SOMFY und SignalDuino
Begonnen von gestein, 16 Juni 2020, 19:05:41
gestein
Und hier noch das Spielchen mit "runter", "stop" bei der höheren Bandbreite (=406kHz):
MU;P0=607;P1=-661;P2=-4992;P3=2300;P4=-2692;P5=4776;P6=-1308;P7=1275;CP=0;R=32;D=234567676010176010171010106010101767101010106767106767106017101067101010101010601017601010;e;
MU;P0=-671;P1=618;P2=-5068;P3=2040;P4=-2680;P5=4776;P6=-1319;P7=1265;CP=1;R=35;D=12345676761010101076107610101076101010107016101010107010101016107016701016767670167010167;e;
MU;P0=-2440;P1=256;P2=-10132;P3=4664;P4=-1329;P5=1257;P6=-682;P7=595;CP=7;R=32;D=012345456767676747676567674767676765454567674545674545674765676745676767676767476765476767;e;
MU;P0=-677;P1=613;P2=-5092;P3=2212;P4=-2668;P5=4792;P6=-1317;P7=1260;CP=1;R=34;D=2345676701010161076107010161076101070101016101010107010101016107016701016767670167010167;e;
MU;P0=-10084;P1=352;P2=4796;P3=-1320;P4=1254;P5=-680;P6=591;CP=6;R=32;D=0102343456563436565456343656565436545656563434563434563654565634565656565656365654365656;e;
MU;P0=-32001;P1=248;P2=-21996;P3=604;P4=-1320;P5=-685;P6=1262;CP=3;R=35;D=012343535643565343535643535646534353535356535353534356534653534646465346535346;e;
MU;P0=-2696;P1=4792;P2=-1314;P3=1271;P4=-680;P5=591;CP=5;R=33;D=0123234523452545434525454545454325454345452323452323452543454523454545454545254543254545;e;
MU;P0=112;P1=-1305;P2=627;P3=-668;P4=1277;CP=2;R=35;D=0123412323234123412341432321232323234323232321234321432321414143214323214;e;
MU;P0=-2710;P1=2260;P2=4788;P3=-1318;P4=1262;P5=-678;P6=592;CP=6;R=33;D=010234345636543656543456365656545656565656563434563434563654565634565656565656365654365656;e;
MU;P0=-32001;P1=2482;P2=-2656;P3=4820;P4=-1308;P5=1263;P6=-679;P7=618;CP=7;R=35;D=012123454567476767654767676767676547654765674767676765676767674765674567674545456745676745;e;
MU;P0=-12036;P1=356;P2=-19144;P3=609;P4=-1321;P5=1264;P6=-663;CP=3;R=32;D=012345636343636545436363636563634563634545634545634365636345636363636363436365436363;e;
MU;P0=204;P1=-2692;P2=2432;P3=4788;P4=-1329;P5=1247;P6=-685;P7=608;CP=7;R=34;D=012134545456747654767656747654765676767674767676765676767674765674567674545456745676745;e;
MU;P0=-32001;P1=611;P2=-10204;P3=4148;P4=-1300;P5=1271;P6=-662;CP=1;R=32;D=01234545454541616541654161616561456161614545614545614165616145616161616161416165416161;e;
MU;P0=-29252;P1=276;P3=1265;P4=-1313;P5=619;P6=-669;CP=5;R=36;D=010345656345656345636543654565656563656565654563654365654343436543656543;e;
MU;P0=-1304;P1=617;P2=-665;P3=1271;CP=1;R=33;D=010121230121212121212321012321210303210303210123212103212121212121012123012121;e;
MU;P0=612;P1=-659;P2=1266;P7=-1311;CP=0;R=35;D=7012721072701010127270127012721010107210101010101010721010107012107010;e;
MU;P0=-32001;P1=360;P2=-21272;P3=627;P4=-661;P5=1278;P6=-1304;CP=3;R=34;D=012343456343454343434363434565436543634345434343656343456565654343656345436345;e;
MU;P0=-6188;P1=2454;P2=-2688;P3=4800;P4=-1318;P5=1260;P6=604;P7=-670;CP=6;R=36;D=01212345454676767675467546754546767676767546754675457676764576767676767676457676764675764676;e;
MU;P0=-32001;P1=308;P2=-19064;P3=872;P4=-665;P5=633;P6=-1302;P7=1267;CP=5;R=33;D=01234545454565454745456765454767654745654547454545676545476767674545676547456547;e;
MU;P0=-3912;P1=2482;P2=-2656;P3=4812;P4=-1328;P5=1249;P6=-680;P7=599;CP=7;R=35;D=01212345456767674765476567676745476765674547654765456767674567676767676767456767674765674767;e;
MU;P0=-32001;P1=2466;P2=-2684;P3=4784;P4=-1314;P5=1263;P6=-675;P7=614;CP=7;R=32;D=012123454567674547676567456747676547654567476765676767454767654545456767454765674765;e;
Übrigens filtere ich die Ausgaben mit "tail -f log/fhem-2020-06-17.log | grep 'Read, msg READredu: MU;'".
