ZWDongle_ReadAnswer: no data read
Begonnen von HarryT, 06 Juli 2022, 23:10:40
HarryT
Hi
After a reboot I get the error "ZWDongle_ReadAnswer: no data read" and I can´t get zwave working.
This seems the same issue  as:
https://forum.fhem.de/index.php/topic,86082.msg785866.html#msg785866
Anybody an idea what the reason can be and how to solve it?
Thanks for any hint.
{HT}
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
HarryT
Zitat von: HarryT am 06 Juli 2022, 23:10:40
Hi
{HT}
For people with the same problem, after a while this issue solves itself.  A "shutdown restart" after an hour or so solves the issue.
{HT}
ZitatFor people with the same problem, after a while this issue solves itself.  A "shutdown restart" after an hour or so solves the issue.
"set ZWDongle reopen" shoould be in this case equivalent to "shutdown restart".
I am not convinced that the problem is solved, I think it is just postponed.
