INSTA Funkbus (Gira, Berker, Jung)
Begonnen von Michi, 20 Januar 2014, 14:44:29
#120
Zitat von: steini1984 am 01 Oktober 2022, 23:44:54
I just bought a second CUL device from here:
https://www.amazon.de/-/en/gp/product/B07T26ZSZG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
https://www.smart-home-komponente.de/nano-cul/nano-cul-868-extern/
The manual says that i should find the device under /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0@38400 0000 but i comes up as:
Can anyone give me a hint on how I can flash the device.
You should do a reclamation also involving amazon, see https://www.voltlog.com/tag/ft232-a50285bi/ for details why.
The seller ("smarty") is one of our "well-known customers" here causing trouble with not well designed products every now and then. Very unhappy to see, he is getting back to old behaviour...
See also here: https://forum.fhem.de/index.php/topic,99871.msg1237474.html#msg1237474
steini1984
#121
Thanks for this information. This is really disappointing and I can verify that I have a fake since the serial is A50285BI :(
I could actually flash the device by changing the baudrate:
avrdude -D -p atmega328p -P /dev/ttyUSB0 -b 115200 -c arduino -U flash:w:nanoCUL.hex
steini1984
#122
Hello again. I have both a CUL  from Busware (CC1101 - USB - Lite module - V3) and a nanoCUL which both work fine. I have been using them to sniff the bus traffic and sync the state of my Gira lights with Home assistant, but controlling the lights via an XS1 from Ezcontrol.
Now i have been playing with the CUL to control the lights, but I cannot figure out the dimming.
I can turn on/off and completely dim up or down, but have not figured out the stop command. My understanding is that I should send a command to dim (eg UL) and then a stop command (S0) to stop the dimming but all my permutations and timing has not worked.
Here is an example of a command I send to dim to 100% brightness:
Js4355D6BA1UL
That gives me the following sequence:
J4355D6BA1UU00
J4355D6BA1U100
J4355D6BA1U100
J4355D6BA1U100
J4355D6BA1UL00
J4355D6BA1UL00
J4355D6BA1UL00
J4355D6BA1UL00
J4355D6BA1SL00
J4355D6BA1SL00
Then I have tried to stop the dimming (for example at 50%) with this commands, but none seem to work for me:
Js4355D6BA1SS
Js4355D6BA1SL
Js4355D6BA1S1
Js4355D6BA1S0
I see that there are some versions of the firmware and maybe dimming is not supported with all of them? I tried to flash a different version, but it got me nowhere. I´m currently on the firmware from reply #110: nanoCUL.hex (MD5 > fa69b2683822bc275f28e9c1e0228cb0)
Can someone point me in the right direction - thanks :)