Dabei bricht die Ausgabe nach den obigen Zeilen mit der Meldung "Übereinstimmungen in Binärdatei (Standardeingabe)" ab.
Es kommt dann keine Ausgabe mehr, nur mehr Ctrl+c hilft.
lg, Gerhard
gestein
Und das hier mit Bandbreite 464kHz:
MU;P0=1269;P1=-1312;P2=-31628;P3=202;P4=-124;P5=144;P6=-666;P7=626;CP=7;R=34;D=2345634567676767606717606767176760676767101767601010106767101760671760;e;
MU;P0=-4300;P1=316;P2=-26452;P3=1267;P4=-1311;P5=604;P6=-675;CP=5;R=37;D=0123456563456563456365436545634563436565654365656565656565436565654563654565;e;
MU;P0=-12344;P1=340;P2=-30936;P3=602;P4=-687;P5=-1312;P6=1266;CP=3;R=35;D=0123435653434656534643434356534653465343464353464343564356565653;e;
MU;P0=-29224;P1=312;P3=1255;P4=-1326;P5=617;P6=-673;CP=5;R=37;D=0103456345634345656565656343456565636565456563456365456345656365656565656565;e;
MU;P0=-2084;P1=248;P2=-25380;P3=380;P4=-679;P5=609;P6=1259;P7=-1314;CP=5;R=35;D=01234545464545454575454676457645454576754675467545464575464545764576767675;e;
MU;P0=-32001;P1=288;P2=-20684;P3=621;P4=-672;P5=-1311;P6=1254;CP=3;R=37;D=0123434343565346564356534343465656534343464343534346534643534653434643434343434343;e;
MU;P0=-671;P1=302;P2=-27976;P4=1261;P5=616;P6=-1308;CP=5;R=35;D=0121040565046505046505050405050564650465046505040565040505640564646465;e;
MU;P0=-32001;P1=618;P2=-10140;P3=4324;P4=-1317;P5=1276;P6=-672;CP=1;R=36;D=01234545616145454165614545416165416545416161656161416165416561416541616561616161616161;e;
MU;P0=-5448;P1=364;P2=-30916;P3=613;P4=-1314;P5=1270;P6=-663;CP=3;R=34;D=0123456343636543654563636345436543654363656343656363456345454543;e;
MU;P0=-29232;P1=304;P3=1269;P4=-1310;P5=625;P6=-674;CP=5;R=36;D=0103456365656543456563654343456565636565456563456365456345656365656565656565;e;
MU;P0=-32001;P1=356;P2=-16096;P3=1266;P4=-1323;P5=-669;P6=597;CP=6;R=35;D=01234356434656565343434656535656465356565643465346534656535646535656435643434346;e;
MU;P0=180;P1=-663;P2=1263;P3=-1316;P4=622;CP=4;R=36;D=01232341414141232341234141232341414121414341412341214341234141214141414141414;e;
MU;P0=-2716;P1=288;P2=-20680;P3=612;P4=-1310;P5=-659;P6=1270;CP=3;R=35;D=01234353535353564653534353565353534653535346435643564353565343565353465346464643;e;
MU;P0=-5244;P1=296;P2=-18704;P3=1272;P4=-1306;P5=-675;P6=618;CP=6;R=37;D=0123435656434656565356434653434343465656535656465653465356465346565356565656565656;e;
MU;P0=292;P1=-681;P2=610;P3=-1309;P4=1259;CP=2;R=34;D=012321212143212143212141232121412121234321432143212141232141212341234343432;e;
MU;P0=-10024;P1=340;P2=-30308;P3=613;P4=-676;P5=1250;P6=-1329;CP=3;R=37;D=0123456565634543634565634343454343634345634543634563434543434343434343;e;
MU;P0=-32001;P1=272;P2=-11500;P3=3288;P4=-1312;P5=1268;P6=606;P7=-668;CP=6;R=35;D=0123454545467676767546757646767576454576767645467546754676757646757676457645454546;e;
MU;P0=-1312;P1=1264;P2=618;P3=-673;CP=2;R=37;D=01023231323201023132320101023232313232023231023132023102323132323232323232;e;
MU;P0=-32001;P1=316;P2=-13748;P3=1273;P4=-1309;P5=628;P6=-665;CP=5;R=34;D=0123434345634565656365654565656563434365656545634365456565656565634565636545634365654365;e;
MU;P0=-32001;P1=2476;P2=-2656;P3=4828;P4=-1323;P5=1252;P6=591;P7=-685;CP=6;R=36;D=0121234545467675454675467676754676767675764576467676757645454576764576467576767645767646;e;
MU;P0=-1708;P1=292;P2=-25400;P3=-674;P4=619;P5=1278;P6=-1297;CP=4;R=35;D=01213434353434346434343565343434343464356534643434343434356434353464356534346534;e;
MU;P0=268;P1=-1310;P2=618;P3=-661;P4=1278;CP=2;R=36;D=012341412341232323432321432123232343214141432321432123432323214323212;e;
MU;P0=292;P1=-654;P2=634;P3=204;P4=-92;P5=156;P6=-1310;P7=1268;CP=2;R=33;D=012121345621212171262121212121762121712121262176712621212121212176212171262176712126712;e;
