Gosund SP112
Begonnen von jbraeu, 08 Februar 2020, 17:32:49
jbraeu
ich kriege o.g. einfach nicht ans laufen, kann jemand helfen?
Info: Das Teil wurde per autocreate angelegt am tasmota kann ich einwandfrei beide Power schalten (230v und 5v usb) aber von fhem aus nicht?
hier die autoconfig:
########### Gosund SP 112    ##############################
define MQTT2_Gosund_SP112 MQTT2_DEVICE Gosund_SP112
setuuid MQTT2_Gosund_SP112 5e3edcb4-f33f-20ab-7d89-b1294f58112805ab
attr MQTT2_Gosund_SP112 IODev m2server
attr MQTT2_Gosund_SP112 autocreate 0
attr MQTT2_Gosund_SP112 comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10;; 'cmnd/CMNDTOPIC/Backlog POWER1 1;; delay '.$duration.';; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
attr MQTT2_Gosund_SP112 icon hue_filled_outlet
attr MQTT2_Gosund_SP112 jsonMap POWER1:0 POWER2:0 POWER3:0 POWER4:0 Dimmer:0 Channel_0:0 Channel_1:0 Channel_2:0 Channel_3:0 Channel_4:0 HSBColor:0 Color:0
attr MQTT2_Gosund_SP112 model tasmota_basic_state_power1
attr MQTT2_Gosund_SP112 readingList TELETOPIC/LWT:.* LWT\
  TELETOPIC/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  TELETOPIC/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  TELETOPIC/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  TELETOPIC/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  TELETOPIC/POWER1:.* state\
  STATTOPIC/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_Gosund_SP112 room MQTT2_DEVICE
attr MQTT2_Gosund_SP112 setList off:noArg    CMNDTOPIC/POWER1 0\
  on:noArg     CMNDTOPIC/POWER1 1\
  toggle:noArg CMNDTOPIC/POWER1 2\
  setOtaUrl:textField CMNDTOPIC/OtaUrl $EVTPART1\
  upgrade:noArg   CMNDTOPIC/upgrade 1
attr MQTT2_Gosund_SP112 setStateList on off toggle
define FileLog_MQTT2_Gosund_SP112 FileLog ./log/MQTT2_Gosund_SP112-%Y.log MQTT2_Gosund_SP112
setuuid FileLog_MQTT2_Gosund_SP112 5e3edcb4-f33f-20ab-c8bb-eb3549ac4c9f5545
attr FileLog_MQTT2_Gosund_SP112 logtype text
attr FileLog_MQTT2_Gosund_SP112 room MQTT2_DEVICE
define MQTT2_Gosund_SP112_CH2 MQTT2_DEVICE Gosund_SP112
setuuid MQTT2_Gosund_SP112_CH2 5e3ede04-f33f-20ab-aca0-d61f10fb5f145c53
attr MQTT2_Gosund_SP112_CH2 IODev m2server
attr MQTT2_Gosund_SP112_CH2 comment Channel 2 for MQTT2_Gosund_SP112
attr MQTT2_Gosund_SP112_CH2 devStateIcon on:usb:off off:usb@red:on
attr MQTT2_Gosund_SP112_CH2 icon usb
attr MQTT2_Gosund_SP112_CH2 jsonMap POWER2:0 Dimmer:pct POWER1:0 Heap:0 LedTable:0 LoadAvg:0 MqttCount:0 SaveData:0 Scheme:0 SetOption26:0 Sleep:0 SleepMode:0 Speed:0 StateText1:0 StateText2:0 StateText3:0 StateText4:0 Time:0 Uptime:0 UptimeSec:0 Wifi_SSId:0 Wifi_RSSI:0 Wifi_LinkCount:0 Wifi_Downtime:0 Wifi_Channel:0 Wifi_BSSId:0 Wifi_AP:0 ANALOG_A0:0 SetOption26:0 Sleep:0 SleepMode:0 Speed:0 StateText1:0 StateText2:0 StateText3:0 StateText4:0 Time:0 Uptime:0 UptimeSec:0 Wifi_SSId:0 Wifi_RSSI:0 Wifi_LinkCount:0 Wifi_Downtime:0 Wifi_Channel:0 Wifi_BSSId:0 Wifi_AP:0
