Revision 23752: 98_serviced: add additional argument and attribute to declare the ssh ...
Begonnen von System, 16 Februar 2021, 23:00:48
System
98_serviced: add additional argument and attribute to declare the ssh port if not the default is used, fix retrieve status on define
Source: Revision 23752: 98_serviced: add additional argument and attribute to declare the ssh ...