MU;P0=-29244;P1=280;P3=1266;P4=-1313;P5=608;P6=-668;CP=5;R=36;D=010345636545656345656343654365456565636543434365654365456365656543656545;e;
MU;P0=-670;P1=164;P2=-1303;P3=616;P4=1275;CP=3;R=34;D=01230403242303030423040303030323042403230303030303042303040323042403032403;e;
MU;P0=-2332;P1=296;P2=-26464;P3=1271;P4=-1314;P5=608;P6=-662;CP=5;R=36;D=01234563656545634565636565654365456565636543434365654365456365656543656545;e;
MU;P0=3944;P1=-1294;P2=1283;P3=-660;P4=633;CP=4;R=34;D=0121234121434343212143434343234341234343414321234143434343434321434323414321234341234;e;
MU;P0=-32001;P1=292;P2=-20680;P3=606;P4=-1302;P5=-676;P6=1277;CP=3;R=36;D=01234356464353535353535643564356534653435353565346464653534653435653535346535343;e;
MU;P0=328;P1=-679;P2=1265;P3=-1304;P4=623;CP=4;R=35;D=0123214341414121414141414141434123214341414141414123414121434123214143214;e;
MU;P0=112;P1=-674;P2=592;P3=-1323;P4=1272;CP=2;R=35;D=012123432121214321432143412123412321212141234343412123412321412121234121232;e;
MU;P0=156;P1=-1298;P2=633;P3=-669;P4=1271;CP=2;R=33;D=0123232341232323232323432123432323212341432123232323232341232343212341432321432;e;
MU;P0=-8720;P1=336;P2=-26444;P3=1268;P4=-1320;P5=598;P6=-664;CP=5;R=36;D=012345656345656345636543654365456565636543434365654365456365656543656545;e;
MU;P0=-8172;P1=296;P2=-13632;P3=1262;P4=-1310;P5=616;P6=-676;CP=5;R=35;D=0123434343456565656345634565656365436565656545634365456565656565634565636545634365654365;e;
MU;P0=-31214;P1=244;P2=604;P3=-679;P4=1264;P5=-1308;CP=2;R=35;D=0102343252345234323232325432523232343254545432325432523432323254323252;e;
MU;P0=-5648;P1=2476;P2=-2668;P3=4800;P4=-1313;P5=1259;P6=602;P7=-673;CP=6;R=34;D=01212345454675467676754676767676767576454676767576454675767676767676457676467576454676754676;e;
MU;P0=-5908;P1=380;P2=-28960;P3=627;P4=-668;P5=1260;P6=-1313;CP=3;R=35;D=0123434563434563454343634563454343436345656563434563454363434345634345;e;
MU;P0=-1311;P1=1273;P2=613;P3=-667;CP=2;R=33;D=01023232323232310231023232313202323232323132010231323232323232013232023132010232310232;e;
MU;P0=-32001;P1=288;P2=-23380;P3=428;P4=-683;P5=609;P6=-1303;P7=1260;CP=5;R=36;D=0123456765454745654765474565454765474545456547676765454765474565454547654547;e;
Das war jetzt übrigens immer der selbe Handsender mit dem selben Kanal (der hat 4 Kanäle). Bei Bedarf kann ich logs auch zu anderen Kanälen/Handsendern oder auch diversen SOMFY-Wandsendern liefern ;-)
lg, Gerhard
gestein
ich habe nun die Parameter wieder eingeschalten und die Bandbreite auf 464kHz gesetzt.
Danach habe ich "rauf", "runter" und "stop" gedrückt.
Meistens wird die Stop-Taste nicht erkannt, aber auch "rauf" und "runter" klappt manchmal nicht.
Von 30x Drücken wird wohl 4-5x nichts erkannt.
Es kommen dann die log-Einträge:
2020.06.17 14:10:31.865 3: mySIGNALduino: Unknown code Ys4D677361ABB3DC, help me!
2020.06.17 14:48:31.514 3: mySIGNALduino: Unknown code Ys457B6F25EFF798, help me!
2020.06.17 14:48:57.449 3: mySIGNALduino: Unknown code Ys4B051161ABB3DC, help me!
2020.06.17 14:49:04.699 3: mySIGNALduino: Unknown code Ys026A6A7D529E60, help me!
2020.06.17 14:49:08.516 3: mySIGNALduino: Unknown code Ys5B1B0F8F455D32, help me!
lg, Gerhard
Ralf9
Ich habe es mir angeschaut, es sind viele Nachrichten dabei die nicht passen. Die Erhöhung der Bandbreite auf 464kHz bringt keine Verbesserung,
Ein Teil sind keine SOMFY Nachrichten und bei einigen SOMFY Nachrichten  fehlt was an Anfang.
Du hast anscheinend keine gute Empfangsbedingungen, evtl ist in der Nähe des Signalduino eine Störungsquelle.
Wie weit ist der Signalduino vom fhem Rechner entfernt.
Hast Du mir mal ein Foto von deinem Signalduino?
Gruß Ralf
