Revision 23052: 10_FRM_LCD.pm: feature update, see forum #114552 msg #1087982 - ...
Begonnen von System, 30 Oktober 2020, 19:00:31
System
10_FRM_LCD.pm: feature update, see Forum: #114552 msg #1087982
- TCP/WiFi connected Firmata devices: TCP socket close detection improved, new attribute "receiveTimeout"
- new attribute "ping-interval"
- I2C: set inernal I2C SENDSTAT to error if sub I2CWrtFn is called while Firmata device is not connected and propagate error by synchronously calling sub I2CRecFn
- added command "set sendString"
- detect if Device::Firmata is installed and has required version, set FRM internal DRIVER_STATUS and FRM client internal IODev_ERROR on error
- added support for client module I2C_INA219
Source: Revision 23052: 10_FRM_LCD.pm: feature update, see forum #114552 msg #1087982
