DbLog Fehler wenn YAMAHA_MC enabled
Begonnen von juppzupp, 22 Oktober 2021, 17:07:37
juppzupp
wenn ich am folgenden device (YAMAHA_MC) das attr disable von 1 auf 0 setze, bekomme ich ein dblog problem.
ist das ein YAMAHA_MC oder DbLog problem ?
   ACTIVE_ZONE main
   API_VERSION 1
   DEF        192.168.0.116
   DEVICEID   0
   FUUID      5ec1016e-f33f-c0e9-209f-81c8c46a8a07d47c
   HOST       192.168.0.116
   LastTtsFile
   NAME       ysp2700
   NOTIFYDEV  global
   NR         519
   OFF_INTERVAL 120
   ON_INTERVAL 60
   PORT       80
   PowerOnInProgress 0
   STATE      on
   TYPE       YAMAHA_MC
   URLCMD     /YamahaExtendedControl
   UdpClientPort 41100
   VERSION    v2.1.1
   ZONE       main
   attemptsToReturnMenu 0
   dist_group_id 00000000000000000000000000000000
   dist_group_name (Linked) Wohnzimmer
   dist_group_role none
   settingChannelInProgress 0
     2020-12-11 12:28:23   DLNARenderer    unknown
     2021-10-22 12:05:05   FirmwareAvailable 0
     2020-12-11 12:28:23   MediaServer     unknown
     2021-10-22 12:54:02   album_name
     2021-10-22 12:54:02   albumart_id     1155
     1                     albumart_url    http://192.168.0.116
     2021-10-22 12:54:02   auto_power_standby 0
     2020-05-17 20:15:12   currentFavNetRadioChannel 2
     2020-05-17 20:15:34   currentMenuName NET RADIO
     2020-05-17 20:15:34   currentMenuPlayingIndex -1
     2020-05-17 20:15:34   currentMenumaxItems 2
     2021-10-22 12:54:02   hdmi_out_1      false
     2021-10-22 12:54:02   hdmi_out_2      false
     2021-10-22 12:54:02   headphone       false
     2021-01-23 14:07:51   input           tv
     2021-10-22 12:54:02   ir_sensor       false
     2021-10-22 12:54:02   last_error      Invalid Parameter (Out of range, invalid characters etc.)
     2021-10-22 12:54:02   linkedClients
     2021-10-22 12:54:02   max_volume      100
     2020-05-17 11:18:39   mute            0
     2021-10-22 12:54:02   party_mode      false
     2021-10-22 12:54:02   play_time       0
     2021-10-22 12:54:02   playback_input  server
     2021-10-22 12:54:02   playback_status stop
     2021-10-22 12:05:05   power           on
     2021-10-22 12:53:58   presence        present
     2021-10-22 12:54:02   repeat_status   off
     2021-10-22 12:54:02   response_code   0
     2021-10-22 12:54:02   shuffle_status  off
     2020-05-17 11:18:39   sound_program   off
     2021-10-22 12:54:02   speaker_a       false
     2021-10-22 12:54:02   speaker_b       false
     2021-10-22 12:54:02   state           on
     2021-10-22 12:54:02   station_name
     2021-10-22 12:54:02   total_time      0
     2021-10-22 12:54:02   track
     2021-10-22 12:05:05   volume          52
   helper:
     AVAILABLE  1
     DISABLED   0
     RUNNING_REQUEST 0
     TIMEOUT_COUNT 0
     inputs_comma
     inputs_piped
     menuitems_comma
     menuitems_piped
     soundprograms_comma
     CMD_QUEUE:
     SELECTED_ZONE:
     ZONES:
     client_list:
   disable    1
   room       Wohnzimmer
2021.10.22 12:06:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 150 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:07:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 201 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:08:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 259 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:09:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 353 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 425 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 501 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:10:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 504 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:06 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 552 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 577 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 627 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:11:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 629 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 664 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 666 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 702 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:12:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 705 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 740 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 753 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 820 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:13:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 823 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:14:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 851 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:14:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 853 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 922 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 924 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1004 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:15:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1006 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1065 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1067 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1113 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:16:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1115 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:06 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1149 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1151 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1205 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:17:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1210 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1226 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1232 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1299 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:18:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1302 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1334 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1336 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1374 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:19:50 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1376 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:20:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1414 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:20:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1430 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1481 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1496 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1550 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:21:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1561 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1612 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:05 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1614 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1673 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:22:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1676 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1692 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1706 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:40 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1754 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:23:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1760 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1820 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1829 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1872 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:24:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1874 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:25:27 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1937 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:25:27 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1956 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 1999 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2009 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:33 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2064 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:26:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2067 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:07 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2127 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:08 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2135 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2173 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:27:41 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2182 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:28:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2231 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:28:22 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2233 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2299 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2308 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2343 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:29:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2345 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2429 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2431 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:46 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2488 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:30:47 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2502 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:17 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2565 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2577 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2625 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:31:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2632 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:24 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2661 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:25 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2669 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:58 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2717 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:32:59 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2719 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:33:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2761 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:33:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2767 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2850 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:03 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2866 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:35 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2883 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:34:36 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2892 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:09 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2974 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 2989 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3045 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:35:44 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3047 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3128 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:17 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3148 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3193 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:36:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3195 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:20 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3255 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3269 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3317 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:37:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3319 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:25 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3373 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:26 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3403 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:56 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3447 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:38:57 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3453 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:39:28 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3469 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:39:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3472 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:00 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3525 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3534 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3591 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:40:33 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3593 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3661 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:05 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3676 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:37 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3731 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:41:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3740 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:12 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3797 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:14 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3811 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:47 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3842 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:42:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3846 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3923 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:20 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3932 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3978 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:43:52 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 3983 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:44:29 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4074 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:44:31 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4083 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4125 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:03 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4153 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:38 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4194 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:45:39 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4196 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:10 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4267 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:11 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4276 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4312 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:46:43 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4327 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:14 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4386 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:15 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4394 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:46 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4436 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:47:48 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4468 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:19 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4522 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:21 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4531 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:53 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4598 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:48:54 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4607 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:49:30 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4643 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:49:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4645 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:02 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4687 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:04 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4727 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:40 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4747 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:50:42 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4756 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:16 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4850 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:18 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4852 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:49 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4890 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:51:51 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4898 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:22 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4963 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:23 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4965 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:52:59 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 4999 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:01 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5008 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:32 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5083 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
2021.10.22 12:53:34 2: DbLog logdb -> Error table history - DBD::mysql::st execute_array failed: executing 5097 generated 1 errors at ./FHEM/93_DbLog.pm line 2855.
