Alexa restartet ständig
Begonnen von Damian, 22 März 2022, 15:39:52
Damian
Irgendetwas passt hier nicht, ich kann aber anhand der Meldung die Ursache für das ständige Durchstarten von alexa nicht erkennen:
2022-3-22 10:47:29 AM] [FHEM] got .eventToken
[2022-3-22 10:47:29 AM] refreshing token
[2022-3-22 10:47:29 AM] BearerToken '...1BE43' read from alexa
[2022-3-22 10:47:29 AM] 39_alexa.pm is new version: true
[2022-3-22 10:47:29 AM] sshautoconf: completed successfully
[2022-3-22 10:47:29 AM] *** SSH: proxy configuration set up done
[2022-3-22 10:47:29 AM] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2022-3-22 10:47:29 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:47:29 AM] Starting SSH with -R 1234:127.0.0.1:33797 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2022-3-22 10:47:29 AM] got fresh token
[2022-3-22 10:47:29 AM] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2022-3-22 10:47:29 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:47:29 AM] *** SSH: proxy connection established
[2022-3-22 10:47:29 AM] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
[2022-3-22 10:48:07 AM] [FHEM] longpoll ended, reconnect in: 200msec
[2022-3-22 10:48:07 AM] [FHEM] trying longpoll to listen for fhem events
[2022-3-22 10:48:07 AM] [FHEM] starting longpoll: http://127.0.0.1:8086/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON&timestamp=1647942487561
[2022-3-22 10:48:07 AM] [FHEM] got csrfToken:
[2022-3-22 10:48:07 AM] [FHEM] Checking devices and attributes...
[2022-3-22 10:48:07 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:48:07 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20TYPE%3Dalexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:48:07 AM] [FHEM] waiting for events ...
[2022-3-22 10:48:07 AM] [FHEM] Fetching FHEM devices...
[2022-3-22 10:48:07 AM] [FHEM] fetching: http://127.0.0.1:8086/fhem?cmd=jsonlist2%20alexaName=..*&XHR=1
[2022-3-22 10:48:07 AM] [FHEM] alexa device is alexa
[2022-3-22 10:48:07 AM] [FHEM] alexa will not send proactive events
[2022-3-22 10:48:07 AM] [FHEM] alexa uses ID: 5e5195d5-f33f-30f6-e1ea-644489e6f9298be4
[2022-3-22 10:48:07 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.48%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:48:07 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:48:07 AM] [FHEM]   executing: http://127.0.0.1:8086/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&XHR=1
[2022-3-22 10:48:07 AM] Server emitted error: {"code":"EADDRINUSE","errno":"EADDRINUSE","syscall":"listen","address":"127.0.0.1","port":33797}
[2022-3-22 10:48:07 AM] Terminating - starting the listener not possible (another instance running?)
[2022-3-22 10:48:27 AM] using config from ./alexa-fhem.cfg
Was läuft hier schief? An der Konfiguration wurde nichts geändert.
Autor von: FHEM Studio, DOIF, THRESHOLD, FHEM-Befehl: IF
justme1968
sorry. hab den thread eben erst gesehen. ist das noch aktuell?
läuft alexa-fhem wenn du es von hand startest?
ich meine mich zu erinnern das problem schon mal gesehen zu haben weiss aber nicht mehr was damals die lösung war.
Damian
Danke für die Rückmeldung.
Das Problem hat sich inzwischen erledigt. Ich habe diverse Dinge aktualisiert. Irgendwann klappte es. Was es am Ende war, konnte ich nicht genau spezifizieren.