attr MQTT2_Gosund_SP112_CH2 model tasmota_2channel_split
attr MQTT2_Gosund_SP112_CH2 readingList STATTOPIC/POWER2:.* state\
Gosund_SP112:stat/tasmota/POWER1:.* POWER1\
Gosund_SP112:stat/tasmota/POWER2:.* POWER2\
Gosund_SP112:cmnd/tasmota/POWER:.* POWER
attr MQTT2_Gosund_SP112_CH2 room MQTT2_DEVICE
attr MQTT2_Gosund_SP112_CH2 setList off:noArg    CMNDTOPIC/POWER2 0\
  on:noArg     CMNDTOPIC/POWER2 1\
  toggle:noArg CMNDTOPIC/POWER2 2
attr MQTT2_Gosund_SP112_CH2 setStateList on off toggle
hier die reading 1:
   CID        Gosund_SP112
   DEF        Gosund_SP112
   DEVICETOPIC MQTT2_Gosund_SP112
   FUUID      5e3edcb4-f33f-20ab-7d89-b1294f58112805ab
   IODev      m2server
   NAME       MQTT2_Gosund_SP112
   NR         155
   STATE      set_off
   TYPE       MQTT2_DEVICE
   JSONMAP:
     Channel_0  0
     Channel_1  0
     Channel_2  0
     Channel_3  0
     Channel_4  0
     Color      0
     Dimmer     0
     HSBColor   0
     POWER1     0
     POWER2     0
     POWER3     0
     POWER4     0
     2020-02-08 17:13:03   associatedWith  MQTT2_Gosund_SP112_CH2
     2020-02-08 17:20:10   state           set_off
     2020-02-08 17:24:27   subscriptions   cmnd/Gosund_SP112_fb/# cmnd/tasmota/# cmnd/tasmotas/#
   IODev      m2server
   autocreate 0
   comment    NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10; 'cmnd/CMNDTOPIC/Backlog POWER1 1; delay '.$duration.'; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
   room       MQTT2_DEVICE
hier das reading 2 vom usb:
   CID        Gosund_SP112
   DEF        Gosund_SP112
   DEVICETOPIC MQTT2_Gosund_SP112_CH2
   FUUID      5e3ede04-f33f-20ab-aca0-d61f10fb5f145c53
   IODev      m2server
   LASTInputDev m2server
   MSGCNT     2
   NAME       MQTT2_Gosund_SP112_CH2
   NR         159
   STATE      set_off
   TYPE       MQTT2_DEVICE
   m2server_MSGCNT 2
   m2server_TIME 2020-02-08 17:23:29
   JSONMAP:
     ANALOG_A0  0
     Dimmer     pct
     Heap       0
     LedTable   0
     LoadAvg    0
     MqttCount  0
     POWER1     0
     POWER2     0
     SaveData   0
     Scheme     0
     SetOption26 0
     Sleep      0
     SleepMode  0
     Speed      0
     StateText1 0
     StateText2 0
     StateText3 0
     StateText4 0
     Time       0
     Uptime     0
     UptimeSec  0
     Wifi_AP    0
     Wifi_BSSId 0
     Wifi_Channel 0
     Wifi_Downtime 0
     Wifi_LinkCount 0
     Wifi_RSSI  0
     Wifi_SSId  0
     2020-02-08 17:23:28   POWER
     2020-02-08 17:23:29   POWER1          OFF
     2020-02-08 17:17:40   POWER2          OFF
     2020-02-08 17:20:09   state           set_off
   IODev      m2server
   icon       usb
   room       MQTT2_DEVICE
Angelegt wurde das ganz mit dem entsprechenden Template:
Plug with additional USB outlet flashed with Tasmota.
For use e.g. with Gosund SP112 or Blitzwolf SH5
NOTE: a second device will be created for the USB channel.