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:.*
   FUUID      5c7ff2ee-f33f-c0e9-5666-b23d05e8cbd44787
   FVERSION   93_DbLog.pm:v4.12.3-s24440/2021-05-15
   MODE       asynchronous
   MODEL      MYSQL
   NAME       logdb
   NR         21
   NTFY_ORDER 50-logdb
   PID        15816
   REGEXP     .*:.*
   STATE      connected
   TYPE       DbLog
   UTF8       0
   dbconn     mysql:database=fhem;host=localhost;port=3306
   dbuser     fhemuser
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    4.12.3
   Helper:
     DBLOG:
       CacheOverflowLastNum:
         logdb:
           TIME       1634915239.20104
           VALUE      0
       CacheOverflowLastState:
         logdb:
           TIME       1634900114.95193
           VALUE      normal
       state:
         logdb:
           TIME       1634900041.60095
           VALUE      connected
     2021-10-22 17:07:19   CacheOverflowLastNum 0
     2021-10-22 12:55:14   CacheOverflowLastState normal
     2021-10-22 17:08:04   CacheUsage      91
     2021-10-22 17:07:19   NextSync        2021-10-22 17:08:19 or if CacheUsage 500 reached
     2017-07-29 15:08:31   countCurrent    0
     2017-07-29 15:08:30   countHistory    21
     2021-01-01 12:16:47   lastRowsDeleted 24835071
     2021-10-22 17:07:19   state           connected
   DbLogSelectionMode Exclude/Include
   asyncMode  1
   room       Server
   syncInterval 60
grüße
DS_Starter
da will ein Event nicht in die db. Du siehst ihn vermutlich wenn du dir zum geeigneten zeitpunkt den Ingalt des cache vom dblog anschaust. listCache
juppzupp
Die Frage die ich mir Stelle, ist ob das so "gewollt" ist, das ein Event die ganze logging Routine lahm legt.
DS_Starter
Nein und macht es ja auch nicht.  Oder ?
DS_Starter
Setz dir das attr commitMode ac:on_ta:off.
juppzupp
Ja doch. Ich hab's nur bemerkt weil alle Plots stehen geblieben sind.
DS_Starter
Dann sei froh sonst wärst du nicht darauf gekommen das mit dem yamaha was nicht stimmt.
juppzupp
output von inform timer logdb
2021-10-24 11:08:54 DbLog logdb CacheUsage: 88
2021-10-24 11:08:54 DbLog logdb DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:08:54 DbLog logdb CacheUsage: 89
2021-10-24 11:09:54 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:09:54 DbLog logdb CacheUsage: 182
2021-10-24 11:10:54 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:10:54 DbLog logdb CacheUsage: 373
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastNum: 0
2021-10-24 11:11:52 DbLog logdb CacheUsage: 501
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastNum: 1
2021-10-24 11:11:52 DbLog logdb CacheOverflowLastState: exceeded
2021-10-24 11:11:52 DbLog logdb NextSync: 2021-10-24 11:12:52 or if CacheUsage 500 reached
2021-10-24 11:11:52 DbLog logdb DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:11:52 DbLog logdb DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
2021-10-24 11:11:52 DbLog logdb CacheUsage: 2
2021-10-24 11:11:52 DbLog logdb CacheUsage: 504
output set logdb listCache
[code]240747 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42643.5|energy|42643.5|
240748 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 58.88|power|58.88|
240749 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|statEnergyCalc|Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|
240750 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 17.6|statEnergyCalcHour|17.6|
240751 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 42.7|statEnergyCalcDay|42.7|
240752 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 479.5|statEnergyCalcMonth|479.5|
240753 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25281.2|statEnergyCalcYear|25281.2|
240754 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|statEnergy|Hour: 17.6 Day: 42.7 Month: 479.5 Year: 25281.2|
240755 => 2021-10-24 11:13:01|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.84|statPowerDayAvg|3.84|
240756 => 2021-10-24 11:13:01|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
|state|DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server vers|
240757 => 2021-10-24 11:12:29|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
240758 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80270.5|statEnergyCalcYear|80270.5|
240759 => 2021-10-24 11:11:52|logdb|DBLOG|state: DBD::mysql::st execute failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 at ./FHEM/93_DbLog.pm line 2644.
