Is possible change Telegram bot name (hsitbot)
Begonnen von DiegoS, 20 April 2021, 21:18:49
DiegoS
I'm Diego Sorrentino and i work for an italian research institute for studyng and monitoring earthquakes.
We have a project named "Hai sentito il terremoto?" (hsit.it) - the italian Did You Feel it? project
i have already activated a telegram bot named @hsit_bot because @hsitbot seems used by FHME project.
If its yours and if you don't use it, could you please release it?
Regards,
Diego
Dr. Boris Neubert
Hi Diego,
the telegram bot @hsitbot is not a bot run by the FHEM e.V. TelegramBot is a FHEM module that can be integrated in one's home automation system by any user of FHEM. I suppose a private user of FHEM has registered the account and uses it to control his home. We have no knowlegde of the user or the bot apart from what you wrote. I am sorry that we are unable to help.
Best regards,
Boris
DiegoS
Hi Boris,
thank you for your attention :-)
My best regards
Diego
