Modus. Und natürlich vergisst er durch einen Factory-Reset dann auch das Pairing - und nimmt keine Befehle mehr an.
... ODER du hast vergessen, dass der HM-MOD-EM-8 nach dem Absetzen des Konfigurationsbefehls nen Druck auf die Config-Taste braucht ;)
Versuche ihn also ggf. mal erneut zu pairen (das Haupt-device, nicht den Channel) bzw. den set-Befehl mit der Configtaste zu bestätigen. Wenn das beides nicht hilft, poste mal ein list vom Haupt-Device (nicht dem Channel von dem klemmenden Button)
chunter1
WAAAAHHHH Config Taste drücken!!!!!!
Ok, das muss ich morgen probieren.
Das Gerät und mich trennen aktuell 16 km :)
chunter1
Nach dem Drücken der Taste am Gerät sind die Eingänge jetzt wieder im "sensor" mode. --> Problem gelöst!
Vielen Dank euch nochmal für die rasche Hilfe!! ;)