240760 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|volume: 15|volume|15|
240761 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240762 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240763 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240764 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240765 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240766 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|station_name: |station_name||
240767 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|album_name: |album_name||
240768 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|track: |track||
240769 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240770 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240771 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240772 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240773 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240774 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240775 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240776 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240777 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240778 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240779 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240780 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240781 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240782 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240783 => 2021-10-24 11:07:57|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240784 => 2021-10-24 11:08:02|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240785 => 2021-10-24 11:08:06|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240786 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|current: 380|current|380|
240787 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42638.7|energy|42638.7|
240788 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 59.88|power|59.88|
240789 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|statEnergyCalc|Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|
240790 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 12.8|statEnergyCalcHour|12.8|
240791 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 37.9|statEnergyCalcDay|37.9|
240792 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 474.7|statEnergyCalcMonth|474.7|
240793 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25276.4|statEnergyCalcYear|25276.4|
240794 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.44|statPowerDayAvg|3.44|
240795 => 2021-10-24 11:08:08|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|statEnergy|Hour: 12.8 Day: 37.9 Month: 474.7 Year: 25276.4|
240796 => 2021-10-24 11:08:10|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
240797 => 2021-10-24 11:08:10|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Power: 0|ENERGY_Power|0|
240798 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519947.2|1-0_1.8.0_255_value|11519947.2|
240799 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519947.2|1-0_1.8.1_255_value|11519947.2|
240800 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
240801 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
240802 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
240803 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
240804 => 2021-10-24 11:08:12|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 54|1-0_16.7.0_255_value|54|
240805 => 2021-10-24 11:08:15|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240806 => 2021-10-24 11:08:16|LaCrosse_02|LACROSSE|humidity: 58|humidity|58|%
240807 => 2021-10-24 11:08:19|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240808 => 2021-10-24 11:08:23|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240809 => 2021-10-24 11:08:26|LaCrosse_12|LACROSSE|temperature: 7|temperature|7|°C
240810 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 86.4|ENERGY_ApparentPower|86.4|
240811 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 69.9|ENERGY_ReactivePower|69.9|
240812 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:08:31|Time|2021-10-24T11:08:31|
240813 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.371|ENERGY_Current|0.371|
240814 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.749|ENERGY_Total|961.749|
240815 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.9|ENERGY_Power|50.9|
240816 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 233.0|ENERGY_Voltage|233.0|
240817 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.9|statENERGY_PowerHourAvg|50.9|
240818 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerDayAvg: 51.0|statENERGY_PowerDayAvg|51.0|
240819 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.010|statENERGY_TotalHour|0.010|
240820 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.572|statENERGY_TotalDay|0.572|
240821 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.015|statENERGY_TotalMonth|28.015|
240822 => 2021-10-24 11:08:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.994|statENERGY_TotalYear|362.994|
240823 => 2021-10-24 11:08:32|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240824 => 2021-10-24 11:08:36|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240825 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|battery: ok|battery|ok|
240826 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|batteryLevel: 2.9|batteryLevel|2.9|
240827 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|desired-temp: 21.0|desired-temp|21.0|
240828 => 2021-10-24 11:08:41|CUL_HM_HM_TC_IT_WM_W_EU_3226D3|CUL_HM|measured-temp: 22.7|measured-temp|22.7|
240829 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
240830 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
240831 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
240832 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
240833 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
240834 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 17.0 Day: 2158.1 Month: 128174.0 Year: 307040.5 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 17.0 Day: 2158.1 Month: 128174.0 Year: 307040.5 (since: 2021-08-16 )|
240835 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 17.0|stat1-0_1.8.0_255_valueHour|17.0|
240836 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2158.1|stat1-0_1.8.0_255_valueDay|2158.1|
240837 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128174.0|stat1-0_1.8.0_255_valueMonth|128174.0|
240838 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307040.5|stat1-0_1.8.0_255_valueYear|307040.5|
240839 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -97|1-0_36.7.0_255_value|-97|
240840 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 6|1-0_56.7.0_255_value|6|
240841 => 2021-10-24 11:08:43|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 147|1-0_76.7.0_255_value|147|
240842 => 2021-10-24 11:08:45|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240843 => 2021-10-24 11:08:46|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 235|ENERGY_Voltage|235|
240844 => 2021-10-24 11:08:49|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240845 => 2021-10-24 11:08:50|eaton|NUT|ups.load: 14|ups.load|14|
240846 => 2021-10-24 11:08:51|CUL_HM_HM_TC_IT_WM_W_EU_3226D3_Weather|CUL_HM|temperature: 22.7|temperature|22.7|°C
240847 => 2021-10-24 11:08:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
240848 => 2021-10-24 11:08:54|logdb|DBLOG|state: DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
|state|DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
240849 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240850 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240851 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240852 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240853 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240854 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|station_name: |station_name||
240855 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|album_name: |album_name||
240856 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|track: |track||
240857 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240858 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240859 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240860 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240861 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240862 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240863 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240864 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240865 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240866 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240867 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240868 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240869 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240870 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240871 => 2021-10-24 11:08:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240872 => 2021-10-24 11:09:04|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
