fehlende Attribute bei gewissen Sensortypen
Begonnen von Burny4600, 12 November 2020, 12:55:29
Burny4600
Ich habe einige Sensoren die Empfangen werden, aber es fehlen diverse Attribute die zu ergänzen sind.
Folgende Sensoren sind davon betroffen.
2020.11.10 19:38:01.875 3: CM160_8042: unknown attribute model. Type 'attr CM160_8042 ?' for a detailed list.
2020.11.10 19:38:01.925 3: CM180_8ff2: unknown attribute model. Type 'attr CM180_8ff2 ?' for a detailed list.
2020.11.10 19:38:01.988 3: CM180I_c200: unknown attribute model. Type 'attr CM180I_c200 ?' for a detailed list.
2020.11.10 19:38:02.143 3: CUL_TX_87: unknown attribute model. Type 'attr CUL_TX_87 ?' for a detailed list.
2020.11.10 19:38:02.726 3: Hideki_31_1: unknown attribute model. Type 'attr Hideki_31_1 ?' for a detailed list.
2020.11.10 19:38:03.750 3: Revolt_0000: unknown attribute ignore. Type 'attr Revolt_0000 ?' for a detailed list.
2020.11.10 19:38:03.963 3: SD_BELL: ERROR! You want to choose the FreeTec_PE-6946 model to Pollin_551227.
2020.11.10 19:38:06.411 3: SD_Keeloq_80BEED: unknown attribute ignore. Type 'attr SD_Keeloq_80BEED ?' for a detailed list.
Empfangen werden diese Sensortypen von einem sduino.
   CFGFN      /media/hdd/fhem/mycfg/schnittstellen_rasp01.cfg
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_BELL:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:CUL_EM:Fernotron:SD_Keeloq:SD_GT:SIGNALduino_un:
   DEF        192.168.17.184:40733
   DMSG       u40#000002
   DevState   initialized
   DeviceName 192.168.17.184:40733
   FD         26
   FUUID      5e6227ab-f33f-21bc-acd7-9dce1977680f0d37
   LASTDMSG   u40#000002
   LASTDMSGID 40
   MSGCNT     71563
   NAME       sduino_ab
   NR         382
   PARTIAL
   RAWMSG     MU;P0=362;P1=-609;P2=608;P3=-1097;P4=848;P5=468;D=0121010101010101010101010101010101010101010101034341030101430143010143014301010101410301410101030101014103010101010101014103010101010101010101010101010101010101010101010141010341030141010343435;CP=0;
   STATE      opened
   TIME       1605181993.85166
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.4.0 SIGNALduino  - compiled at Jul 16 2020 20:52:03
   versionProtocols 1.20
   versionmodul v3.4.4_dev+14042020
   DoubleMsgIDs:
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}[AFaf][A-Fa-f0-9]{2,3}
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^P(?:14|20|26|29|30|34|46|68|69|76|81|83|86|90|91|91.1|92|93|95|97|99|104)#.*
     18:FLAMINGO ^P13\.?1?#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     25:CUL_EM  ^E0.................
     26:Fernotron ^P82#.*
     27:SD_BELL ^P(?:15|32|41|42|57|79|96|98)#.*
     28:SD_Keeloq ^P(?:87|88)#.*
     29:SD_GT   ^P49#[A-Fa-f0-9]+
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2020-05-11 20:10:46   ping            OK
     2020-11-12 11:38:11   state           opened
     2020-03-11 18:13:18   version         V 3.3.2.1-rc9 SIGNALduino - compiled at Jun 16 2019 18:11:42
   helper:
   keepalive:
     ok         1
     retry      0
   mcIdList:
     10
     11
     12
     18
     43
     47
     52
     57
     58
     96
   msIdList:
     0
     0.1
     0.2
     0.3
     0.4
     0.5
     1
     3
     3.1
     4
     6
     7
     13
     13.2
     14
     15
     17
     20
     23
     25
     33
     33.1
     33.2
     35
     41
     49
     51
     53
     54.1
     55
     65
     68
     74.1
     87
     88
     90
     91.1
     93
   muIdList:
     8
     9
     13.1
     16
     17.1
     19
     21
     22
     24
     26
     27
     28
     29
     30
     31
     32
     34
     36
     37
     38
     39
     40
     42
     44
     44.1
     45
     46
     48
     49.1
     49.2
     50
     54
     56
     59
     60
     61
     62
     64
     66
     67
     69
     70
     71
     72
     73
     74
     76
     79
     80
     81
     83
     84
     85
     86
     89
     91
     92
     94
     95
   alias      SIGNALduino - AB Wetterstation
   devStateIcon Initialized:it_network@0CFB0C opened:it_network@0CFB0C disconnected:it_network@red closed:it_network@red
   flashCommand avrdude -c arduino -b 57600 -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   group      Schnittstellen ser2net
   hardware   nano328
   icon       cul_usb
   longids    0
   room       _RxTx
   updateChannelFW stable
   verbose    0
   whitelist_IDs 0,0.1,0.2,0.3,0.4,0.5,1,3,3.1,4,6,7,8,9,10,11,12,13,13.1,13.2,14,15,16,17,17.1,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,33.1,33.2,34,35,36,37,38,39,40,41,42,43,44,44.1,45,46,47,48,49,49.1,49.2,50,51,52,53,54,54.1,55,56,57,58,59,60,61,62,64,65,66,67,68,69,70,71,72,73,74,74.1,76,79,80,81,83,84,85,86,87,88,89,90,91,91.1,92,93,94,95,96
MfG Chris
Raspberry Pi 2-5, Bullseye Lite, Bookworm Lite
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
elektron-bbs
Diese Attribute sind nicht zu ergänzen. Die aufgezeigten Attribute gibt es bei diesen Sensoren nicht.
Wann tauchen die Meldungen auf?
Intel(R) Atom(TM) CPU N270 mit 2 SIGNALduino nanoCC1101 + ESPEasy 2x serial server SIGNALduino nanoCC1101, Raspberry Pi 2 mit 2 CUL Stackable CC1101, Raspberry Pi 3 mit SIGNALduino radino + nano328 + 2 x SIGNAL-ESP CC1101 + 2 x rf_Gateway
Burny4600
Diese Meldungen tauchen beim Boot von FHEM auf.
Das Attribut ignore sollte bei allen Sensoren vorhanden sein um diese im Bedarfsfall zu deaktivieren.
Bei Sensoren, bei den ein Model für die Funktion benötigt wird, sollten dieses auch enthalten sein oder es sollte nicht notwendig sein es anzuführen.
Man kann bei diesen Sensoren, ohne gültiges Model, keine Änderungen der Attribute durchgeführt werden, weil man immer an dem nicht einstellbaren Model hängen bleibt.
MfG Chris
elektron-bbs
Ich habe keine Ahnung, wie du die nicht unterstützten Attribute hinzugefügt hast. Evtl. mal mit "userattr" gespielt?
Beim nächsten Neustart sollten diese Meldungen nicht wieder auftauchen.
Falls du konkrete Vorschläge hast, wo ein Attribut "model" erforderlich wäre, so wende dich bitte an den jeweiligen Maintainer des Modules.
