Revision 26272: 02_HTTPAPI.pm: syntax check extended, device attributes disable and ...
Begonnen von System, 29 Juli 2022, 18:46:00
System
02_HTTPAPI.pm: syntax check extended, device attributes disable and ignore now lock the command execution
Source: Revision 26272: 02_HTTPAPI.pm: syntax check extended, device attributes disable and ...
