[GELÖST] FHEM Startfehler nach reboot - Speicher voll
Begonnen von crazystone, 10 Februar 2020, 15:12:41
crazystone
Danke Sabine heute hat mein RPi wohl mehrfach rebootet. Seitdem startet fhem nicht mehr.
pi@rpi:~ $ systemctl status fhem.service
● fhem.service - FHEM Home Automation
   Loaded: loaded (/etc/systemd/system/fhem.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-02-10 15:06:49 CET; 2min 32s ago
  Process: 1811 ExecStart=/usr/bin/perl fhem.pl fhem.cfg (code=exited, status=28)
      CPU: 348ms
Feb 10 15:06:49 rpi systemd[1]: fhem.service: Unit entered failed state.
Feb 10 15:06:49 rpi systemd[1]: fhem.service: Failed with result 'exit-code'.
Feb 10 15:06:49 rpi systemd[1]: fhem.service: Service hold-off time over, scheduling restart.
Feb 10 15:06:49 rpi systemd[1]: Stopped FHEM Home Automation.
Feb 10 15:06:49 rpi systemd[1]: fhem.service: Start request repeated too quickly.
Feb 10 15:06:49 rpi systemd[1]: Failed to start FHEM Home Automation.
und beim versuch es zu re-starten
pi@rpi:~ $ sudo service fhem restart
Job for fhem.service failed because the control process exited with error code.
See "systemctl status fhem.service" and "journalctl -xe" for details.
pi@rpi:~ $ journalctl -xe
Feb 10 15:10:12 rpi systemd[1]: fhem.service: Failed with result 'exit-code'.
Feb 10 15:10:12 rpi systemd[1]: fhem.service: Service hold-off time over, scheduling restart.
Feb 10 15:10:12 rpi systemd[1]: Stopped FHEM Home Automation.
-- Subject: Unit fhem.service has finished shutting down
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit fhem.service has finished shutting down.
Feb 10 15:10:12 rpi systemd[1]: Starting FHEM Home Automation...
-- Subject: Unit fhem.service has begun start-up
-- Unit fhem.service has begun starting up.
Feb 10 15:10:13 rpi perl[1953]: Can't open ./log/fhem-2020-02.log: No space left on device at fhem.pl line 2767.
Feb 10 15:10:13 rpi systemd[1]: fhem.service: Control process exited, code=exited status=28
Feb 10 15:10:13 rpi systemd[1]: Failed to start FHEM Home Automation.
-- Subject: Unit fhem.service has failed
-- Unit fhem.service has failed.
-- The result is failed.
Feb 10 15:10:13 rpi systemd[1]: fhem.service: Unit entered failed state.
Feb 10 15:10:13 rpi systemd[1]: fhem.service: Failed with result 'exit-code'.
Feb 10 15:10:13 rpi systemd[1]: fhem.service: Service hold-off time over, scheduling restart.
Feb 10 15:10:13 rpi systemd[1]: Stopped FHEM Home Automation.
Feb 10 15:10:13 rpi systemd[1]: fhem.service: Start request repeated too quickly.
Hilfe...
binford6000
Evtl. kein Platz mehr?
Frank_Huber
Partition korrupt?
Herunterfahren, Karten in anderes Linux Gerät stecken und Dateisystem prüfen.
Gesendet von meinem Doogee S60 mit Tapatalk
Wernieman
Ne .. was dort wortwörtlich steht:
No space left
Also einfach mal aufräumen ...
- Bitte um Input für Output
Frank_Huber
No space left
wenn Die Partition nicht durch Fehler auf Read Only steht.
Oder kommt da nen anderer Fehler?
Plötzlicher Stromausfall ist ja Partitionskiller #1 bei de RPI...
crazystone
#5
Wo finde ich den "./log" auf dem RPi?
pi@rpi:/ $ df -h
Dateisystem         Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root            3,7G    3,5G     0  100% /
devtmpfs             459M       0  459M    0% /dev
tmpfs                464M       0  464M    0% /dev/shm
tmpfs                464M     13M  451M    3% /run
tmpfs                5,0M    4,0K  5,0M    1% /run/lock
tmpfs                464M       0  464M    0% /sys/fs/cgroup
/dev/mmcblk0p1        44M     23M   21M   52% /boot
tmpfs                 93M       0   93M    0% /run/user/1000
Eigentlich zeigt er mir ja noch Rest an, auch wenn total bei 100% steht. Gern lösche ich mal alle FHEM Logs, brauche die nichtm, wenn ich sie nur finde...
Danke!
crazystone
#6
Selber gefunden  :D
/opt/fhem/log
Nach dem Löschen:
pi@rpi:~ $ df -h
/dev/root            3,7G    2,6G  962M   73% /
//server/TempVolume  1,8T    238G  1,5T   14% /home/pi/TempVolume
pi@rpi:~ $ service fhem status
   Active: active (running) since Mon 2020-02-10 16:11:58 CET; 1min 30s ago
  Process: 551 ExecStart=/usr/bin/perl fhem.pl fhem.cfg (code=exited, status=0/SUCCESS)
Main PID: 734 (perl)
    Tasks: 12 (limit: 4915)
   Memory: 101.6M
      CPU: 18.318s
   CGroup: /system.slice/fhem.service
           ├─ 734 /usr/bin/perl fhem.pl fhem.cfg
           ├─1298 node /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg
           └─1368 /usr/bin/ssh -R 1234:127.0.0.1:44379 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
Feb 10 16:11:56 rpi systemd[1]: Starting FHEM Home Automation...
Feb 10 16:11:58 rpi systemd[1]: Started FHEM Home Automation.
Alles in Butter! Danke nochmals!
