Smartmatch is experimental in fhem.pl
Begonnen von dieter56, 19 Juli 2021, 08:07:00
dieter56
gelegentlich taucht in meiner Log-Datei folgende Fehlermeldung auf.
2021.07.19 07:47:30 1: PERL WARNING: Smartmatch is experimental at (eval 2172903) line 1.
2021.07.19 07:47:30 3: eval: my $EVENT=   $evalSpecials->{'%EVENT'};my $EVTPART0=   $evalSpecials->{'%EVTPART0'};my $NAME=   $evalSpecials->{'%NAME'};my $SELF=   $evalSpecials->{'%SELF'};my $TYPE=   $evalSpecials->{'%TYPE'};{ if( ($EVENT ~~ / /) and ($EVENT !~ /: /) ) {fhem("setreading $NAME $EVENT")} }
2021.07.19 07:47:30 1: stacktrace:
2021.07.19 07:47:30 1:     main::__ANON__                      called by (eval 2172903) (1)
2021.07.19 07:47:30 1:     (eval)                              called by fhem.pl (1161)
2021.07.19 07:47:30 1:     main::AnalyzePerlCommand            called by fhem.pl (1190)
2021.07.19 07:47:30 1:     main::AnalyzeCommand                called by fhem.pl (1117)
2021.07.19 07:47:30 1:     main::AnalyzeCommandChain           called by ./FHEM/91_notify.pm (121)
2021.07.19 07:47:30 1:     main::notify_Exec                   called by fhem.pl (3893)
2021.07.19 07:47:30 1:     main::CallFn                        called by fhem.pl (3810)
2021.07.19 07:47:30 1:     main::DoTrigger                     called by fhem.pl (4895)
2021.07.19 07:47:30 1:     main::readingsEndUpdate             called by fhem.pl (5078)
2021.07.19 07:47:30 1:     main::readingsSingleUpdate          called by ./FHEM/98_dummy.pm (73)
2021.07.19 07:47:30 1:     main::dummy_Set                     called by fhem.pl (3888)
2021.07.19 07:47:30 1:     main::CallFn                        called by fhem.pl (1938)
2021.07.19 07:47:30 1:     main::DoSet                         called by fhem.pl (1971)
2021.07.19 07:47:30 1:     main::CommandSet                    called by fhem.pl (1266)
2021.07.19 07:47:30 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2775)
2021.07.19 07:47:30 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (963)
2021.07.19 07:47:30 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (598)
2021.07.19 07:47:30 1:     main::FW_Read                       called by fhem.pl (3893)
2021.07.19 07:47:30 1:     main::CallFn                        called by fhem.pl (774)
Was hat es damit auf sich? Ist da Code in fhem.pl nicht PERL-Standardkonform? Wie kann man das beheben?
Dieter
a) WARNING != Fehler...
b) Die tiefere Ursache ist Code, den du selbst als <command> in einem notify stehen hast:
{ if( ($EVENT ~~ / /) and ($EVENT !~ /: /) ) {fhem("setreading $NAME $EVENT")} }Sollte sich durch "configdb search" bzw. eine Textsuche in der fhem.cfg aufdecken lassen, welches notify das ist ;) .
(Der Sinn dieses notify erschließt sich mir nicht so recht, sieht nach einem Test aus).
c) Obwohl kein Fehler, ist es sinnvoll, "smartmatch" zu vermeiden, das scheint sich nicht durchgesetzt zu haben.
dieter56
Danke; ich werde mich auf die Suche begeben.
