Revision 23559: bugfix : fix parse loop over MGB instances for the same IODev ...
Begonnen von System, 19 Januar 2021, 23:30:06
System
bugfix     : fix parse loop over MGB instances for the same IODev (MQTT2-IO only)
Source: Revision 23559: bugfix     : fix parse loop over MGB instances for the same IODev ...
