Sduino Fehler beim fhem Update | ERROR: FHEM/00_SIGNALduino.pm
Begonnen von Burny4600, 02 Februar 2020, 12:54:28
Burny4600
Das aktuelle FHEM Update mit Sduino ist fehlerhaft und wird nicht ausgeführt.
2020.02.02 12:35:57.251 1: Downloading http://www.wallmeier.net/fhem/controls_I2C_SUSV.txt
2020.02.02 12:35:57.253 1: FHEM::Meta::__GetUpdatedata: ERROR: FHEM/00_SIGNALduino.pm belongs to source repository "fhem". Ignoring identical file name from source repository signalduino
2020.02.02 12:35:57.262 1: FHEM::Meta::__GetUpdatedata: ERROR: FHEM/14_SD_UT.pm belongs to source repository "fhem". Ignoring identical file name from source repository signalduino
2020.02.02 12:36:00.063 2: backup include:
2020.02.02 12:36:00.065 2: backup include: /media/hdd/fhem/logtest/fhem.save
2020.02.02 12:36:00.091 2: Backup with command: tar czf /media/hdd/Backup/ccs-ht-rasptest/opt/fhem/restoreDir/FHEM-20200202_123559.tar.gz "/media/hdd/fhem/mycfg/Modbus/smd630_rasptest.cfg" "./fhem.cfg.demo" "./MAINTAINER.txt" "./contrib" "./demolog" "./shutdown restart" "/media/hdd/fhem/mycfg/schnittstellen_rasptest.cfg" "./README_DEMO.txt" "./fhem.pl" "/media/hdd/fhem/mycfg/FHEM2FHEM/f2f_rasptest.cfg" "./www" "/media/hdd/fhem/logtest/system" "/media/hdd/fhem/logtest/ph_t_lw" "/media/hdd/fhem/zeitplaene/zeitplaene_rasptest.pm" "./docs" "./restoreDir" "/media/hdd/fhem/mycfg/USV/usv_rasptest.cfg" "./certs" "./fhem.cfg" "./FHEM" "/media/hdd/fhem/logtest/wetter" "/media/hdd/fhem/mycfg/ph_lw_do/phtlw_rasptest.cfg" "/media/hdd/fhem/mycfg/AD_Controller/I2C_MCP23017_rasptest.cfg" "/media/hdd/fhem/logtest/fhem.save" "./configDB.pm" "./CHANGED" "/media/hdd/fhem/logtest/autocreate" "./unused" "/media/hdd/fhem/logtest" "/media/hdd/fhem/mycfg/Resol/Resol_DL2_rasptest.cfg" "./log" "/media/hdd/fhem/myprogram/reset_rasptest.pm" "./_fhem.cfg" "/media/hdd/fhem/logtest/resol"
2020.02.02 12:41:33.306 1: backup tar: Entferne führende ,,/" von Elementnamen tar: Entferne führende ,,/" von Zielen harter Verknüpfungen tar: /media/hdd/fhem/logtest/energiezaehler: Datei hat sich beim Lesen geändert.
2020.02.02 12:41:33.387 1: backup done: FHEM-20200202_123559.tar.gz (177760385 Bytes)
2020.02.02 12:41:33.392 1:
2020.02.02 12:41:33.393 1: I2C_SUSV
2020.02.02 12:41:33.606 1: nothing to do...