240873 => 2021-10-24 11:09:13|OWX_28_FF6721361603|OWTHERM|temperature: 19.75|temperature|19.75|°C
240874 => 2021-10-24 11:09:13|LaCrosse_02|LACROSSE|temperature: 15.5|temperature|15.5|°C
240875 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519948.2|1-0_1.8.0_255_value|11519948.2|
240876 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519948.2|1-0_1.8.1_255_value|11519948.2|
240877 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
240878 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
240879 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
240880 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
240881 => 2021-10-24 11:09:13|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 54|1-0_16.7.0_255_value|54|
240882 => 2021-10-24 11:09:25|CUL_HM_HB_UW_Sen_THPL_I_E453C2|CUL_HM|batVoltage: 2.50|batVoltage|2.50|
240883 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|boot: off|boot|off|
240884 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|eState: E: 223777.7 P: 51|eState|E: 223777.7 P: 51|
240885 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|energy: 223777.7|energy|223777.7|
240886 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|energyCalc: 6934663.3|energyCalc|6934663.3|
240887 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|power: 51|power|51|
240888 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
240889 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalc: Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: 1626391.4|statEnergyCalc|Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: 1626391.4|
240890 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcHour: 18.5|statEnergyCalcHour|18.5|
240891 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcDay: 2162.6|statEnergyCalcDay|2162.6|
240892 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcMonth: 128408.7|statEnergyCalcMonth|128408.7|
240893 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergyCalcYear: 1626391.4|statEnergyCalcYear|1626391.4|
240894 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statEnergy: Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: -51330.0|statEnergy|Hour: 18.5 Day: 2162.6 Month: 128408.7 Year: -51330.0|
240895 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayMin: 10|statPowerDayMin|10|
240896 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayAvg: 197|statPowerDayAvg|197|
240897 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|statPowerDayMax: 2118|statPowerDayMax|2118|
240898 => 2021-10-24 11:09:28|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
240899 => 2021-10-24 11:09:28|HM_698044_IEC_02|CUL_HM|state: 223777.7|state|223777.7|
240900 => 2021-10-24 11:09:30|CUL_HM_HM_TC_IT_WM_W_EU_34B40A_Weather|CUL_HM|humidity: 61|humidity|61|%
240901 => 2021-10-24 11:09:30|CUL_HM_HM_TC_IT_WM_W_EU_34B40A_Weather|CUL_HM|temperature: 18.5|temperature|18.5|°C
240902 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 68.5|ENERGY_ReactivePower|68.5|
240903 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 85.1|ENERGY_ApparentPower|85.1|
240904 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.9|ENERGY_Voltage|229.9|
240905 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.4|ENERGY_Power|50.4|
240906 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.571|ENERGY_Today|0.571|
240907 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.370|ENERGY_Current|0.370|
240908 => 2021-10-24 11:09:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:09:31|Time|2021-10-24T11:09:31|
240909 => 2021-10-24 11:09:43|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Voltage: 229|ENERGY_Voltage|229|
240910 => 2021-10-24 11:09:43|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 0|ENERGY_Power|0|
240911 => 2021-10-24 11:09:45|LaCrosse_02|LACROSSE|temperature: 15.4|temperature|15.4|°C
240912 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
240913 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
240914 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
240915 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
240916 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
240917 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 17.9 Day: 2159.0 Month: 128174.9 Year: 307041.4 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 17.9 Day: 2159.0 Month: 128174.9 Year: 307041.4 (since: 2021-08-16 )|
240918 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 17.9|stat1-0_1.8.0_255_valueHour|17.9|
240919 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2159.0|stat1-0_1.8.0_255_valueDay|2159.0|
240920 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128174.9|stat1-0_1.8.0_255_valueMonth|128174.9|
240921 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307041.4|stat1-0_1.8.0_255_valueYear|307041.4|
240922 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -96|1-0_36.7.0_255_value|-96|
240923 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 6|1-0_56.7.0_255_value|6|
240924 => 2021-10-24 11:09:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 155|1-0_76.7.0_255_value|155|
240925 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|eState: E: 186760.5 P: 0.14 I: 1 U: 235.2 f: 49.99|eState|E: 186760.5 P: 0.14 I: 1 U: 235.2 f: 49.99|
240926 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|energy: 186760.5|energy|186760.5|
240927 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|energyCalc: 575809.2|energyCalc|575809.2|
240928 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
240929 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|power: 0.14|power|0.14|
240930 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|voltage: 235.2|voltage|235.2|
240931 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 4.6|statEnergyCalcHour|4.6|
240932 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 238.3|statEnergyCalcDay|238.3|
240933 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6827.4|statEnergyCalcMonth|6827.4|
240934 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80268.1|statEnergyCalcYear|80268.1|
240935 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.56|statPowerDayAvg|20.56|
240936 => 2021-10-24 11:09:50|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
240937 => 2021-10-24 11:09:50|eaton|NUT|ups.load: 15|ups.load|15|
240938 => 2021-10-24 11:09:53|LaCrosse_02|LACROSSE|temperature: 15.5|temperature|15.5|°C
240939 => 2021-10-24 11:09:53|LaCrosse_02|LACROSSE|humidity: 56|humidity|56|%
240940 => 2021-10-24 11:09:53|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
240941 => 2021-10-24 11:09:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
240942 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
240943 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
240944 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
240945 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
240946 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
240947 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|station_name: |station_name||
240948 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|album_name: |album_name||
240949 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|track: |track||
240950 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
240951 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
240952 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
240953 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
240954 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
240955 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
240956 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
240957 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
240958 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
240959 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
240960 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
240961 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
240962 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
240963 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
240964 => 2021-10-24 11:09:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
240965 => 2021-10-24 11:09:56|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
240966 => 2021-10-24 11:10:01|LaCrosse_02|LACROSSE|temperature: 15.4|temperature|15.4|°C
240967 => 2021-10-24 11:10:01|45er|DUMMY|uptime: 3895667.39|uptime|3895667.39|
240968 => 2021-10-24 11:10:01|twooone|DUMMY|cpu: 51.000|cpu|51.000|
240969 => 2021-10-24 11:10:01|camlight|DUMMY|hofpython: 127|hofpython|127|
240970 => 2021-10-24 11:10:01|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240971 => 2021-10-24 11:10:01|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240972 => 2021-10-24 11:10:01|camlight|DUMMY|hofpythonr: 129.23484126984127|hofpythonr|129.23484126984127|
240973 => 2021-10-24 11:10:01|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240974 => 2021-10-24 11:10:01|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240975 => 2021-10-24 11:10:02|camlight|DUMMY|hofpythong: 128.05662698412698|hofpythong|128.05662698412698|