NOTE: still untested template, feedback is welcome!
set DEVICE attrTemplate tasmota_2channel_split
set DEVICE attrTemplate tasmota_POW
attr DEVICE comment Channel 1 for DEVICE, see also DEVICE_CH2
copy DEVICE DEVICE_CH2
attr DEVICE_CH2 icon ICON
attr DEVICE_CH2 comment Channel 2 (USB outlets) for DEVICE
setreading DEVICE_CH2 associatedWith DEVICE
attr DEVICE_CH2 devStateIcon on:usb:off off:usb@red:on
attr DEVICE_CH2 setStateList on off toggle
set DEVICE_CH2 attrTemplate mqtt2_speech_recognition_type_switch
attr DEVICE,DEVICE_CH2 model tasmota_POW_USB_split
wobei das Template beim zusammenbau immer wieder sagt der CH2 wäre schon vorhanden und müsste gelöscht werden obwohl ich den vorher nicht angelegt hatte. Evtl ist das noch ein bug im template?
VG
Da ist bei der Auswertung des topic-trees was schief gelaufen bzw. du hast die Rückfrage von attrTemplate nicht zutreffend beantwortet. (Hast du das Device händisch angelegt, oder kam das aus autocreate?)
Hast du weitere tasmota-Devices? Das "tasmota" in dem Topic-tree ist m.E. nicht so gut, nimm lieber die Empfehlung aus dem Wiki oder sonst was mit mehr Unterscheidungskraft.
Kannst du dann nochmal alles löschen, was mit dem Device zu tun hat und autocreate arbeiten lassen, den Zwischenstand (Bitte als RAW-Code!) wegspeichern, dann das attrTemplate anwenden und dann nochmal posten, was am Ende für beide Kanäle rauskam?
jbraeu
Da hast du recht, die Rückfragen habe ich nicht wirklich kapiert. CMDTOPIC TELETOPIC..
Ja per Autocreate
Ja ich habe weitere Devices
Hab alles gelöscht und hier der autocreate:
defmod MQTT2_Gosund_SP112 MQTT2_DEVICE Gosund_SP112
attr MQTT2_Gosund_SP112 readingList Gosund_SP112:cmnd/tasmota/POWER:.* POWER\
setstate MQTT2_Gosund_SP112 2020-02-09 09:00:13 POWER
setstate MQTT2_Gosund_SP112 2020-02-09 09:02:53 POWER1 ON
setstate MQTT2_Gosund_SP112 2020-02-09 09:00:56 POWER2 OFF
setstate MQTT2_Gosund_SP112 2020-02-09 09:00:51 subscriptions cmnd/Gosund_SP112_fb/# cmnd/tasmota/# cmnd/tasmotas/#
Und hier nachdem ich das Template angewendet hatte:
setuuid MQTT2_Gosund_SP112 5e3fbead-f33f-20ab-41db-598fbafb4dadf89a
attr MQTT2_Gosund_SP112 comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10;; 'cmnd/Gosund_SP112/Backlog POWER1 1;; delay '.$duration.';; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
attr MQTT2_Gosund_SP112 readingList Gosund_SP112/LWT:.* LWT\
  Gosund_SP112/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  Gosund_SP112/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  Gosund_SP112/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  Gosund_SP112/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  Gosund_SP112/POWER1:.* state\
  Gosund_SP112/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_Gosund_SP112 setList off:noArg    Gosund_SP112/POWER1 0\
  on:noArg     Gosund_SP112/POWER1 1\
  toggle:noArg Gosund_SP112/POWER1 2\
  setOtaUrl:textField Gosund_SP112/OtaUrl $EVTPART1\
  upgrade:noArg   Gosund_SP112/upgrade 1
setuuid FileLog_MQTT2_Gosund_SP112 5e3fbead-f33f-20ab-ba11-ff29505892b2e041
setuuid MQTT2_Gosund_SP112_CH2 5e3fbf4f-f33f-20ab-f992-7745089dc2d1439b
attr MQTT2_Gosund_SP112_CH2 setList off:noArg    Gosund_SP112/POWER2 0\
  on:noArg     Gosund_SP112/POWER2 1\
  toggle:noArg Gosund_SP112/POWER2 2
jbraeu
die Lösung:
wenn man beim Template gefragt wird nach CMDTOPIC TELETOPIC und STATTOPIC
ersetzt man diese mit
cmnd/tasmota
tele/tasmota
stat/tasmota
vielleicht hilfts jemandem
