DOIF sendet falsches set Mqtt2 Wled
Begonnen von DrNuke33, 08 November 2021, 21:16:46
DrNuke33
Hi habe folgenes problem wenn ich ein set an das Wled sende über DOIF setzt er eine 0 dahinter z.B. (set WLED_35a31c rgb 0000FF) im Wled kommt der wert 000FF0 an.
direkt über die leiste geht der set befehl.
jemand ein tip
DIOF
defmod di_Bewegungsmelder_Haustur_02 DOIF ([HM_HmIP_FCI1_00:state] eq "0")\
(set WLED_35a31c palette 3)\
(set WLED_35a31c rgb FF0000)\
(set WLED_35a31c brightness 255)\
(set WLED_35a31c effect 0)\
(set WLED_35a31c speed 140)\
DOELSEIF\
([HM_HmIP_FCI1_00:state] eq "1")\
(set WLED_35a31c rgb 0000FF)\
attr di_Bewegungsmelder_Haustur_02 DbLogExclude .*
attr di_Bewegungsmelder_Haustur_02 event-on-change-reading .*
WLED
defmod WLED_35a31c MQTT2_DEVICE WLED_35a31c
attr WLED_35a31c DbLogExclude .*
attr WLED_35a31c comment For questions about the use of different widgets for color selection see discussion at https://forum.fhem.de/index.php/topic,98880.msg995308.html
attr WLED_35a31c devStateIcon {Color::devStateIcon( $name, "rgb", "rgb", "brightness", "state" )}
attr WLED_35a31c event-on-change-reading .*
attr WLED_35a31c eventMap /effect 0:Solid/effect 2:Breathe/effect 63:Pride/effect 48:Police/
attr WLED_35a31c gassistantName LED Vorgarten 1
attr WLED_35a31c genericDeviceType light
attr WLED_35a31c group LED Vorgarten 1
attr WLED_35a31c homebridgeMapping Brightness=brightness::brightness,maxValue=100,factor=0.39216,delay=true
attr WLED_35a31c icon hue_filled_iris
attr WLED_35a31c model wled_controller
attr WLED_35a31c oldreadings .*
attr WLED_35a31c readingList wled/35a31c/status:.* LWT\
  wled/35a31c/g:.* brightness\
  wled/35a31c/g:.* { $EVENT ? {"state"=>"on"} : {"state"=>"off"} }\
  wled/35a31c/c:.* { {"rgb"=>substr("$EVENT",1,6)} }\
  wled/35a31c/v:.* api\
  wled/35a31c/v:.* { $EVENT =~ m,(?<=<sx>)([\d]+)(?=<\/sx>), ? $1 eq ReadingsVal($NAME,"speed","unknown") ? return : {"speed"=>$1} : return;; }\
  wled/35a31c/v:.* {$EVENT =~ m,(?<=<ix>)([\d]+)(?=<\/ix>), ? $1 eq ReadingsVal($NAME,"intensity","unknown") ? return : {"intensity"=>$1} : return }\
  wled/35a31c/v:.* {$EVENT =~ m,(?<=<fp>)([\d]+)(?=<\/fp>), ? $1 eq ReadingsVal($NAME,"palette","unknown") ? return : {"palette"=>$1} : return }\
  wled/35a31c/v:.* {$EVENT =~ m,(?<=<fx>)([\d]+)(?=<\/fx>), ? $1 eq ReadingsVal($NAME,"effect","unknown") ? return :{"effect"=>"$1"} : return }
attr WLED_35a31c room 1.5_Licht_Aussen,9.5_Mqtt,GoogleAssistant
attr WLED_35a31c setList on:noArg wled/35a31c on\
  off:noArg wled/35a31c off\
  toggle:noArg wled/35a31c t\
  rgb:colorpicker,RGB wled/35a31c/col #$EVTPART1\
  brightness:colorpicker,BRI,0,1,255 wled/35a31c\
  speed:colorpicker,BRI,0,1,255 wled/35a31c/api SX=$EVTPART1\
  intensity:colorpicker,BRI,0,1,255 wled/35a31c/api IX=$EVTPART1\
  palette:selectnumbers,0,1,46,0,lin wled/35a31c/api FP=$EVTPART1\
  effect:selectnumbers,0,1,101,0,lin wled/35a31c/api FX=$EVTPART1\
  loadPreset:selectnumbers,0,1,3,0,lin wled/35a31c/api PL=$EVTPART1\
  dimup:noArg wled/35a31c/api A=~10\
  dimdown:noArg wled/35a31c/api A=~-10
attr WLED_35a31c setStateList on off toggle
attr WLED_35a31c userReadings rgb_old {(split(" ",OldReadingsVal("WLED_35a31c","rgb","000000")))[1]},\
effect_old {(split(" ",OldReadingsVal("WLED_35a31c","effect","000000")))[1]},\
intensity_old {(split(" ",OldReadingsVal("WLED_35a31c","intensity","000000")))[1]},\
brightness_old {(split(" ",OldReadingsVal("WLED_35a31c","brightness","000000")))[1]},\
speed_old {(split(" ",OldReadingsVal("WLED_35a31c","speed","000000")))[1]},\
palette_old {(split(" ",OldReadingsVal("WLED_35a31c","palette","")))[1]},\
state_old {(split(" ",OldReadingsVal("WLED_35a31c","state","000000")))[0]}
attr WLED_35a31c webCmd rgb:brightness:Solid:Breathe:Pride:Police
Damian
Aus den Definitionen kann ich keine Fehler interpretieren, da man sie nicht sehen kann. Ich würde aber behaupten, dass DOIF selbst keine Null irgendwo anhängt.
DrNuke33
Hätte ja sein können das es ein bug gibt der das problem verursacht.
Hab den fehler gefunden die firmware 0.12 war das problem in 0.13.b1 ist es weg
Danke nochmals