240976 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240977 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240978 => 2021-10-24 11:10:02|camlight|DUMMY|feldpython: 154|feldpython|154|
240979 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240980 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240981 => 2021-10-24 11:10:02|LaCrosse_23|LACROSSE|temperature: 19.8|temperature|19.8|°C
240982 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythonr: 105.85717647058823|feldpythonr|105.85717647058823|
240983 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240984 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240985 => 2021-10-24 11:10:02|camlight|DUMMY|hofpythonb: 107.89746031746031|hofpythonb|107.89746031746031|
240986 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240987 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240988 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythong: 162.11891067538127|feldpythong|162.11891067538127|
240989 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
240990 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
240991 => 2021-10-24 11:10:02|twooone|DUMMY|fan1: 242.000|fan1|242.000|
240992 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 75.5|ENERGY_ReactivePower|75.5|
240993 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
240994 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 94.5|ENERGY_ApparentPower|94.5|
240995 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.2|ENERGY_Voltage|232.2|
240996 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 56.8|ENERGY_Power|56.8|
240997 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.572|ENERGY_Today|0.572|
240998 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.750|ENERGY_Total|961.750|
240999 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:03|Time|2021-10-24T11:10:03|
241000 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.407|ENERGY_Current|0.407|
241001 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.011|statENERGY_TotalHour|0.011|
241002 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.573|statENERGY_TotalDay|0.573|
241003 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.016|statENERGY_TotalMonth|28.016|
241004 => 2021-10-24 11:10:02|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.995|statENERGY_TotalYear|362.995|
241005 => 2021-10-24 11:10:02|camlight|DUMMY|feldpythonb: 211.2236688453159|feldpythonb|211.2236688453159|
241006 => 2021-10-24 11:10:02|camlight|DUMMY|HumanFeld: 329.4|HumanFeld|329.4|
241007 => 2021-10-24 11:10:02|camlight|DUMMY|HumanHof: 335.6|HumanHof|335.6|
241008 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.54|ENERGY_Factor|0.54|
241009 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 79.8|ENERGY_ReactivePower|79.8|
241010 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.7|ENERGY_Power|50.7|
241011 => 2021-10-24 11:10:03|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:04|Time|2021-10-24T11:10:04|
241012 => 2021-10-24 11:10:03|twooone|DUMMY|sys: 32.000|sys|32.000|
241013 => 2021-10-24 11:10:06|LaCrosse_23|LACROSSE|temperature: 19.9|temperature|19.9|°C
241014 => 2021-10-24 11:10:11|fh|PWM|roomsOn: 1|roomsOn|1|
241015 => 2021-10-24 11:10:11|fh|PWM|roomsOff: 2|roomsOff|2|
241016 => 2021-10-24 11:10:11|fh|PWM|avgPulseRoomsOn: 0.15|avgPulseRoomsOn|0.15|
241017 => 2021-10-24 11:10:11|fh|PWM|avgPulseRoomsOff: 0.00|avgPulseRoomsOff|0.00|
241018 => 2021-10-24 11:10:11|fh|PWM|pulseMax: 0.15|pulseMax|0.15|
241019 => 2021-10-24 11:10:11|fh|PWM|pulseSum: 0.15|pulseSum|0.15|
241020 => 2021-10-24 11:10:11|fh|PWM|pulseAvg: 0.05|pulseAvg|0.05|
241021 => 2021-10-24 11:10:11|fh|PWM|pulseAvg2: 0.07|pulseAvg2|0.07|
241022 => 2021-10-24 11:10:11|fh|PWM|pulseAvg3: 0.05|pulseAvg3|0.05|
241023 => 2021-10-24 11:10:11|LaCrosse_01|LACROSSE|temperature: 20.3|temperature|20.3|°C
241024 => 2021-10-24 11:10:11|ESPEasy_8fbh_Arbeitszimmer|ESPEASY|AZ: on|AZ|on|
241025 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.408|ENERGY_Current|0.408|
241026 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:14|Time|2021-10-24T11:10:14|
241027 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.2|ENERGY_Voltage|234.2|
241028 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 56.6|ENERGY_Power|56.6|
241029 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 95.6|ENERGY_ApparentPower|95.6|
241030 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 77.0|ENERGY_ReactivePower|77.0|
241031 => 2021-10-24 11:10:13|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.59|ENERGY_Factor|0.59|
241032 => 2021-10-24 11:10:13|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 7|ENERGY_Power|7|
241033 => 2021-10-24 11:10:13|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241034 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.3|ENERGY_Power|50.3|
241035 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:15|Time|2021-10-24T11:10:15|
241036 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 81.2|ENERGY_ReactivePower|81.2|
241037 => 2021-10-24 11:10:14|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.53|ENERGY_Factor|0.53|
241038 => 2021-10-24 11:10:15|LaCrosse_01|LACROSSE|temperature: 20.2|temperature|20.2|°C
241039 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519949.2|1-0_1.8.0_255_value|11519949.2|
241040 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519949.2|1-0_1.8.1_255_value|11519949.2|
241041 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
241042 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
241043 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
241044 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
241045 => 2021-10-24 11:10:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 70|1-0_16.7.0_255_value|70|
241046 => 2021-10-24 11:10:19|LaCrosse_01|LACROSSE|temperature: 20.3|temperature|20.3|°C
241047 => 2021-10-24 11:10:21|esp8266_2|DUMMY|level: 417.00|level|417.00|
241048 => 2021-10-24 11:10:22|LaCrosse_12|LACROSSE|temperature: 7.1|temperature|7.1|°C
241049 => 2021-10-24 11:10:28|esp8266_2|DUMMY|temperature: 19.00|temperature|19.00|
241050 => 2021-10-24 11:10:28|esp8266_2|DUMMY|trend: 0|trend|0|
241051 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241052 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|eState: E: 186760.8 P: 135.34 I: 1266 U: 233.9 f: 50.01|eState|E: 186760.8 P: 135.34 I: 1266 U: 233.9 f: 50.01|
241053 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|energy: 186760.8|energy|186760.8|
241054 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|energyCalc: 575809.5|energyCalc|575809.5|
241055 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|frequency: 50.01|frequency|50.01|
241056 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|power: 135.34|power|135.34|
241057 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|voltage: 233.9|voltage|233.9|
241058 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.54|statPowerDayAvg|20.54|
241059 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241060 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 4.9|statEnergyCalcHour|4.9|
241061 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 238.6|statEnergyCalcDay|238.6|
241062 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6827.7|statEnergyCalcMonth|6827.7|
241063 => 2021-10-24 11:10:28|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80268.4|statEnergyCalcYear|80268.4|
241064 => 2021-10-24 11:10:28|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241065 => 2021-10-24 11:10:29|esp8266_2|DUMMY|humidity: 43.50|humidity|43.50|
241066 => 2021-10-24 11:10:29|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
241067 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.3|ENERGY_ApparentPower|84.3|
241068 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
241069 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 67.6|ENERGY_ReactivePower|67.6|
241070 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:10:31|Time|2021-10-24T11:10:31|
241071 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.363|ENERGY_Current|0.363|
241072 => 2021-10-24 11:10:30|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.2|ENERGY_Voltage|232.2|
241073 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241074 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|eState: E: 186762 P: 639.22 I: 2743 U: 232.9 f: 49.99|eState|E: 186762 P: 639.22 I: 2743 U: 232.9 f: 49.99|
241075 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|energy: 186762|energy|186762|
241076 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|energyCalc: 575810.7|energyCalc|575810.7|
241077 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
241078 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|power: 639.22|power|639.22|
241079 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|voltage: 232.9|voltage|232.9|
