[gelöst] cfgState BurstUnknwn (Fehler bein ConfigCkeck - HMInfo)
Begonnen von Rampler, 13 Februar 2021, 09:06:33
Rampler
ich habe neuerdings Fehler im ConfigCheck, welche ich mir nicht erklären kann:
configCheck done:
peerNeedsBurst cannot be determined
    WF.fb_lock: WF.keymatic
    WF.fb_open: WF.keymatic
    WF.fb_unlock: WF.keymatic
WF.fb ist eine Homematic Fernbedienung (HM-RC-KEY4-2).
Hier mal ein List vom WF.fb_lock und dem Controller:
WF.fb_lock
   DEF        26848A02
   FUUID      5c489c0c-f33f-b6d9-e557-61b532d102e2fb35
   NAME       WF.fb_lock
   NOTIFYDEV  global
   NR         39
   NTFY_ORDER 50-WF.fb_lock
   STATE      Short 1_0 (to WF.keymatic)
   TYPE       CUL_HM
   chanNo     02
   device     WF.fb
   peerList   WF.keymatic
     2021-02-13 07:40:21   R-WF.keymatic_chn-01-expectAES off
     2021-02-13 07:40:21   R-WF.keymatic_chn-01-peerNeedsBurst on
     2021-02-13 07:40:20   R-dblPress      0 s
     2021-02-13 07:40:20   R-longPress     0.4 s
     2021-02-13 07:40:20   R-sign          on
     2021-02-13 07:40:20   RegL_01.        00:00 04:10 08:01 09:00
     2021-02-13 07:40:21   RegL_04.WF.keymatic_chn-01 00:00 01:01
     2021-02-13 08:54:39   cfgState        BurstUnknwn
     2021-02-13 08:30:36   peerList        WF.keymatic
   helper:
     peerFriend peerAct,peerVirt
     peerIDsState complete
     peerOpt    4:remote
     regLst     1,4p
     cfgChk:
       idBc01     WF.keymatic
     cmds:
       TmplKey    26111801:no:1613201435.62215
       TmplTs     1613201436.13342
       cmdKey     1:0:0::WF.fb::02:26111801
       cmdLst:
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         getConfig  noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single}|dual|reverse)] [({set}|unset)] [(actor|remote|{both})]
         peerSmart  -peerOpt-
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         tplSet_26111801 -tplPeer-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
       lst:
         condition  slider,0,1,255
         peer       26111801
         peerOpt    AZ.hk_remote,AZ.hk_windowrec,Alarm_sir_ext,Alarm_sir_int,BD.hk_remote,BD.hk_windowrec,BD.licht,BD.spiegel,EM.pm.sw,FL.AZ.pm.sw,FL.EG.gong.led,FL.EG.gong.mp3,FL.EG.licht,FL.OG.licht,FL.UG.hk_remote,FL.UG.hk_windowrec,FL.UG.licht,FL.UG.strahler,FL.ZG.licht,GA.keymatic,GA.licht,GA.taster,HW.hk_remote,HW.hk_windowrec,HW.licht,HW.sw,HZ.ctrl.K1,HZ.ctrl.K2,HZ.ctrl.K3,HZ.ctrl.K4,KE.licht,KE.sw,KG.hk_remote,KG.hk_windowrec,KK.hk_remote,KK.hk_windowrec,KU.licht,KU.spuele,PR.hk_remote,PR.hk_windowsrec,PR.licht,Rauchmelder,SZ.hk_remote,SZ.hk_windowrec,TR.sw,WC.hk_remote,WC.hk_windowrec,WC.licht,WC.ventilator,WF.OUT.licht,WF.keymatic,WF.licht,WZ.hk_remote,WZ.hk_windowrec,WZ.sw,vccu
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     peerIDsH:
       00000000   broadcast
       26111801   WF.keymatic_chn-01
     role:
       chn        1
     tmpl:
   role:
   aesCommReq 1
   alias      Windfang FB Lock
   event-on-change-reading no
   group      Fernbedienung
   icon       remote_control
   model      HM-RC-KEY4-2
   peerIDs    00000000,26111801
   room       Windfang
Controller:
   DEF        26848A
   FUUID      5c489c0c-f33f-b6d9-82f1-e3808eece265f780
   IODev      HMUART1
   NAME       WF.fb
   NOTIFYDEV  global
   NR         36
   NTFY_ORDER 50-WF.fb
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 WF.fb_unlock