2020.02.02 12:41:33.611 1: Downloading https://fhem.de/fhemupdate/controls_fhem.txt
2020.02.02 12:41:33.613 1:
2020.02.02 12:41:33.614 1: fhem
2020.02.02 12:41:35.119 1: UPD FHEM/00_SIGNALduino.pm
2020.02.02 12:41:35.121 1: UPD FHEM/10_FS10.pm
2020.02.02 12:41:35.122 1: UPD FHEM/14_SD_RSL.pm
2020.02.02 12:41:35.133 1: UPD FHEM/14_SD_WS.pm
2020.02.02 12:41:35.237 1: UPD FHEM/14_SD_WS09.pm
2020.02.02 12:41:35.303 1: UPD FHEM/14_SD_WS_Maverick.pm
2020.02.02 12:41:35.414 1: UPD FHEM/41_OREGON.pm
2020.02.02 12:41:35.564 1: UPD FHEM/90_SIGNALduino_un.pm
2020.02.02 12:41:35.713 1: UPD FHEM/lib/SD_ProtocolData.pm
2020.02.02 12:41:36.474 1: saving fhem.cfg
2020.02.02 12:41:36.485 1:
2020.02.02 12:41:36.499 1: Downloading https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r34/controls_signalduino.txt
2020.02.02 12:41:36.506 1:
2020.02.02 12:41:36.508 1: signalduino
2020.02.02 12:41:38.007 1: UPD FHEM/00_SIGNALduino.pm
2020.02.02 12:41:39.048 1: UPD FHEM/10_FS10.pm
2020.02.02 12:41:39.050 1: UPD FHEM/14_SD_RSL.pm
2020.02.02 12:41:39.052 1: UPD FHEM/14_SD_WS.pm
2020.02.02 12:41:39.053 1: UPD FHEM/14_SD_WS09.pm
2020.02.02 12:41:39.179 1: UPD FHEM/14_SD_WS_Maverick.pm
2020.02.02 12:41:39.568 1: UPD FHEM/41_OREGON.pm
2020.02.02 12:41:39.807 1: UPD FHEM/90_SIGNALduino_un.pm
2020.02.02 12:41:40.031 1: UPD FHEM/lib/SD_ProtocolData.pm
2020.02.02 12:41:41.133 1: saving fhem.cfg
2020.02.02 12:41:41.135 1:
2020.02.02 12:41:41.136 1: New entries in the CHANGED file:
2020.02.02 12:41:41.138 1: 2020-01-30 - bug fix set/get cc1101_patable (#789)
2020.02.02 12:41:41.139 1: Calling /usr/bin/perl ./contrib/commandref_join.pl -noWarnings, this may take a while
2020.02.02 12:42:19.077 1: *** EN FHEM/50_Elster.pm: ignoring text due to DOS encoding
2020.02.02 12:42:19.079 1: *** DE FHEM/50_Elster.pm: ignoring text due to DOS encoding
2020.02.02 12:42:19.081 1:
2020.02.02 12:42:19.083 1: update finished, "shutdown restart" is needed to activate the changes.
2020.02.02 12:42:19.088 1:
2020.02.02 12:42:20.175 1: fheminfo Statistics data sent to server. See Logfile (level 4) for details.
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
elektron-bbs
Intel(R) Atom(TM) CPU N270 mit 2 SIGNALduino nanoCC1101 + ESPEasy 2x serial server SIGNALduino nanoCC1101, Raspberry Pi 2 mit 2 CUL Stackable CC1101, Raspberry Pi 3 mit SIGNALduino radino + nano328 + 2 x SIGNAL-ESP CC1101 + 1 x rf_Gateway + 1 x SIGNAL-STM
Burny4600
Eigenartig.
Ein Fehler der kein Fehler ist.
Es werden aber die angezeigten Dateien auch nicht aktualisiert.
Jeder Updateaufruf zweigt die angeführten Dateien wieder an.
LG Chris
HomeAuto_User
#3
da dies auch bei mir schon für Verwirrung sorgte, habe ich den Maintainer angeschrieben und es hinterfragt.
Ich zitiere Loredo:
ZitatDie Meldung besagt, dass diese Dateien in mehr als nur einer Update Controls Datei stehen und angenommen wird, dass diese zu FHEM Core Code gehören, da sie von dort zuerst ausgeliefert werden.
Er soll informieren, dass man hier womöglich Dateiversionen läd, die nicht dem Original entspricht.
Da der FHEM Installer derzeit noch keine FHEM Module updaten kann, ist das derzeit nur ein Hinweis ohne konkrete Folgen.
Die wohl richtig Aktion wäre sich bei der Auslieferung der Module für eines der Quellen zu entscheiden.
Vielleicht kann man den Text anpassen um keine Verwirrung zu stiften.
Sehen wir diese Aufklärung zugleich als Diskussionsanregung.
Edit:
Man sollte vielleicht für den Fall, das es 2 Orte des Modules zur Aktualisierung gibt, eine Möglichkeit finden.
Ich als Maintainer habe Bsp. das SVN immer als "stable" gesehen wenn ich etwas hochgeladen habe. Die Quelle auf Github hingegen ist dann ein Pre-release und so kommt der Fall, das man 2 unterschiedliche Bezugsquellen besitzt.
"Developer" heißt nicht, das man alles wissen kann!
- FHEM v5.9 | Rasberry PI 3
- radino CC1101 433Mhz (SIGNALduino)| - radino CC1101 868Mhz (CUL) | nano 433Mhz (SIGNALduino) - Sensoren: purer Dschungel querbeet