241080 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 6.1|statEnergyCalcHour|6.1|
241081 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 239.8|statEnergyCalcDay|239.8|
241082 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6828.9|statEnergyCalcMonth|6828.9|
241083 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80269.6|statEnergyCalcYear|80269.6|
241084 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.56|statPowerDayAvg|20.56|
241085 => 2021-10-24 11:10:35|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241086 => 2021-10-24 11:10:35|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241087 => 2021-10-24 11:10:37|LaCrosse_02|LACROSSE|humidity: 56|humidity|56|%
241088 => 2021-10-24 11:10:41|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 233|ENERGY_Voltage|233|
241089 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|current: 375|current|375|
241090 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|energy: 42641.2|energy|42641.2|
241091 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|power: 57.52|power|57.52|
241092 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statPowerDayAvg: 3.65|statPowerDayAvg|3.65|
241093 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergy: Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|statEnergy|Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|
241094 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalc: Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|statEnergyCalc|Hour: 15.3 Day: 40.4 Month: 477.2 Year: 25278.9|
241095 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcHour: 15.3|statEnergyCalcHour|15.3|
241096 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcDay: 40.4|statEnergyCalcDay|40.4|
241097 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcMonth: 477.2|statEnergyCalcMonth|477.2|
241098 => 2021-10-24 11:10:42|CUL_HM_HM_ES_PMSw1_Pl_2E1AFF_Pwr|CUL_HM|statEnergyCalcYear: 25278.9|statEnergyCalcYear|25278.9|
241099 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241100 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|eState: E: 186762.9 P: 0.15 I: 1 U: 234.3 f: 49.99|eState|E: 186762.9 P: 0.15 I: 1 U: 234.3 f: 49.99|
241101 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|energy: 186762.9|energy|186762.9|
241102 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|energyCalc: 575811.6|energyCalc|575811.6|
241103 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|frequency: 49.99|frequency|49.99|
241104 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|power: 0.15|power|0.15|
241105 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|voltage: 234.3|voltage|234.3|
241106 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.69|statPowerDayAvg|20.69|
241107 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241108 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 7.0|statEnergyCalcHour|7.0|
241109 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 240.7|statEnergyCalcDay|240.7|
241110 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6829.8|statEnergyCalcMonth|6829.8|
241111 => 2021-10-24 11:10:43|HM_283B50_Pwr|CUL_HM|statEnergyCalcYear: 80270.5|statEnergyCalcYear|80270.5|
241112 => 2021-10-24 11:10:43|HM_283B50_Sw|CUL_HM|commState: CMDs_done|commState|CMDs_done|
241113 => 2021-10-24 11:10:44|LaCrosse_29|LACROSSE|temperature: 18.2|temperature|18.2|°C
241114 => 2021-10-24 11:10:44|HM_57D135_Motion|CUL_HM|brightness: 147|brightness|147|
241115 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
241116 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
241117 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
241118 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
241119 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
241120 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 21.4 Day: 2162.5 Month: 128178.4 Year: 307044.9 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 21.4 Day: 2162.5 Month: 128178.4 Year: 307044.9 (since: 2021-08-16 )|
241121 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 21.4|stat1-0_1.8.0_255_valueHour|21.4|
241122 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2162.5|stat1-0_1.8.0_255_valueDay|2162.5|
241123 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128178.4|stat1-0_1.8.0_255_valueMonth|128178.4|
241124 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307044.9|stat1-0_1.8.0_255_valueYear|307044.9|
241125 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -101|1-0_36.7.0_255_value|-101|
241126 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 12|1-0_56.7.0_255_value|12|
241127 => 2021-10-24 11:10:45|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 165|1-0_76.7.0_255_value|165|
241128 => 2021-10-24 11:10:47|ESPEasy_ESP_Kueche_LED_W|ESPEASY|state: absent|state|absent|
241129 => 2021-10-24 11:10:50|eaton|NUT|battery.runtime: 1500|battery.runtime|1500|
241130 => 2021-10-24 11:10:50|eaton|NUT|ups.load: 14|ups.load|14|
241131 => 2021-10-24 11:10:54|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241132 => 2021-10-24 11:10:54|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
241133 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
241134 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
241135 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
241136 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
241137 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
241138 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|station_name: |station_name||
241139 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|album_name: |album_name||
241140 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|track: |track||
241141 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
241142 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
241143 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
241144 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
241145 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
241146 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
241147 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
241148 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
241149 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
241150 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|speaker_b: false|speaker_b|false|
241151 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|headphone: false|headphone|false|
241152 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|hdmi_out_1: false|hdmi_out_1|false|
241153 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|hdmi_out_2: false|hdmi_out_2|false|
241154 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|ir_sensor: false|ir_sensor|false|
241155 => 2021-10-24 11:10:56|ysp2700|YAMAHA_MC|party_mode: false|party_mode|false|
241156 => 2021-10-24 11:10:59|CUL_HM_HM_TC_IT_WM_W_EU_3226D3_Weather|CUL_HM|humidity: 55|humidity|55|%
241157 => 2021-10-24 11:10:59|LaCrosse_12|LACROSSE|temperature: 7|temperature|7|°C
241158 => 2021-10-24 11:11:01|LaCrosse_02|LACROSSE|humidity: 57|humidity|57|%
241159 => 2021-10-24 11:11:02|ESPEasy_ESP_UV_sysinfo|ESPEASY|uptime: 33130|uptime|33130|
241160 => 2021-10-24 11:11:03|LaCrosse_12|LACROSSE|temperature: 7.1|temperature|7.1|°C
241161 => 2021-10-24 11:11:04|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 235|ENERGY_Voltage|235|
241162 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Today: 0.573|ENERGY_Today|0.573|
241163 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.751|ENERGY_Total|961.751|
241164 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:06|Time|2021-10-24T11:11:06|
241165 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.391|ENERGY_Current|0.391|
241166 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 58.1|ENERGY_Power|58.1|
241167 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 232.6|ENERGY_Voltage|232.6|
241168 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 90.9|ENERGY_ApparentPower|90.9|
241169 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 70.0|ENERGY_ReactivePower|70.0|
241170 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.64|ENERGY_Factor|0.64|
241171 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.012|statENERGY_TotalHour|0.012|
241172 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.574|statENERGY_TotalDay|0.574|
241173 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.017|statENERGY_TotalMonth|28.017|
241174 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.996|statENERGY_TotalYear|362.996|
241175 => 2021-10-24 11:11:05|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.8|statENERGY_PowerHourAvg|50.8|
241176 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 89.6|ENERGY_ApparentPower|89.6|
241177 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 73.6|ENERGY_ReactivePower|73.6|
241178 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.57|ENERGY_Factor|0.57|
241179 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:07|Time|2021-10-24T11:11:07|
241180 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.1|ENERGY_Voltage|229.1|
