[gelöst] farbliche Devicenamen bei nichterreichbarkeit ?
Begonnen von taskkill, 27 Januar 2022, 09:56:36
carlos
#15
So:
   CODE       CUL_TCM97001_84
   DEF        CUL_TCM97001_84
   FUUID      61ad3fb4-f33f-b077-9830-798a7ae4106fd063
   IODev      signalESP
   NAME       NC_WS_84
   NR         761
   STATE      dead
1:ok
ok
2:???
??? °C
3:???
   TYPE       CUL_TCM97001
   lastH      0
   lastT      0
     2022-01-27 09:25:35   IODev           signalESP
     2022-01-27 15:19:05   activity        dead
     2021-12-05 23:57:53   battery         ok
     2021-12-05 23:57:53   batteryState    ok
     2021-12-05 23:40:29   channel         1
     2022-01-08 01:18:29   humidity        ???
     2021-12-05 23:40:29   mode            normal
     2022-01-08 01:18:29   state           T: 2.3 H: 23
     2022-01-08 01:18:29   temperature     ???
   IODev      signalESP
   alias      Temp_Aussen
   appOptions {
"template": "thermometer1",
"name": "Aussentemperatur(84)",
  "panel": {
    "min":5,
    "max":20,
    "status": [ "temperature::%s°C:%n:success" ]
   devStateIcon 1.ok:measure_battery_100@green 1.low:measure_battery_25@red 2.[+-]?([0-9]*[.])?[0-9]+:temp_temperature 3.[+-]?([0-9]*[.])?[0-9]+:humidity 4.[+-]?([0-9]*[.])?[0-9]+:weather_barometric_pressure alive:10px-kreis-gruen@green dead:10px-kreis-rot@red
   event-min-interval .*:300
   event-on-change-reading .*
   icon       temperature_humidity
   model      NC_WS
   mqttDefaults base={"fhemout/$device"}
   mqttPublish temperature|humidity:topic={"$base/$name"}
   negation-batt 1
   readingsWatcher 300,???,temperature,humidity
   room       CUL_TCM97001
   stateFormat activity
1:battery
battery
2:temperature
temperature °C
3:humidity
humidity %
   userattr   mqttAlias:textField-long mqttDefaults:textField-long mqttDisable:both,incoming,outgoing mqttForward:all,none mqttPublish:textField-long mqttSubscribe:textField-long
keine Temperatur Werte, Batterie leer, ich geh mal austauschen.
edit: Und schon siehts wieder gut aus.
FHEM svn auf Intel NUC mit proxmox, 3 Raspberry Pi, signalduino, nanoCUL,  toom Baumarkt Funksteckdosen, einige sonoffs, hue, shelly
