MQTT2 set attrTemplate
Begonnen von Wolfgang Hochweller, 21 September 2020, 14:17:04
Wolfgang Hochweller
Folgendes Kommando :
set attrTemplate wallpanel_app
fuehrt zu diesem Listing :
   CFGFN
   CID        HowiTab
   DEF        HowiTab
   DEVICETOPIC MQTT2_HowiTab
   FUUID      5f687dd5-f33f-775d-620b-6c75291dc7b25c12
   IODev      mqtthome
   LASTInputDev mqtthome
   MSGCNT     755
   NAME       MQTT2_HowiTab
   NR         518
   STATE      ???
   TYPE       MQTT2_DEVICE
   mqtthome_MSGCNT 755
   mqtthome_TIME 2020-09-21 14:14:39
   JSONMAP:
     FACE_value face
     MOTION_value motion
     2020-09-21 14:14:39   acPlugged       false
     2020-09-21 14:09:44   attrTemplateVersion 20200522 or prior
     2020-09-21 14:09:39   battery_acPlugged true
     2020-09-21 14:09:39   battery_charging true
     2020-09-21 14:09:39   battery_unit    %
     2020-09-21 14:09:39   battery_usbPlugged false
     2020-09-21 14:09:39   battery_value   100
     2020-09-21 14:14:39   brightness      48
     2020-09-21 14:14:39   charging        false
     2020-09-21 14:14:39   currentUrl      http:\/\/10.0.0.41:8083\/fhem\/ftui\/index.html
     2020-09-21 12:38:07   face_value      false
     2020-09-21 14:14:39   light_id        als-apds9251
     2020-09-21 14:14:39   light_unit      lx
     2020-09-21 14:14:39   light_value     90
     2020-09-21 14:14:39   magneticField_id mag-akm09911
     2020-09-21 14:14:39   magneticField_unit uT
     2020-09-21 14:14:39   magneticField_value -37.5625
     2020-09-21 13:41:38   motion_value    false
     2020-09-21 14:14:39   screenOn        true
     2020-09-21 14:09:39   state_brightness 48
     2020-09-21 14:09:39   state_currentUrl http:\/\/10.0.0.41:8083\/fhem\/ftui\/index.html
     2020-09-21 14:09:39   state_screenOn  true
     2020-09-21 12:17:57   subscriptions   wallpanel/HowiTab/command
     2020-09-21 14:14:39   unit            %
     2020-09-21 14:14:39   usbPlugged      false
     2020-09-21 14:14:39   value           100
   IODev      mqtthome
   comment    For further info on configuration and available commands see <a href="https://thanksmister.com/wallpanel-android/">project page</a>.
   event-on-change-reading .*
   icon       kindle
   jsonMap    MOTION_value:motion FACE_value:face
   model      wallpanel_app
   readingList wallpanel/HowiTab/state:.* { json2nameValue($EVENT) }
  wallpanel/HowiTab/sensor/battery:.* { json2nameValue($EVENT) }
  wallpanel/HowiTab/sensor/motion:.* { json2nameValue($EVENT, 'MOTION_', $JSONMAP) }
  wallpanel/HowiTab/sensor/face:.* { json2nameValue($EVENT, 'FACE_', $JSONMAP) }
HowiTab:wallpanel/HowiTab/sensor/light:.* { json2nameValue($EVENT, 'light_', $JSONMAP) }
HowiTab:wallpanel/HowiTab/sensor/magneticField:.* { json2nameValue($EVENT, 'magneticField_', $JSONMAP) }
   room       MQTT2_DEVICE,Zentrale
   setList    alert:textField wallpanel/HowiTab/command {"eval": "alert('$EVTPART1');;"}
  audio:textField wallpanel/HowiTab/command {"$EVTPART0": "$EVTPART1"}
  brightness:colorpicker,BRI,0,1,255 wallpanel/HowiTab/command {"$EVTPART0": $EVTPART1}
  camera:noArg wallpanel/HowiTab/command {"$EVTPART0": "true"}
  clearCache:noArg wallpanel/HowiTab/command {"$EVTPART0": true}
  google:noArg wallpanel/HowiTab/command {"url": "https://www.google.com"}
  relaunch:noArg wallpanel/HowiTab/command {"$EVTPART0": true}
  reload:noArg wallpanel/HowiTab/command {"$EVTPART0": true}
  screenoff:noArg wallpanel/mywallpanel/command {"wake": false}
  screenon:select,60,600,3600,86400 wallpanel/wz_tablet/command {"wake": true, "wakeTime": $EVTPART1}
  speak:textField {"wallpanel/HowiTab/command {'$EVTPART0': '".substr($EVENT,5)."'}"}
  url:textField wallpanel/HowiTab/command {"$EVTPART0": "$EVTPART1"}
  volume:slider,0,1,100 wallpanel/HowiTab/command {"$EVTPART0": $EVTPART1}
Alles fast gut, ausser dass in der Setlist Devices auftauchen, die da nicht hingehoeren :
wz_tablet
mywallpanel
Letzteres gibt es auch, ersteres ist mir fremd.
Thx für's melden, sollte mit dem nächsten update passen, war ausweislich der desc noch "Experimental", jetzt ist es "Early"...
Wolfgang Hochweller
Danke, alles ok.
Ging mir auch mehr um die Info, ich kann das ja leicht korrigieren.