241181 => 2021-10-24 11:11:06|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 51.1|ENERGY_Power|51.1|
241182 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.0_255_value: 11519952.6|1-0_1.8.0_255_value|11519952.6|
241183 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.1_255_value: 11519952.6|1-0_1.8.1_255_value|11519952.6|
241184 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_1.8.2_255_value: 0.0|1-0_1.8.2_255_value|0.0|
241185 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.0_255_value: 10152.1|1-0_2.8.0_255_value|10152.1|
241186 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.1_255_value: 10152.1|1-0_2.8.1_255_value|10152.1|
241187 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_2.8.2_255_value: 0.0|1-0_2.8.2_255_value|0.0|
241188 => 2021-10-24 11:11:17|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_16.7.0_255_value: 41|1-0_16.7.0_255_value|41|
241189 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.365|ENERGY_Current|0.365|
241190 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:22|Time|2021-10-24T11:11:22|
241191 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 59.9|ENERGY_Power|59.9|
241192 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 229.5|ENERGY_Voltage|229.5|
241193 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 83.8|ENERGY_ApparentPower|83.8|
241194 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.72|ENERGY_Factor|0.72|
241195 => 2021-10-24 11:11:21|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 58.6|ENERGY_ReactivePower|58.6|
241196 => 2021-10-24 11:11:22|LaCrosse_14|LACROSSE|temperature: -18.6|temperature|-18.6|°C
241197 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.53|ENERGY_Factor|0.53|
241198 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 82.6|ENERGY_ReactivePower|82.6|
241199 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 97.3|ENERGY_ApparentPower|97.3|
241200 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 51.5|ENERGY_Power|51.5|
241201 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.424|ENERGY_Current|0.424|
241202 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:23|Time|2021-10-24T11:11:23|
241203 => 2021-10-24 11:11:22|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_PowerHourAvg: 50.9|statENERGY_PowerHourAvg|50.9|
241204 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_PowerHourAvg: 180|statENERGY_PowerHourAvg|180|
241205 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_Total: Hour: 0.030 Day: 0.213 Month: 12.094 Year: 183.651 (since: 2021-03-31_10:36:04 )|statENERGY_Total|Hour: 0.030 Day: 0.213 Month: 12.094 Year: 183.651 (since: 2021-03-31_10:36:04 )|
241206 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalDay: 0.213|statENERGY_TotalDay|0.213|
241207 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalMonth: 12.094|statENERGY_TotalMonth|12.094|
241208 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalYear: 183.651|statENERGY_TotalYear|183.651|
241209 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|ENERGY_Power: 186|ENERGY_Power|186|
241210 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|ENERGY_Today: 0.228|ENERGY_Today|0.228|
241211 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_Total: Hour: 0.046 Day: 0.229 Month: 12.110 Year: 183.667 (since: 2021-03-31_10:36:04 )|statENERGY_Total|Hour: 0.046 Day: 0.229 Month: 12.110 Year: 183.667 (since: 2021-03-31_10:36:04 )|
241212 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalDay: 0.229|statENERGY_TotalDay|0.229|
241213 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalMonth: 12.110|statENERGY_TotalMonth|12.110|
241214 => 2021-10-24 11:11:24|MQTT2_DVES_548DF2|MQTT2_DEVICE|statENERGY_TotalYear: 183.667|statENERGY_TotalYear|183.667|
241215 => 2021-10-24 11:11:29|LaCrosse_17|LACROSSE|humidity: 53|humidity|53|%
241216 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|boot: off|boot|off|
241217 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|eState: E: 223781.6 P: 45|eState|E: 223781.6 P: 45|
241218 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|energy: 223781.6|energy|223781.6|
241219 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|energyCalc: 6934667.2|energyCalc|6934667.2|
241220 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|power: 45|power|45|
241221 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
241222 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalc: Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: 1626395.3|statEnergyCalc|Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: 1626395.3|
241223 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcHour: 22.4|statEnergyCalcHour|22.4|
241224 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcDay: 2166.5|statEnergyCalcDay|2166.5|
241225 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcMonth: 128412.6|statEnergyCalcMonth|128412.6|
241226 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergyCalcYear: 1626395.3|statEnergyCalcYear|1626395.3|
241227 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayMin: 10|statPowerDayMin|10|
241228 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayAvg: 197|statPowerDayAvg|197|
241229 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statPowerDayMax: 2118|statPowerDayMax|2118|
241230 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|statEnergy: Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: -51326.1|statEnergy|Hour: 22.4 Day: 2166.5 Month: 128412.6 Year: -51326.1|
241231 => 2021-10-24 11:11:36|HM_698044_IEC_01|CUL_HM|kWh: 11529.7|kWh|11529.7|
241232 => 2021-10-24 11:11:36|HM_698044_IEC_02|CUL_HM|state: 223781.6|state|223781.6|
241233 => 2021-10-24 11:11:38|LaCrosse_17|LACROSSE|temperature: 21.4|temperature|21.4|°C
241234 => 2021-10-24 11:11:44|MQTT2_DVES_832F7F|MQTT2_DEVICE|ENERGY_Voltage: 234|ENERGY_Voltage|234|
241235 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_value: Hour: 22.3 Day: 2163.4 Month: 128179.3 Year: 307045.8 (since: 2021-08-16 )|stat1-0_1.8.0_255_value|Hour: 22.3 Day: 2163.4 Month: 128179.3 Year: 307045.8 (since: 2021-08-16 )|
241236 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueHour: 22.3|stat1-0_1.8.0_255_valueHour|22.3|
241237 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueDay: 2163.4|stat1-0_1.8.0_255_valueDay|2163.4|
241238 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueMonth: 128179.3|stat1-0_1.8.0_255_valueMonth|128179.3|
241239 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_1.8.0_255_valueYear: 307045.8|stat1-0_1.8.0_255_valueYear|307045.8|
241240 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_value: Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|stat1-0_2.8.0_255_value|Hour: 0.0 Day: 0.3 Month: 213.0 Year: 2789.8 (since: 2021-08-16 )|
241241 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueHour: 0.0|stat1-0_2.8.0_255_valueHour|0.0|
241242 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueDay: 0.3|stat1-0_2.8.0_255_valueDay|0.3|
241243 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueMonth: 213.0|stat1-0_2.8.0_255_valueMonth|213.0|
241244 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|stat1-0_2.8.0_255_valueYear: 2789.8|stat1-0_2.8.0_255_valueYear|2789.8|
241245 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_36.7.0_255_value: -100|1-0_36.7.0_255_value|-100|
241246 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_56.7.0_255_value: 11|1-0_56.7.0_255_value|11|
241247 => 2021-10-24 11:11:49|MQTT2_esp8266_02A548|MQTT2_DEVICE|1-0_76.7.0_255_value: 133|1-0_76.7.0_255_value|133|
241248 => 2021-10-24 11:11:50|eaton|NUT|battery.runtime: 1450|battery.runtime|1450|
241249 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|eState: E: 186762.9 P: 0.14 I: 1 U: 234.8 f: 50.01|eState|E: 186762.9 P: 0.14 I: 1 U: 234.8 f: 50.01|
241250 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|energy: 186762.9|energy|186762.9|
241251 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|energyCalc: 575811.6|energyCalc|575811.6|
241252 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|frequency: 50.01|frequency|50.01|
241253 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|power: 0.14|power|0.14|
241254 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|voltage: 234.8|voltage|234.8|
241255 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statPowerDayAvg: 20.65|statPowerDayAvg|20.65|
241256 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statPowerDayMax: 704.06|statPowerDayMax|704.06|
241257 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcHour: 7.0|statEnergyCalcHour|7.0|
241258 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcDay: 240.7|statEnergyCalcDay|240.7|
241259 => 2021-10-24 11:11:52|HM_283B50_Pwr|CUL_HM|statEnergyCalcMonth: 6829.8|statEnergyCalcMonth|6829.8|
241260 => 2021-10-24 11:11:52|logdb|DBLOG|CacheOverflowLastNum: 0|CacheOverflowLastNum|0|
241261 => 2021-10-24 11:11:52|logdb|DBLOG|state: DBD::mysql::st execute failed: Incorrect datetime value: '1' for column 'TIMESTAMP' at row 10 at ./FHEM/93_DbLog.pm line 2644.