   channel_02 WF.fb_lock
   channel_03 WF.fb_light
   channel_04 WF.fb_open
     2021-01-16 20:38:17   Batterie_changed 2020-05-09
     2021-02-13 07:49:44   CommandAccepted yes
     2021-02-13 08:26:39   D-firmware      1.2
     2021-02-13 08:26:39   D-serialNr      KEQ1064561
     2021-02-13 07:34:27   PairedTo        0x29A083
     2016-05-04 20:04:49   R-localResDis   off
     2016-05-04 20:04:49   R-pairCentral   0x29A083
     2021-02-13 07:34:27   RegL_00.        00:00 02:01 0A:29 0B:A0 0C:83 18:00
     2021-02-13 07:49:44   aesCommToDev    ok
     2021-02-13 07:49:44   aesKeyNbr       02
     2021-02-13 07:50:47   aesReqTo        WF.keymatic
     2020-05-09 11:33:23   alive           yes
     2021-02-13 07:50:47   battery         ok
     2021-02-13 08:54:39   cfgState        ok
     2021-02-13 08:26:40   commState       CMDs_done
     2020-05-09 11:33:23   powerOn         2020-05-09 11:33:23
     2020-05-09 11:33:23   recentStateType info
     2021-02-13 08:26:40   state           CMDs_done
   helper:
     HM_CMDNR   149
     mId        00A6
     peerFriend
     peerOpt    -:remote
     regLst     0
     rxType     20
     cmds:
       TmplKey    :no:1613201435.62359
       TmplTs     1613201435.62359
       cmdKey     0:1:0::WF.fb:00A6:00:
       cmdLst:
         assignHmKey noArg
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         peerOpt
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       newChn     +26848A,00,01,16
       prefIO
       rxt        2
       vccu       vccu
       p:
         26848A
         00
         01
         16
     mRssi:
       mNo
     peerIDsH:
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       dev        1
     tmpl:
   IODev      HMUART1
   IOgrp      vccu
   alias      Windfang FB Controller
   autoReadReg 4_reqStatus
   event-on-change-reading battery,state
   expert     defReg,allReg,rawReg,templ
   firmware   1.2
   group      Fernbedienung
   icon       remote_control
   model      HM-RC-KEY4-2
   room       Windfang
   serialNr   KEQ1064561
   subType    remote
Einen Getconfig habe ich bereits durchgeführt. Die Fernbedienung funktioniert einwandfrei.
Hat jemand einen Tipp ?
FHEM ist aktuell ..
VG Klaus
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
frank
eventuell wird nur eine "falsche" kategorie gezeigt.
nach meinem verständnis sollte doch jeweils R-WF.keymatic_chn-01-expectAES=on sein.
FHEM: 6.0(SVN) => Pi3(buster)
Rampler
Hallo Frank,
ich habe das Reading  R-WF.keymatic_chn-01-expectAES auf on gestezt, leider immer noch ein cfgState BurstUnknwn.
Die Fernbedienung funktioniert noch, gottseidank.
Rampler
Mit den folgenden Modulen ist der cfgstate OK:
98_HMinfo.pm 23446 2020-12-31 15:08:30Z martinp876 $
10_CUL_HM.pm 23421 2020-12-26 15:11:46Z martinp876 $
Diese Versionen führen zum o.g. Fehler (cfgState BurstUnknwn):
98_HMinfo.pm 23643 2021-01-30 16:21:19Z martinp876 $
10_CUL_HM.pm 23644 2021-01-30 16:22:42Z martinp876 $
octek0815
#4
Kann ich bestätigen.
Habe den selben Fehler ebenfalls mit HM-SEC-KEY und HM-RC-4-3.
Es funktioniert weiterhin alles, aber halt die Hinweise in HMinfo, und beheben lässt sich das auch nicht.
Olli
Rampler
@octek0815
Hast Du mit dem neuesten update nochmal getestet ?
octek0815
Zitat von: Rampler am 15 Februar 2021, 15:19:15
@octek0815
Stimmt hatte ich total vergessen.
Gerade getestet, ist behoben.
Olli
