Log Warnung Cul-HM
Begonnen von Tommy82, 19 August 2015, 07:02:06
Tommy82
ich habe seit heute diese Meldung im Log
2015.08.19 06:59:10.167 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 5992.
Scheint nichts gravierendes zu sein, trotzdem wüsste ich gerne was sie verursacht
EDIt
stacktrace liefert
2015.08.19 20:46:08.674 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 5992.
2015.08.19 20:46:08.674 3: stacktrace:
2015.08.19 20:46:08.675 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (5992)
2015.08.19 20:46:08.675 3:     main::CUL_HM_respPendRm             called by ./FHEM/10_CUL_HM.pm (6243)
2015.08.19 20:46:08.676 3:     main::CUL_HM_eventP                 called by ./FHEM/10_CUL_HM.pm (5870)
2015.08.19 20:46:08.676 3:     main::CUL_HM_SndCmd                 called by ./FHEM/10_CUL_HM.pm (1302)
2015.08.19 20:46:08.676 3:     main::CUL_HM_Parse                  called by fhem.pl (3184)
2015.08.19 20:46:08.676 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (737)
2015.08.19 20:46:08.677 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.08.19 20:46:08.677 3:     main::HMLAN_Read                    called by fhem.pl (3046)
2015.08.19 20:46:08.677 3:     main::CallFn                        called by fhem.pl (649)
Allnetl Wandtablett mit FTUI
Tommy82
ich hab gestern abend Fhem aktualisiert und heute zwei Meldungen im Log:
2016.04.24 10:53:16.327 1: PERL WARNING: Use of uninitialized value $list in pattern match (m//) at ./FHEM/10_CUL_HM.pm line 4012
2016.04.24 18:22:23.597 1: PERL WARNING: Argument "C4" isn't numeric in numeric eq (==) at ./FHEM/10_CUL_HM.pm line 3018.
Tommy82
ich habe nach einem Fhem Neustart diese Meldungen im Log:
2021.08.17 08:07:21.632 3: Device Terassen_Tuer added to ActionDetector with 028:00 time
2021.08.17 08:07:24.025 2: HMinfo hm get:configCheck :-f,^(unknown_2D5FAB|unknown_2D5FAB)$
2021.08.17 08:07:24.099 1: PERL WARNING: substr outside of string at ./FHEM/10_CUL_HM.pm line 10699.
2021.08.17 08:07:24.100 1: stacktrace:
2021.08.17 08:07:24.101 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (10699)
2021.08.17 08:07:24.101 1:     main::CUL_HM_UpdtCentral            called by ./FHEM/10_CUL_HM.pm (345)
2021.08.17 08:07:24.102 1:     main::CUL_HM_updateConfig           called by fhem.pl (3426)
2021.08.17 08:07:24.103 1:     main::HandleTimeout                 called by fhem.pl (695)
2021.08.17 08:07:24.104 1: PERL WARNING: Use of uninitialized value in hex at ./FHEM/10_CUL_HM.pm line 10699.
2021.08.17 08:07:24.105 1: stacktrace:
2021.08.17 08:07:24.105 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (10699)
2021.08.17 08:07:24.106 1:     main::CUL_HM_UpdtCentral            called by ./FHEM/10_CUL_HM.pm (345)
2021.08.17 08:07:24.106 1:     main::CUL_HM_updateConfig           called by fhem.pl (3426)
2021.08.17 08:07:24.107 1:     main::HandleTimeout                 called by fhem.pl (695)
2021.08.17 08:07:24.110 1: PERL WARNING: Use of uninitialized value $a[2] in uc at ./FHEM/10_CUL_HM.pm line 571.
2021.08.17 08:07:24.111 1: stacktrace:
2021.08.17 08:07:24.112 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (571)
2021.08.17 08:07:24.113 1:     main::CUL_HM_Define                 called by fhem.pl (3889)
2021.08.17 08:07:24.114 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2021.08.17 08:07:24.114 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2021.08.17 08:07:24.115 1:     main::__ANON__                      called by fhem.pl (2127)
2021.08.17 08:07:24.116 1:     main::CommandDefine                 called by ./FHEM/10_CUL_HM.pm (10700)
2021.08.17 08:07:24.116 1:     main::CUL_HM_UpdtCentral            called by ./FHEM/10_CUL_HM.pm (345)
2021.08.17 08:07:24.117 1:     main::CUL_HM_updateConfig           called by fhem.pl (3426)
2021.08.17 08:07:24.117 1:     main::HandleTimeout                 called by fhem.pl (695)
2021.08.17 08:07:24.118 1: define vccu_Btn0 CUL_HM : wrong syntax: define <name> CUL_HM 6-digit-hex-code [Raw-Message]
2021.08.17 08:07:24.288 1: CUL_HM finished initial cleanup
Wo liegt da der Fehler?