241262 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 62.3|ENERGY_ReactivePower|62.3|
241263 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.68|ENERGY_Factor|0.68|
241264 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.7|ENERGY_ApparentPower|84.7|
241265 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.6|ENERGY_Voltage|234.6|
241266 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 57.4|ENERGY_Power|57.4|
241267 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Total: 961.752|ENERGY_Total|961.752|
241268 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:53|Time|2021-10-24T11:11:53|
241269 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Current: 0.361|ENERGY_Current|0.361|
241270 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalHour: 0.013|statENERGY_TotalHour|0.013|
241271 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalDay: 0.575|statENERGY_TotalDay|0.575|
241272 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalMonth: 28.018|statENERGY_TotalMonth|28.018|
241273 => 2021-10-24 11:11:52|MQTT2_DVES_62DF7B|MQTT2_DEVICE|statENERGY_TotalYear: 362.997|statENERGY_TotalYear|362.997|
241274 => 2021-10-24 11:11:52|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|Wifi_Signal: -58|Wifi_Signal|-58|
241275 => 2021-10-24 11:11:52|MQTT2_DVES_8B9CBD|MQTT2_DEVICE|ENERGY_Power: 1|ENERGY_Power|1|
241276 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Voltage: 234.2|ENERGY_Voltage|234.2|
241277 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Power: 50.4|ENERGY_Power|50.4|
241278 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|Time: 2021-10-24T11:11:54|Time|2021-10-24T11:11:54|
241279 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ReactivePower: 67.9|ENERGY_ReactivePower|67.9|
241280 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_Factor: 0.60|ENERGY_Factor|0.60|
241281 => 2021-10-24 11:11:53|MQTT2_DVES_62DF7B|MQTT2_DEVICE|ENERGY_ApparentPower: 84.5|ENERGY_ApparentPower|84.5|
241282 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|max_volume: 100|max_volume|100|
241283 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|last_error: Invalid Parameter (Out of range, invalid characters etc.)|last_error|Invalid Parameter (Out of range, invalid characters etc.)|
241284 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|response_code: 4|response_code|4|
241285 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|playback_input: server|playback_input|server|
241286 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|playback_status: stop|playback_status|stop|
241287 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|station_name: |station_name||
241288 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|album_name: |album_name||
241289 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|track: |track||
241290 => 1|ysp2700|YAMAHA_MC|albumart_url: http://192.168.0.116|albumart_url|http://192.168.0.116|
241291 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|albumart_id: 7718|albumart_id|7718|
241292 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|repeat_status: off|repeat_status|off|
241293 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|shuffle_status: off|shuffle_status|off|
241294 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|play_time: 0|play_time|0|
241295 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|total_time: 0|total_time|0|
241296 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|linkedClients: |linkedClients||
241297 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|auto_power_standby: 0|auto_power_standby|0|
241298 => 2021-10-24 11:11:56|ysp2700|YAMAHA_MC|speaker_a: false|speaker_a|false|
241299 => 2021-10-24 11:11:56|ysp2
DS_Starter
Ja, du siehst dass der Event des Readings albumart_url keinen Timestamp hat:
Wenn du mit den anderen Einträgen im Cache vergleichst, siehst du ja wie der Timestamp aufgebaut ist.
Jetzt wo es mir aufgefallen ist, sieht man es auch schon in deinem List von YAMAHA:
     2020-12-11 12:28:23   DLNARenderer    unknown
     2021-10-22 12:05:05   FirmwareAvailable 0
     2020-12-11 12:28:23   MediaServer     unknown
     2021-10-22 12:54:02   album_name
     2021-10-22 12:54:02   albumart_id     1155
     1                     albumart_url    http://192.168.0.116
     2021-10-22 12:54:02   auto_power_standby 0
     2020-05-17 20:15:12   currentFavNetRadioChannel 2
     2020-05-17 20:15:34   currentMenuName NET RADIO
     2020-05-17 20:15:34   currentMenuPlayingIndex -1
     2020-05-17 20:15:34   currentMenumaxItems 2
     2021-10-22 12:54:02   hdmi_out_1      false
     2021-10-22 12:54:02   hdmi_out_2      false
     2021-10-22 12:54:02   headphone       false
Kein Wunder dass DbLog bzw. die DB es nicht verarbeiten kann.
juppzupp
ich werde versuchen den mainainer darauf aufmerksam zu machen. trotzdem stellt sich mir die frage, ob man sowas (zukünftig) in logdb abfangen will, ich finde ein modul/device sollte nicht die ganze db lahmlegen können.
danke fürs schauen.
DS_Starter
Dafür gibt es ja das Attribut commitMode. Es steuert ob das Wegschreiben in die DB als Transaktion ausgeführt wird oder nicht.
Es ist wichtig um temporäre Fehler der DB (z.B. Wartungsmodus, Absturz, etc. ) abzufangen und die Events im Cache zu behalten damit sie nicht verloren gehen. Mit entsprechenden Einstellungen des CommitMode kann der User das Verhalten in solchen Fällen korrigieren.
Insofern hat der User alle Möglichkeiten. Und ich bzw. DbLog kann auch nicht alle eventuell auftretenden Fehlervarianten vordenken und abfangen. Da muß der User schonmal selber mit ran  ;).
Im synchronen Modus hat man dieses Problem übrigens nicht ... dafür aber andere.  :)
juppzupp
Das hatte ich noch gar nicht gesetzt, danke für die erinnerung.
